Who else is running MegaSquirt on the 2.0t? - Hyundai Genesis Forum
post #1 of 37 Old 08-26-2016 Thread Starter
Quoted: 34 Post(s)
I'm running MS3 on the 2.0. Want to know if anyone else is.
JoshClifford84 is offline
post #2 of 37 Old 08-26-2016
Daktah Pepah's Avatar
Quoted: 44 Post(s)
very interdasting. how is it working out for you? how do you get around the problems the haltec cant like ac control?
2014 Hyundai Genesis Coupe
R-Spec | 2.0L Turbo | Casablanca White | 6 Speed Manual
Mods
BPV to BOV | Interior LEDs | R2C Short Ram Intake | Wing Badges | ISIS Short Throw Shifter | HID Headlights | ISIS O2+DP+CNT v3 | Deck Lid Spoiler | Enthuspec Stainless Brake+Clutch Lines | Prosport EVO Boost+Oil Temp+Wideband | SFR Stage 1.5
Daktah Pepah is offline
post #3 of 37 Old 08-26-2016 Thread Starter
Quoted: 34 Post(s)
It's a parallel install so the stock ECU stays in place to handle all the acc's. The MS is doing fuel/spark/vvt/boost etc. It's actually going a lot smoother than I thought. It's going to take some substantial time to tune, but It started right up first try with all the correct settings. You have make your own throttle controller because the stock ECU limits throttle opening after almost any DTC, and use a separate coil driver for spark, and convert to traditional wastegate, there is a lot of little things. Other wise I am happy.
post #4 of 37 Old 08-27-2016
Quoted: 740 Post(s)
I thought the flywheel/flex plate has some odd nonstandard number of teeth to have MS work. guess someone got around it.
post #5 of 37 Old 08-28-2016 Thread Starter
Quoted: 34 Post(s)
I can't speak for the auto, but the manual has a 60 tooth crank wheel with 2 of the teeth missing, so 60-2. MS has a setting just for this. I am not sure of the older versions of MS but the latest edition has all settings needed for the 2.0.
post #6 of 37 Old 08-30-2016
RedGen13's Avatar
Quoted: 147 Post(s)
I run it on my eclipse, but I haven't thought about it for the Genesis yet.
Are you using Tunerstudio?
Any interest in doing a write up on what you have done? I think a lot of people overlook Megasquirt because of the learning curve, but it is a great tool if you are willing to put in the work.
'13 2.0T R-Spec
  • BTR Stage 3 GTX3076 @ 24psi
  • MXP exhaust manifold
  • 3" Custom turbo back
  • Synapse BOV
  • Injen Intake
  • BK1 Intake Manifold
  • 4.18 final drive w/ LSD
  • Slotted and dimpled rotors
  • Wing Badges
  • CF "functional" hood vents
'99 Eclipse Fully Built
RedGen13 is offline
post #7 of 37 Old 08-31-2016
You are the first one I read that installed a MS in this forum.
Pretty nice to hear.
ykill is offline
post #8 of 37 Old 08-31-2016
Quoted: 10 Post(s)
nice in for more
Engine:
custom short ram intake
custom hard piping synapse BOV
custom 3in intercooler core
3in custom exhaust
comp clutch stage 4 6puck sprung
ISR evo 8 manifold
325whp 347twq at 19psi
10sub stock radio
AEM afr and Boost guages
Greddy profec b specII
8000k HIDs
35% tint
tinted tail lights
struck1481 is offline
post #9 of 37 Old 08-31-2016
nyangineer's Avatar
Quoted: 175 Post(s)
Does MS allow you to have multiple camshaft maps depending on throttle position?
nyangineer is offline
post #10 of 37 Old 09-17-2016
ElDominio's Avatar
Quoted: 32 Post(s)
No, and I still don't know why you'd need this lol.
@JoshClifford84 , I'm really interested in doing this since I'm sure I can develop a bunch more thing than our current solution is offering us (Haltech). Is your car running full standalone or are you using the stock ECM for throttle control?
... "Big name" shops live off of kids like this. Enough money to buy super sweet marked up name brand parts at MSRP and then pay outrageous labor rates all day long to have a car that could have made the exact same power for significantly cheaper that will run ten times better... ... That's when people just pay out the ass 24/7 for the rest of their lives.
-Chapter 11, Section 51
- Self-proclaimed tuner
-I tune remotely!
My Facebook page at: https://www.facebook.com/AlphaSpeedPR
ElDominio is offline
post #11 of 37 Old 09-17-2016 Thread Starter
Quoted: 34 Post(s)
The cam maps are 2d, load vs rpm. I am using Tunerstudio. I am not sure about a write up because the throttle control issue really makes MS not an option for most. I will however answer any questions. I went with MS because its completely open source and I will be able to transfer it to almost any car when I get rid of the gen.
