Water/methanol questions. - Hyundai Genesis Forum
post #1 of 6 Old 4 Weeks Ago Thread Starter
B3Ar15's Avatar
Hello all, I recently installed a stage 2 water meth kit it all went together as expected. I just have a coupe concerns. I'm running the nozzle post TB and am worried about siphoning the line, I have a 20psi check valve but I dont think it is enough to stop vacuum from pulling it open. So I bought a solenoid and was told to install it between the tank and pump... that doesnt make sense either as whatever is in the line will be sucked out. This leads me to my question what would you all recommend for solenoid placement? I also cannot get a straight answer on nozzle sizing from the manufacturer the instructions in the kit state something totally different then what they have online. Current mods are, Injen SRI,Isr O2 housing Turboxs Stealthpipe Mxp catback, BTR stage A/T canned. My research leads me to the 225ml nozzle. Thoughts?
B3Ar15 is offline
post #2 of 6 Old 2 Weeks Ago
I'm supposed to be getting my kit soon and installing it after waiting for over two months
I'll be watching here and posting what I read.
ilbxru is offline
post #3 of 6 Old 2 Weeks Ago Thread Starter
B3Ar15's Avatar
I ended up using the solenoid, put it 6-8" away from the nozzle. After a few phone calls to the manufacturer I finally got the nozzle size of 225ml. All seems to be working as expected.
THE GO
BTR Stage A/t tune
ISR O2 housing
TXS Racepipe
MXP Catback
Injen SRI
Synapse Cold side BOV
Snow Perf. stage 2 water/meth
THE SHOW
19" VRC13
Vinyl hood/roof wrap
B3Ar15 is offline
post #4 of 6 Old 2 Weeks Ago
Tailgunner's Avatar
Quoted: 17 Post(s)
Originally Posted by B3Ar15 View Post
I have a 20psi check valve but I don't think it is enough to stop vacuum from pulling it open.
The highest possible vacuum you can pull is 14.7psi.
2010 3.8 Base
2012 3.8 Track
Tailgunner is offline
post #5 of 6 Old 2 Weeks Ago
Quoted: 637 Post(s)
It's 20+ at most, because of the it's weird manifold/vacuum tank arrangement.
If you put a vacuum gauge on the tank, you can see. As far as the manifold itself, then 20psi of vacuum is likely not going to show up on a boost gauge, as it's just a vacuum spike.
post #6 of 6 Old 2 Weeks Ago
Tailgunner's Avatar
Quoted: 17 Post(s)
Vacuum tool coating industry background (maintaining the equipment).
Vacuum has several measurement scales, I've listed what the nominal air pressure around you is, in the most common scales below:
0 PSIG (gauge) = 14.7 PSIA (absolute) = 1 Atmosphere = 1 BAR (Barometer) = 1000 mBar = 760mm HG (HG=Mercury) = 29.92 inches HG = 760 TORR = 7.6x10^+2 TORR.
A perfect vacuum would read -14.7 PSIG, 0.0 PSIA, 0.000 BAR, etc.
2010 3.8 Base
2012 3.8 Track
2013 Hyundai Genesis Coupe 2.0T Sound System Questions airisgood Electrical & Wiring 2013 and up 0 04-21-2016 07:27 PM
Winter Storage - Checklist and Questions Fast-Eddie General Discussion 6 11-30-2014 05:37 AM
NHTSA Orders Takata to Answer Questions on Recall AutoGuide.com AutoGuide.Com News 0 10-31-2014 11:40 AM
New Member/Soon To Be Owner w/ Questions about factory options. Espo General Discussion 5 02-16-2011 03:39 PM
Genesis Coupe Webcast Questions. Posted March 25, 2009 ed3cjd Media 0 04-22-2009 12:51 PM
