SuperTech Synthetic 5w20 + Fram Filter Oil Analysis at 6,576 miles - Hyundai Genesis Forum
 5Likes
post #1 of 25 Old 08-08-2018 Thread Starter
Quoted: 114 Post(s)
2010 3.8 Track. 204,xxx miles now. Original engine, transmission, and clutch.
Since everyone loves to hate on slightly longer oil change intervals, Walmart's SuperTech brand oil, and plain old Fram filters, I decided to do a test and get empirical evidence to see how well all of those factors together would do in my 200,000+ mile BK1 3.8. Judging by the results, I must be doing something right.
My vehicle sees tons of usage at relatively high speeds in the Texas heat, with a WOT pull to the redline daily. This sample also saw extended periods of high speed driving through the deserts of New Mexico and Colorado, with a trip to the top of Pike's Peak, and extended periods of idling as I slept in the back overnight on a road trip more than once. Apparently it is time for me to clean my air filter again (oops) due to the rising silicon content - I guess it has been about 21,000 miles now that I think of it. This may have slightly elevated the wear metals but nothing seems out of line so I will just clean it and drive on.
Top picture is the most recent oil analysis result with the SuperTech Synthetic 5w20 and a Fram filter. I have labelled the rest on the bottom for easier referencing and comparison. Universal averages are based upon 6,400 miles of usage in the 3.8 engine. The bottom picture is an oil analysis I had done over 100,000 miles ago using plain old Mobil 1 5w20 and an OEM filter - I wanted to directly compare the SuperTech synthetic 5w20 to the Mobil 1 5w20 to show it doesn't have to be name brand to perform just as well, and I got the mileage of the samples as close as I could while being feasible for my schedule.
Lethal1ty17 is offline
post #2 of 25 Old 08-08-2018
Quoted: 747 Post(s)
Fram
post #3 of 25 Old 08-08-2018 Thread Starter
Quoted: 114 Post(s)
Good thing I have a cartridge filter.
post #4 of 25 Old 08-08-2018
Quoted: 248 Post(s)
I still go with the Mahle OX-351,same as whats in the Hyundai box, oil filter which I found a bunch of online for 3 to 5 dollars, some in Mahle boxes and some in Beck Arnly boxes.
lvdukerider is offline
post #5 of 25 Old 08-08-2018 Thread Starter
Quoted: 114 Post(s)
The only reason I went with the Fram was just because of the overall dislike for them and wanted to show they can still perform as well as anything else.
post #6 of 25 Old 08-09-2018
Quoted: 747 Post(s)
Since you have the cartriage type, then you should be able to tell which filter has quality construction (not talking about filter element when talking about construction)
The inner barrel on the one I posted had a seam going straight. The one to look for are the ones with the spiral seam.
The actual element... that's debatable.
I change mine every 3k miles (wider ambient temp swings). As long as you change the oil/filters regularly, going a few times with longer than ideal intervals shouldn't do much.... It's different when you start adding significant power to it.
All that aside. Above all else, always make sure to check your oil level.
post #7 of 25 Old 08-09-2018
MZ777's Avatar
Quoted: 181 Post(s)
I am surprised you aren't getting much hate on this here... I remember posting a simple question on FB gencoupe group about the difference between purelator filter, which I've been using for over 50k miles and the oem ones... I got so much hate from all the marketing victims to the point that I just simply had to quit the group, because I couldn't stop my phone from going off from all the notifications from all the Facebook mechanics on there.
Glad it works for you. Despite all the hate I received, I am still using Walmart oil with purelator filters lol
Sent from my ZTE A2017U using Tapatalk
MZ777 is offline
post #8 of 25 Old 08-09-2018 Thread Starter
Quoted: 114 Post(s)
I've been doing extended drain intervals for the past 5 years and 100,000+ miles on my Genesis. It is more or less stock though. I don't consider a CAI, tune, and catback exhaust major power adders.
You can turn off notifications for a particular post on your phone. Also, I posted it on Facebook on my own post where I hit 200,000 miles on my 3.8 with the original engine, transmission, and clutch. So, it was hard for people to say "you're destroying your car" when I have the highest mileage 3.8 I've yet found. I like getting actual data to support my arguments, not "that's bad oil and you're an idiot because I said so" type logic you see online.
Red Raspberry likes this.
post #9 of 25 Old 08-09-2018
MZ777's Avatar
Quoted: 181 Post(s)
My 2009 Santa Fe has only seen SuperTech 5w20 along with SuperTech oil filters for over 150k miles and I am the original owner. I have no clue why people are b!thcing at those who don't do what they do.