DTC limp mode makes the stock ECM throttle control useless, so you need to make your own or swap in a cable TB. The external control is worth it, but it is a lot of work and requires some electronics experience to build. I also have to pass NYS inspection once a year so keeping as many stock components as possible was key for easily doing this.
post #12 of 37 Old 09-17-2016
ElDominio's Avatar
Quoted: 32 Post(s)
Which exactly why I want this. I have asked (a certain company) countless times for several features that I know their product is capable of, but I'm usually just shot down. I'm sure I could apply a lot more in terms of development for our platform if I could get one going.
I have tuned several cars running MS, and my first aftermarket ECM on a car was an MS2 on my MR2. A way to control the Gen's throttle would be great since that would be a big jump forward, and using the newly-developed GM TAC CAN implementation is a bit shoddy. Did you do it with their kind-of implementation?
-I tune remotely!
post #13 of 37 Old 09-17-2016 Thread Starter
Quoted: 34 Post(s)
Yea I am impressed with the features MS3 offers. I have been following the product since MS1 and I never had the opportunity to actually run one until recently, so this is my first build. Being that the 2.0 isn't anything fancy as far as signals/controls, I thought it was a good candidate for my first MS build. Having complete control over pretty much everything is the best part. I still have a lot of fine tuning, but that's also fun.
I am not familiar with the GM TAC CAN, but I can describe what I did. I used an off the shelf "h-bridge" motor driver and developed a PID controller for it(microcontroller and some programming in C). Basically it uses the pedal and TPS signals and moves the TB 1:1 to pedal, it's nice but it also is being fine tuned. I am struggling with closed loop idle control, I have spend very little time with it though. I will revisit that when the time comes. I run open loop idle for now.
Also, for non Rspec cars you will lose cruise control unless you incorporate that into the external throttle control.
post #14 of 37 Old 09-19-2016
RedGen13's Avatar
Quoted: 147 Post(s)
Any interest in sharing your project files and tables so we could view them? I use Tunerstudio as well, and would be interested in seeing if I had anything to contribute. (Although it sounds like you have it all figured out)
I really wanted to use MS on the GC as I have had great experiences with it, but I'm not confident enough in my skills to be a pioneer with it. I appreciate anything you can contribute to the community as I think another tuning option would be a nice addition to this platform.
'13 2.0T R-Spec
  • Synapse BOV
  • Injen Intake
  • Wing Badges
RedGen13 is offline
post #15 of 37 Old 10-05-2016
nyangineer's Avatar
Quoted: 175 Post(s)
Stock ECU uses different cam maps depending on throttle position which optimizes driveability and performance.
post #16 of 37 Old 10-09-2016
ElDominio's Avatar
Quoted: 32 Post(s)
I ordered an MS3 with an MS3x and the controller you linked me to, @JoshClifford84 , and I'm going to have my go at making the logic with an Arduino. I'm also going to be making it a PnP, since Sebastien Moreau told me the connector we use ( http://www.onlinecomponents.com/te-c...tml?p=28218036 ) and I'm going to have an interface board to go along with it to make it a PnP deal. Let's see how this goes!
Thumb5 likes this.
-I tune remotely!
post #17 of 37 Old 10-10-2016 Thread Starter
Quoted: 34 Post(s)
Awesome!
post #18 of 37 Old 10-10-2016
RedGen13's Avatar
Quoted: 147 Post(s)
This is awesome, you have been one of the more knowledgeable users on this site when it comes to the ECU and tuning side of this car. I'm interested to see what you come up with.
And damn, $50 just for the ECU connector...
'13 2.0T R-Spec
  • Synapse BOV
  • Injen Intake
  • Wing Badges
RedGen13 is offline
post #19 of 37 Old 10-19-2017
PAdutch's Avatar
Quoted: 62 Post(s)
Bumping this thread. Has any progress been made using the megasquirt? I've just started using it on my miata and was thinking it would be cool to use on the genesis.
2013 2.0t Base
Mods: 30mm Whiteline Front sway bar.
Yup just one.
PAdutch is offline
post #20 of 37 Old 10-23-2017
Quoted: 740 Post(s)
From my understanding. it can handle and on/off type variable valvetrain, but not a progressive one.
Hyundai's CVVT = Continuous variable valve timing.
Automatic DRL (Daytime Running Lights) when engine running heli_guy Electrical and Lighting 0 10-19-2014 07:49 PM
It seems like my AC is always running? tscan Electrical & Wiring 2013 and up 24 11-25-2013 01:49 PM
Anyone running 17's? SnakeGen Wheels, Tires and Brakes 2013 and up 1 04-20-2013 09:31 PM
anybody running this set up???? swcc 3.8 V6 Discussion 2008-2012 7 07-28-2011 08:52 PM
who's running cp e intercooler? [email protected] 2.0T Discussion 2008-2012 4 03-04-2011 10:35 AM
