P0365 Camshaft Position Sensor "B" Circuit - Hyundai Genesis Forum
post #1 of 44 Old 12-28-2017 Thread Starter
Quoted: 25 Post(s)
Was driving my car and it just shut off and won't start back up and will crank. I pulled this code from the car and was wondering where the Camshaft position sensor is because it clearly crapped out on me.
Evink is offline
post #2 of 44 Old 12-29-2017
Quoted: 709 Post(s)
On the sides of the head, near the back.
post #3 of 44 Old 12-29-2017 Thread Starter
Quoted: 25 Post(s)
Driver's side?
Evink is offline
post #4 of 44 Old 12-29-2017
Quoted: 709 Post(s)
there are 2 cams, meaning 2 sensors.
Unplug one and pull codes, and see if cam sensor A shows up as a fault.
Then plug it back in and unplug the other one and check again, just to make sure.
post #5 of 44 Old 12-29-2017 Thread Starter
Quoted: 25 Post(s)
Very helpful thanks a bunch!
Evink is offline
post #6 of 44 Old 01-03-2018 Thread Starter
Quoted: 25 Post(s)
So I just replaced it and have no more engine code but the car still won't start.
Evink is offline
post #7 of 44 Old 01-03-2018 Thread Starter
Quoted: 25 Post(s)
Update: Tried to start the car again, and a loud single pop came from the exhaust like the original problem and still throwing the code with the new camshaft sensor installed. I installed the new sensor into the back left corner of the engine (the back of the passenger side) which is where I think it goes. Could this also be caused by a crankshaft sensor malfunction? Generic sites says this code could also be caused by a failed crankshaft sensor.
Evink is offline
post #8 of 44 Old 01-03-2018
Quoted: 709 Post(s)
Is the starter clicking when you try to crank it?
post #9 of 44 Old 01-03-2018 Thread Starter
Quoted: 25 Post(s)
Yes it is.
Evink is offline
post #10 of 44 Old 01-03-2018
Quoted: 709 Post(s)
Yes it is.
Check fuses?
post #11 of 44 Old 01-03-2018 Thread Starter
Quoted: 25 Post(s)
I'll do that tomorrow and get back to you. Is there a specific one I should look for or just all of them under the hood and in the interior part of the car.
Evink is offline
post #12 of 44 Old 01-04-2018 Thread Starter
Quoted: 25 Post(s)
Fuses are good. Thinking I should give replacing the crankshaft sensor a shot unless you have something else in mind.
Evink is offline
post #13 of 44 Old 01-04-2018 Thread Starter
Quoted: 25 Post(s)
Does anyone have anything else in mind that it could be? I really need to fix this issue.
Evink is offline
post #14 of 44 Old 01-04-2018
Quoted: 709 Post(s)
disconnect the battery for an hour and see if it will start after that.
post #15 of 44 Old 01-04-2018 Thread Starter
Quoted: 25 Post(s)
Ok I will give it a shot. The battery keeps dying because I haven't been able to run the car and it's below zero here in Chicago. I'll disconnect it completely for an hour and give it a shot. Thanks!
Evink is offline
post #16 of 44 Old 01-05-2018
Quoted: 709 Post(s)
It could be that you just have a bad battery. try to turning off the climate fan and leave the headlights off and get a jumpstart.
post #17 of 44 Old 01-05-2018 Thread Starter
Quoted: 25 Post(s)
I originally did that a week ago when this whole thing happened. My battery is good.
Evink is offline
post #18 of 44 Old 01-05-2018 Thread Starter
Quoted: 25 Post(s)
The battery is good. I disconnected it and waited for it to reset the ECU. This didn't work. I checked the plug for the camshaft position sensor and the voltage is correct.
Evink is offline
post #19 of 44 Old 01-05-2018 Thread Starter
Quoted: 25 Post(s)
Through all the searching around I've done there is a possibility that the crankshaft sensor is causing the camshaft sensor to fail. I have a replacement coming in the mail tomorrow for the crankshaft sensor. I am praying this will be the fix. If it is, it's strange that no code was thrown for the crankshaft sensor.
Evink is offline
post #20 of 44 Old 01-05-2018 Thread Starter
Quoted: 25 Post(s)
If you still have more ideas or input I'd still love to hear it. Thanks!
Evink is offline
P2564 Turbo Boost Control Position Sensor circuit low traceurjase 2.0T Discussion 2013 and up 26 02-20-2018 01:38 PM
Issue with Camshaft Sensor or Crankshaft Sensor Ralphmac General Discussion 0 07-23-2016 04:38 PM
Enjoyed position of "Reverse" until today... infeKteDx General Discussion 40 04-06-2011 09:43 AM
