Only 5-7lbs of boost when launching. - Hyundai Genesis Forum
post #1 of 7 Old 05-06-2019 Thread Starter
Hoping someone could shed some light on this odd issue im having. I have a fbo custom tuned 2013 a/t. First track day at local strip last week when launching, the car limits boost to 5-7lbs for whole run unless i lift off throttle and get back in it. Does it if i brake boost or just hit gas from a stop. But if im driving down the road and get on it everything is normal. 24psi. Only when from dead stop this happens. I swapped in my stock ecu and it does the same thing. Swapped in my old bov just to see because thats was only thing i changed since last season. First run not realizing my issue was 15.0 at 93mph. 2nd run i let off at 8th got back in it still went 104mph. So i know everything else is running great.
Ian Tsi Dumas is offline
post #2 of 7 Old 05-06-2019
Quoted: 740 Post(s)
possibly sticky boost solenoid
post #3 of 7 Old 05-06-2019 Thread Starter
That was a thought of mine too. Would rerouting my bov to intake vac line and capping off solenoid be a viable way to test this?
post #4 of 7 Old 05-06-2019
Yes it can be a permanent solution.
post #5 of 7 Old 05-06-2019
Sergs22
Sergio Sanchez's Avatar
Quoted: 23 Post(s)
Do you hold your footbrake when you launch the car? if so, then that's your issue. Here's a forum on how to fix it.
https://www.gencoupe.com/2-0t-discus...witch-mod.html
Sergio Sanchez is offline
post #6 of 7 Old 05-06-2019
Quoted: 740 Post(s)
better solution is to install a line lock kit
post #7 of 7 Old 05-06-2019 Thread Starter
I do. The sfr tune allows for this. I always did it before no issues. With radials i would build 9-10 lbs of boost for my launch. This is a new problem. also happens without brake boosting. just mashing gas in 1st will make it happen as well. Never did this to me before.
Gauge Galore - Prosport, Defi, AEM, Autometer - Special Deal on 3 or more - OAKOS.com OAKOS Automotive Interior 48 08-23-2019 01:42 PM
Losing boost and no boost leak? Check this. JSB889 2.0T Discussion 2008-2012 21 08-04-2014 12:06 PM
Tomei 7960 boost issue's endersroc 2.0T Discussion 2008-2012 70 05-19-2014 12:13 AM
FS: ApexI AVC-R Boost Controller (Silver) Scott @ RA Engine 1 12-15-2010 06:24 PM
