2.0T Genesis Engine Noise - Hyundai Genesis Forum
post #1 of 12 Old 02-22-2019 Thread Starter
SliderAllin's Avatar
Under some investigation it seems similar to other posts that it is due to a bad lifter. I would like to get some of your opinions because I have been told a couple of different things. One mechanic who didn't even drive it told me it could be the timing chain, but I am not experiencing any issues besides the noise when throttling at 2000-3000 rpms regardless if the car is in neutral or while driving.
SliderAllin is offline
post #2 of 12 Old 02-22-2019
Quoted: 33 Post(s)
Probably injectors. If it's a clicking sound it's most likely the noisy fuel injectors the 2.0t has. The theta 2.0t doesn't have lifters.
Sent from my SM-G960U using Tapatalk
hollysheepsht is offline
post #3 of 12 Old 02-25-2019 Thread Starter
Sound of Engine Noise Uploaded
I just changed the oil and filter. I also added some Lucas Oil Stabilizer and some SeaFoam and the car is still making the same noise. Other than the noise being annoying the car has no problems starting, idle seems to be fine and car is running great to the best of my knowledge. Your thoughts and or help as to what it might be would be much appreciated.
Here is a link to the sound I am hearing.
post #4 of 12 Old 02-26-2019
Quoted: 33 Post(s)
I'm no expert by far but it sounds like rod knock. When you accelerate does the noise increase or get louder?
post #5 of 12 Old 02-26-2019
Valve train knock will be at half the speed of a rod knock.
post #6 of 12 Old 02-26-2019 Thread Starter
Noise
The noise doesn't necessarily get that much larger but the knocking noise seems to increase (gets faster).
When you said a "valve train knock will be at half the speed of a rod knock" Are you saying it's a valve train knock? If so, what exactly is that in compared to a rod knock?
post #7 of 12 Old 02-26-2019
A rod knock when driving with a warmed up motor will be there under acceleration or load, when lifting the throttle it will go away temporarily. Valve train knock will always be there.
I would guess on a Gen Coupe 2L that valve train knock is coming form one of the buckets used for adjustment. So you would need to take the valve cover off and see what the clearances are on the cam to buckets. You may be able to see a mark on the bucket too.
post #8 of 12 Old 02-26-2019 Thread Starter
Rod Knock
How and what could I do to determine if it'd a rod knock or is that what you described how to do?
post #9 of 12 Old 02-26-2019
I would pull the valve cover off and give the cam and buckets a good look over. Rotate the engine by hand a few revolutions. Rod bearings are not generally worth the effort. Easier to drop in a different motor.
post #10 of 12 Old 02-26-2019
FWIW I reuse the gasket.
post #11 of 12 Old 05-15-2019
13 2.0T
Did you figure out what was the issue?
Adeeb Hamad is offline
post #12 of 12 Old 06-09-2019
I had the same problem with my 2010 coupe 2.0t. I drove it for almost a year without issue other then what you described. Until my timing chain slipped a tooth. It did when I turned off the car so it would not start again but luckily did not damage my engine. I don’t know to this day why it happened but that the two might have been related in some way.
Just my two cents.
Jaybee is offline
Official Texas Roll Call - *Updated 12/28/2012* WildBill Texas 115 05-04-2018 06:26 AM
