BTR Stage 3 Longevity - Hyundai Genesis Forum
 2Likes
  • 1 Post By Sinnah
  • 1 Post By RedGen13
post #1 of 9 Old 05-19-2017 Thread Starter
Beginner
lastrainhome's Avatar
Quoted: 11 Post(s)
I am planning to make the jump and go for the BTR stage 3 package (currently BTR stage 2 custom tuned), and I was wondering what all supporting mods would be necessary to keep the block safe and fully functional without having to worry about going WOT. I already have most of my bolt-ons besides the upgraded intercooler/pipes and Methanol injection as a safety measure/heat soak prevention instead of maximizing performance.
I was told that the BK2 Theta engine came with semi-forged rods so I'm not planning on changing them. However I'm questioning the pistons, cams, maybe valve springs, fuel pump (probably not), fuel injectors 750vs1000cc, and possibly crankshaft to give the car more power before hitting boost. The car is a DD but I do want to take her to the track and burn some rubber of course! I'm not building a full on race car. I'm just trying to make sure that I have all the supporting mods needed to fully enjoy the BTR stage 3 kit with the GTX 3076R. Any assistance will be greatly appreciated! .
BTR Stage 2 Tune 289WHP/359WTQ
14' Genesis Coupe 2.0T R-Spec
| Injen SRI | Synapse BOV w/Cold-Side Pipe | Depo 02 Housing | Depo DP + HFC | TurboXS CBE (For Sale) | Stock Boost Solenoid Bypass |
lastrainhome is offline
post #2 of 9 Old 05-23-2017
99.9% Lurker...
ScarlettGen's Avatar
Quoted: 39 Post(s)
I've put 3k miles on my new setup (395whp 320wtq) which is very similar to the BTR Stage 3 Kit and haven't had a single issue with reliability. Its been a very hard 3k miles as well.
The Gen isn't my daily so I'm not too concerned with breaking something, but torque is what kills motors not HP. My suggestion would be to get tuned with the Stage 3 kit and then run methanol on top of it for just added safety. Also if you get a electronic boost controller with multiple modes you can easily set your daily boost level to something slightly lower than whatever they tuned you to and raise it when needed.
Best of luck
2014 2.0T R-Spec
Mods:
Synapse BOV
Treadstone IC piping
Snow Performance Stage 2 W/M Kit
TurboXS Racepipe
Exceladyne Cat Back
MAMBA GTX3076r
SPA T3 Manifold
Precision 39mm Wastegate
Innovate SCG-1 Boost Controller
395whp 320wtq SAE (No meth) @23psi
3.53 gears
ScarlettGen is offline
post #3 of 9 Old 05-23-2017 Thread Starter
Beginner
Quoted: 11 Post(s)
Best of luck
Ahh, I see! It's good to hear that our motors can yet again retain longer than we had previously thought. It's nice to know that I am able to run the BTR Stage 3 kit with a stock head. Thank you very much for the info sir!
PS: are you running catch cans as well?
post #4 of 9 Old 05-23-2017
99.9% Lurker...
Quoted: 39 Post(s)
Only on the driver side. I was running it on both sides but the passenger side catch can never had anything in it so I removed it to clean up the engine bay.
2014 2.0T R-Spec
Mods:
Synapse BOV
TurboXS Racepipe
Exceladyne Cat Back
MAMBA GTX3076r
SPA T3 Manifold
3.53 gears
post #5 of 9 Old 05-23-2017 Thread Starter
Beginner
Quoted: 11 Post(s)
Okay, good to know! I was about to get snoopy's cans and I was wondering if I needed one on the passenger side. Thank you!
post #6 of 9 Old 07-24-2017
Newb level: Expert
Sinnah's Avatar
Quoted: 121 Post(s)
Best of luck
A little late here but I also agree 100% with ScarlettGen.
I've been on the GT3076r for about 10,000 miles and haven't have anything break *knock on wood*
I had it custom tuned by BTR and they kept the torque low on my own as well I believe I made like 311wtq and 380whp on 22.8lbs of boost. I daily my car on 17lbs and also have a water meth kit. The car has been reliable so far and I also take it to the track and beat on her a little. No issues at all reliability wise.
darkvader0 likes this.
2013 2.0T Base Model with R-Spec characteristics
ATP 3 inch intake
HKS SSQ4 BOV
Depo Racing DP/TP Combo
BK1 o2 housing
Isis Street Catback Exhaust
Eibach Sportline Springs
Garageline spacers
R-Spec Brembo Brakes
R-Spec LSD
R-Spec Wheels
Grimmspeed ported iintake manifold
BTR Stage 3 Kit (Garrett GT3076R)
BTR Custom tuned
Dyno'd 381whp / 311wtq 4/21/17
Snow meth kit stage 1 for safety.
Sinnah is offline
post #7 of 9 Old 07-24-2017
RedGen13's Avatar
Quoted: 146 Post(s)
I am at about 20k now since installing mine. I drive the GC as a daily during the summer, but I have 4 other cars so I haven't been terribly concerned about if something did happen ( Not that I'm hoping for issues lol). I beat the absolute crap out of my car and so far the only thing that happened to me was that I blew a hole in the stock plastic manifold.
Currently running 24 psi and have water/meth injection for a safety precaution.
Stock clutch has about 69k miles on it and it is holding well too.
My car has been modded since 1,500 miles. I was one of the first people to have the BTR Stage 1 tune, I had the BTR Stage 2 tune, and now the Stage 3. This car has not has an easy life and it is still holding together.I haven't dyno'd the stage 3 set up yet.
'13 2.0T R-Spec
  • BTR Stage 3 GTX3076 @ 24psi
  • MXP exhaust manifold
  • 3" Custom turbo back
  • Synapse BOV
  • Injen Intake
  • BK1 Intake Manifold
  • 4.18 final drive w/ LSD
  • Slotted and dimpled rotors
  • Wing Badges
  • CF "functional" hood vents
'99 Eclipse Fully Built
RedGen13 is offline
post #8 of 9 Old 08-11-2017
Newb level: Expert
Sinnah's Avatar
Quoted: 121 Post(s)
@RedGen13
So I take it you bumped up the boost to 24lbs on the stock BTR stage 3 tune?
ATP 3 inch intake
HKS SSQ4 BOV
BK1 o2 housing
Garageline spacers
R-Spec LSD
R-Spec Wheels
BTR Custom tuned
Sinnah is offline
post #9 of 9 Old 08-11-2017
RedGen13's Avatar
Quoted: 146 Post(s)
Originally Posted by Sinnah View Post
@RedGen13
Correct, probably not a good idea, but AFR is still 10.0-10.3 at WOT. I can't get Torque to show IDC, but I'm guessing I'm over 85% which is not safe. AFR is not from Torque, I have a stand alone WBO2.
I'm spraying the smallest nozzle Snow Performance stage 2, 2 bottles of HEET (yellow) and the rest windshield washer fluid (-20f)
91 octane tune
'13 2.0T R-Spec
  • Synapse BOV
  • Injen Intake
  • Wing Badges
RedGen13 is offline
BTR Stage 1 Tune andybtt 2.0T Discussion 2013 and up 30 3 Weeks Ago 12:16 PM
For the BTR Stage 3 guys Genesaur 2.0T Discussion 2013 and up 9 09-07-2018 06:26 PM
Btr stage 3 gencoupenc 2.0T Discussion 2013 and up 190 09-21-2017 05:16 PM
Btr stage 3 gencoupenc 2.0T Discussion 2013 and up 8 12-18-2014 09:31 PM
