Turbo question - Hyundai Genesis Forum
 2Likes
  • 1 Post By nyangineer
  • 1 Post By Laurence Strong
post #1 of 18 Old 01-04-2016 Thread Starter
Turbo question
Hi
At times when I put my foot to the floor all I get is maybe 7 psi of boost, and other times it will wrap it's self around the post at 15 psi boost.
Could someone explain what is going on.
Is this a result of the twin-scroll?
Thanks for the help
Cheers
Larry
Laurence Strong is offline
post #2 of 18 Old 01-04-2016
'14 2.0t R-Spec
RSpectator's Avatar
Quoted: 11 Post(s)
It could be that your oil temperature isn't up to a healthy temp yet and it won't allow full power.
I believe the temperature that allows full power is roughly 140-150 F
2014 Casablanca White R-Spec 2.0T
Stage 2 Custom Alphaspeed Tune
Injen SRI
HKS SSQV4
CNT V3 Catback Exhaust
Turbo XS o2 Housing
Turbo XS Downpipe
RSpectator is offline
post #3 of 18 Old 01-04-2016 Thread Starter
Thanks for that.
Never thought of something along those lines. It did it on the way home after work at about -10 C, and I was unable to warm it up much..
I will check that out, again "Many Thanks"
Cheer's
Larry
post #4 of 18 Old 01-05-2016
nyangineer's Avatar
Quoted: 175 Post(s)
Why are you trying to floor it during winter?
titan2782 likes this.
nyangineer is offline
post #5 of 18 Old 01-05-2016
Myke123's Avatar
Quoted: 16 Post(s)
Oil temp has to be up to temp car will not allow full boost
Myke123 is offline
post #6 of 18 Old 01-05-2016
Drakkcoil's Avatar
^ This. It will pull boost and timing until the oil temp comes up to an acceptable level.
2013 BB 2.0T Premium M6
PTE 6152 56-trim | PRW Cast T3 Top Mount Manifold | TiAL 38mm Wastegate | DeatschWerks 1000cc Injectors | DeatschWerks DW200 255lph FP | FabZilla SRI | FabZilla Custom Catless O2 Housing |
WeirTech CBE | Synapse BOV | FabZilla ICP | RTM 3x12x30" FMIC | Eibach Pro-Kit | AEM Digital Boost, WB AFR & Oil Pressure | ATQ Short Shifter | OEM LSD | Haltech Tuned by APH | AEM Electronic Boost Controller @ 30psi
425whp, 351tq
Drakkcoil is offline
post #7 of 18 Old 01-05-2016
Why is that not allowed exactly?
Wjlock is offline
post #8 of 18 Old 01-05-2016 Thread Starter
Thanks all, much appreciated.
My question would be....Why can't I?
Cheers
Larry
post #9 of 18 Old 01-05-2016
3point8 Performance
titan2782's Avatar
Quoted: 1069 Post(s)
I would ask why you're trying to floor it before it's fully warmed up. Can you test some more, but make sure the oil temp is warm enough and see if you still see if the 7psi issue still occurs.
3point8 Performance
Performance parts for your Genesis Coupe, G35/G37, 350z/370z
@3point8Performance
2014 3.8 R-Spec - Tuned by AlphaSpeed
352HP/312TQ (Dynomite)
336HP/298TQ (Dynojet STD)
330HP/292TQ (Dynojet SAE)
3p8p Stage 3 intake manifolds, 3p8p manifold riser, 3p8p true CAI, J2 Headers, Coolerworx true STS
titan2782 is offline
post #10 of 18 Old 01-05-2016
Vacmurse's Avatar
Quoted: 688 Post(s)
Cheers
Larry
Because if you just start pounding on it cold, you're gonna destroy your engine... What happens to metal when you rapidly heat or cool it?
2015 Ultimate 3.8T 8AT (415 whp / 420 wtq)
Go: Precision 6266BB @ 7.9 psi, TB bored (83mm), PNP IM
Safely: AEM Meth injection, Custom Saikou Michi catch cans
Precisely: Enthuspec Subframe collars, Eibach sway bars, BC coilovers, Work D9R 19x9.5 +23 (255/35) 19x10.5 +23 (285/35)
Breakin' Necks: DD Tail as Turn, Hyper G, Gemini Hood, Hydro dip!
Vacmurse is offline
post #11 of 18 Old 01-05-2016
I don't think you understand what he was replying to. The guy asked why he would floor it in the winter not when the engine itself is cold.
Wjlock is offline
post #12 of 18 Old 01-05-2016
Quoted: 137 Post(s)
i was not able to put the full table
colomn
value where taken with pedal to the floor lol
1-oil temp
2-max throttle position (pre sept 2012)
3-max boost (pre sept 2012)
4-max throttle (post sept 2012 or update)
5-max boost (post sept 2012 or update)
genspec13 is offline
post #13 of 18 Old 01-05-2016
GTFOMWB's
speedosack's Avatar
Quoted: 25 Post(s)
Also, your car will only allow limited boost when you're low on fuel. It's like driving a Mazda3 when the tank is low.
Hi
Thanks for the help
Cheers
Larry
speedosack is offline
post #14 of 18 Old 01-05-2016
3point8 Performance
titan2782's Avatar
What is the limit? When the gas light is on?
3point8 Performance
@3point8Performance
post #15 of 18 Old 01-05-2016
Quoted: 137 Post(s)
i don't remember the exact fuel quantity it's a bit after the light is on
post #16 of 18 Old 01-05-2016
Quoted: 276 Post(s)
7 psi doesn't sound like a cold engine. Even stone cold you can get more than 7 psi. In limp mode you get no boost at all.
guybo is offline
post #17 of 18 Old 01-05-2016
Quoted: 137 Post(s)
You need to define stone cold....you being from florida and he was a -10C temp...
there could be a small difference there
post #18 of 18 Old 01-06-2016 Thread Starter
Turns out that's the problem, a couple quick tests proved it out pretty quick. Many thanks guys, much appreciated.
I do apologize, "foot to the floor" might be a poor choice of words.....I have 3 short blocks to drive, then a stop sign, a right turn into a approx. 300 foot long merge lane onto a rush hour freeway going from 0 to 110 Kph to be able to merge in safely...........most days I am able to get to my car 15 min before quitting time, some days its just not possible.
With any luck next winter it can stay parked.......
Cheers
Larry
Turbo question h0ray Ontario 2 10-09-2013 07:06 AM
Turbo question chase jones Engine 0 05-23-2012 03:58 PM
Turbo Question strezy 2.0T Discussion 2008-2012 28 02-18-2012 08:21 AM
Turbo question FLTLNR Maritimes 2 04-12-2011 08:59 AM
2.0T Turbo Question j1k 2.0T Discussion 2008-2012 5 02-09-2009 10:09 AM