MZ777 is offline
post #10 of 25 Old 08-09-2018
I use the Fram XG 9688 on both my Hyundais. Go double oil filter changes too. 10k for the Gen Coupe, 15k for the Accent for the filter.
post #11 of 25 Old 08-14-2018 Thread Starter
Quoted: 114 Post(s)
Found that source of high silicon in the oil. Let's chalk that one up to a lot of desert driving.
post #12 of 25 Old 08-14-2018
Jimmy C's Avatar
Quoted: 79 Post(s)
Any reason for not using the XG3593A slightly longer filter ?
2012 Red premium 2.0t M/t
K&N Typhoon intake
TWN Big R type 600 gram shifter knob
Quaife LSD
SFR stage 1 canned
Synapse BOV
Uniq performance rigid collar kit
Solo Performance HI-flow cat down pipe + cat back
Saikou Michi catch cans
Uniq Performance Strut Bar
BBM Spoiler
ATQ Short shifter + bushings
13+Flywheel , Veleo HD cutch and throw out bearing , APR FW bolts , SS braided hose
Stop tech SS brake lines
Uniq Performance FMIC
Jimmy C is offline
post #13 of 25 Old 08-14-2018
I used one of those once. But I buy the XG 9688 fo rboth cars by the six pack.
Jimmy C likes this.
post #14 of 25 Old 08-16-2018
Irresponsible Rookie
rthorniley's Avatar
Quoted: 23 Post(s)
Thanks Lethal! This thread is super encouraging, as my 2010 3.8 engine is at 69k (Chassis at 103k), with plans to track it.
I was gonna suggest upgrading the filter to anything but fram.
But it seems these guys who do their homework and know way more than me, including Red Rasberry think their fine. Surprising, I always heard and read that Fram was cheap and lower quality.
rthorniley is offline
post #15 of 25 Old 08-16-2018
Gaijinn's Avatar
Quoted: 241 Post(s)
Dudes,....all Walmart house brand and Sams chouce oils are made by Valvoline. Its good stuff.
Here we go again !
Gaijinn is offline
post #16 of 25 Old 08-16-2018 Thread Starter
Quoted: 114 Post(s)
Warren Distribution the last time I checked.
post #17 of 25 Old 08-16-2018
Quoted: 248 Post(s)
Yes, if I couldn't find the Mahle filters so cheap online I would feel comfortable using Fram. I dont think a well known company would manufacture and sell a sub par filter and risk ruining their name.
post #18 of 25 Old 08-16-2018 Thread Starter
Quoted: 114 Post(s)
Fram has had its issues in the past, the same goes with Purolator. If I remember right, they were both having instances of filter media tearing. The Frams were jokingly referred to as the orange can of death for a while.
As far as I can tell though using the oil analysis results from my engine over several years with multiple different types of filters, they all seem to filter the same amount for how much they are used when you look at the mileage and insolubles value in the reports. Now that may or may not mean they have a similar filtering capability, but the wear metals all seem to be in check as well. The OEM filters work a-ok. Same with K&N. Purolator. I think that's all I've tried so far.
post #19 of 25 Old 08-17-2018
rthorniley's Avatar
Quoted: 23 Post(s)
I think if you're religiously changing your oil, as most of us do. You can probably get away with the cheaper filters.
That said, the Fram XG synthetic has much more quality materials (metal backing, silicone plug, etc) than the conventional Fram filter (cardboard backing, rubber plug), so no orange death for those who use synthetic.
2010 3.8 Track,
Konig Hypergram, Nitto NT05, Trans Mount, Engine Leash, Diff Bushings, Intake, Powerstop Track Pads, Braided Brake Lines, Tien Lowering Springs, CAI, Thermal Gaskets, Stripped
post #20 of 25 Old 08-17-2018 Thread Starter
Quoted: 114 Post(s)
The 3.8 is a cartridge filter. So it doesn't have any anti-drainback valves like a can filter would. Also, the Fram cartridge filter didn't have cardboard in it, it was a plastic internal cage and plastic end caps like many other filters. Come to think of it, even the OEM filter is really just like a paper or felt on the end caps so even Fram has one upped them on this.
Mobil 1 5W-20 Full Synthetic Oil Analysis Results (4.5K miles; 55K miles overall) sa41 3.8 V6 Discussion 2008-2012 12 06-29-2018 04:19 PM
Mobil 1 Extended Performance 5w20 11,076 Mile Oil Analysis Results Lethal1ty17 3.8 V6 Discussion 2008-2012 8 08-01-2017 08:41 PM
Mobil 1 E.P. (5w20) 10,222 Mile Oil Sample Analysis Lethal1ty17 3.8 V6 Discussion 2008-2012 10 07-18-2017 08:31 AM
Engine Oil Analysis after 9,042 miles on 5w20 Lethal1ty17 3.8 V6 Discussion 2008-2012 6 07-18-2017 08:18 AM
Canadian Tire sale on Castrol EDGE API-SM oil w/free Fram Ultra Synthetic filter twopointfivebar Ontario 4 03-27-2014 07:04 PM
