Questions! - Hyundai Genesis Forum
  • 1 Post By AKGC
post #1 of 8 Old 08-28-2019 Thread Starter
Questions!
Hi, I have a forge blow off valve connected to stock solenoid and wondering if I should connect it to manifold instead. I have a cat back with test pipe, injen intake and stage 2 xclusive tune
jcbr600rr is offline
post #2 of 8 Old 08-29-2019
Some times the ECU will activate the BOV when you are in partial boost and not WOT. And some think the OE vacuum hose is too small for the fastest activation.
post #3 of 8 Old 08-29-2019
Quoted: 750 Post(s)
It's more like the solenoid is opened (or closed, depending on how you look at it) with vacuum still in the line, when there shouldn't be.
When this happens, I just let off the throttle slightly.
Red Raspberry likes this.
post #4 of 8 Old 08-29-2019
How does the OE setup relieve vacuum that has been applied?
post #5 of 8 Old 08-29-2019
Quoted: 750 Post(s)
the BOV solenoid T's into the line that leads to the compressor housing.
The line leading to the weird vacuum tank on the intake manifold, is suppose to always have some vacuum.
The wastegate solenoid is actually the same as the bov solenoid, but it just has a cap/cover on the third vacuum port, and a different connector.
post #6 of 8 Old 08-29-2019
My first AM BOV was a Tial and it had issues with the OE setup. I went to straight intake vacuum and a bigger hose and that corrected the issues. I got rid of the Tial though for a Forge later.
post #7 of 8 Old 08-29-2019 Thread Starter
Is your forge on manifold ?
post #8 of 8 Old 08-29-2019
No it is a direct OE replacement.
