Exhaust Setup Dilemma - Hyundai Genesis Forum
  • 1 Post By L8Braker
Old 3 Weeks Ago Thread Starter
Alright, I own a 2010 Gen Coupe 3.8. So back in October 2018 i installed headers, downpipes, and test pipes in addition to CNT V3 CBE. The mid resonator was also replaced with an X-pipe. I was awfully disappointed with the result, which was a loud, ugly, metallic raspy exhaust note. Me being a noob didnt research deep enough to anticipate this. I temporarily remedied the issue by taking out the X-pipe and installing two 24 inch resonators based on advice given to me by my mechanic. However, I am still not satisfied. The exhaust note is a bit tame now but the drone is quite bad. So what I am going to do is put the OEM headers back in and take off those resonators.
Now the part where I need some advice. I want a fairly deep, aggressive, but smooth exhaust note or as close to that as I can get. I was aiming for this from the start. Something that largely eliminates the rasp. After the Primary cats and downpipes, what should the rest of my setup be to achieve the exhaust note that I want?
Thanks in advance.
paulyg95 is offline
Old 3 Weeks Ago
I have installed a Catback CNT and test pipe Ark. I replaced the Center resonator with an x-pipe but to eliminate the extra RASP I had to added 2 bottle style resonator from vibrant performance (1792) just before the x-pipe. Now the exhaust note its perfect and deep just like I want. As for the header you have to expect a minimum of RASP but I read on the Forum that if you weld a pipe between the downpipe that helps enormously for the extra RASP and drone.
Kdmonster is offline
Old 3 Weeks Ago
Reader of many threads
TKJode's Avatar
Quoted: 198 Post(s)
I went thru this same issue, but with the Stillen exhaust, which is pretty much the same design as the CNT when you add a x-pipe. I had wicked bad rasp when I installed headers and test pipes.
I went the other route first - I switched to Ark Grip V2 cat back and things improved but there was still a lot of rasp anywhere above 4000RPM.
Like you, I too put my stock headers back on - that alleviated all remaining rasp and drone. The Ark is well suited for keeping things quiet when cruising with the dual reservoirs off the rear canisters.
If you're going to run CNT and want no rasp, you'll probably have to run stock headers, X-Pipe or alternatively stock secondary cats - that's the only way to keep these smaller canister exhausts chilled out and smooth sounding.
2010 Silverstone 380GT
TKJode is offline
Thanks fellas for the responses. So heres what i think i’ll do. Stock headers-downpipes-test pipes-x pipe-CNT exhaust. What do yall think if in the case this does not do it that i have the mechanic turn my straight test pipes into an H pipe to eliminate rasp? (Thats what I’ve read...) Yall think an H-pipe/X-pipe combo setup will sound good?
paulyg95 is offline
Old 3 Weeks Ago
TKJode's Avatar
Quoted: 198 Post(s)
Do either H-Pipe OR X-Pipe... both is a waste of time as they perform the same function...allowing a bit of pressure equalization between the pipes to smooth things out. There wouldn't be much change in sound.
Consider some resonator setup - eliminating any resos in the flow is going to bring drone in. You'll want something that keeps noise down below 4000RPM so you can cruise without bleeding ears. Honestly, the CNT mufflers are probably just not up to the job if you have no cats. The headers are going to do most of your work, so do that first, then introduce changes to alter the sound to your liking.
TKJode is offline
@TKJode alright thanks for that advice man. Appreciate the input.
paulyg95 is offline
Old 3 Weeks Ago
Quoted: 594 Post(s)
Depends on how well they were welded. If the transition sections aren't deburred and/or they welded over an overlap, that would cause some noise. It's easy to weld to hide these.
Old 2 Weeks Ago
Irresponsible Rookie
rthorniley's Avatar
Quoted: 18 Post(s)
What is the diameter of the headers / downpipe? And the rest of the system for that matter...
I'm no exhaust expert but I know changes in diameter can cause weird pressure zones that can create an undesirable exhaust note. So that might be something to look into, is keeping the diameter uniform throughout the system
2010 3.8 Track,
Konig Hypergram, Nitto NT05, Trans Mount, Engine Leash, Diff Bushings, Intake, Powerstop Track Pads, Braided Brake Lines, Tien Lowering Springs, CAI, Thermal Gaskets, Stripped
rthorniley is online now
Old 2 Weeks Ago
NOOB
Thraxbert's Avatar
Quoted: 30 Post(s)
I killed a ton of rasp by wrapping both of my downpipes in DEI titanium heat wrap. It helped sooooo much.
2013 Grand Touring 3.8L A/T (White Satin Pearl)
Brembo Swap / R1Concepts Rotors / Enthuspec Steel Lines
R2C Short Ram Intake
Depo 2.5" Test Pipes
ISR Performance GT Single Exit
TROS Potent Booster 2 ✨
Front: Klutch KM20 Bronze (19x8.5 ET20 + 245/35R19)
Rear: Klutch KM20 Bronze (19x10 ET20 + 285/35R19)
Thraxbert is offline
Old 2 Weeks Ago
shorttrack
Quoted: 349 Post(s)
H pipe at higher RPM's is less effective do to flow characteristics .
Nightmare On Any Street.2014 3.8 R-spec- Best 1/4 mile 11.70 ET @ 117 MPH on Nitrous and supporting mods (Many).Featured in GCtuner's featured rides section under ''links''.Many changes since then, too many to list.
shorttrack is online now
Old 1 Week Ago
Quoted: 74 Post(s)
Secondary cats do an enormous job of taming rasp. However, they’re not great for sound volume, tone, or power. I’m running stock headers/downpipes, but the exhaust was too tame w/ the secondaries in. On go the test pipes and I unleashed the Gods Of Rasp. That wasn’t going to do.
My solution was to have two resonators fabricated from Vibrant 1792 bottle resonators and their flanges. The results have been perfect. No rasp, plenty of volume under load, no drone (Magnaflow CBE) and great tone.
rthorniley likes this.
2013 3.8 R-Spec - Great White
Magnaflow X-pipe CBE
Custom Vibrant resonators
15mm/20mm spacers
BC Racing coils
TROS Potent Booster
L8Braker is online now
Old 1 Week Ago Thread Starter
so youre saying that test pipes produce bad rasp, even with the primary cats back in place?
paulyg95 is offline
Old 1 Week Ago
Quoted: 74 Post(s)
They did for me. I may be overstating it a little bit, but although I liked the exhaust sound at idle, any load part throttle or more produced a nasty rasp I just couldn’t tolerate.
15mm/20mm spacers
BC Racing coils
TROS Potent Booster
alright thanks for the feedback.
paulyg95 is offline
Old 1 Week Ago
Quoted: 19 Post(s)
@L8Braker hey man, I know we already discussed this a bit in the resonated test pipes thread, but do you need to get the car tuned after replacing the secondaries with resonators? I’ve thought about getting the Vibrant 1790 Bottle Style resonators to pair with my CBE, so with it being a slightly smaller diameter, I’m wondering if this will make the car run too rich. As I’ve heard can be the case when removing the cats off certain vehicles. Not sure if that’s the case with these cars though.
SynysterCoupe is offline
Old 1 Week Ago
Quoted: 74 Post(s)
I don’t have a tune. Any good tune based on your mods would likely produce improved numbers, but I wouldn’t say it’s required. I have my primaries still on and no CELs.
15mm/20mm spacers
BC Racing coils
TROS Potent Booster
Alright i was thinking...where in the exhaust system would vibrant resonators perform the best: further from the exhaust exit (such as, in place of the secondary cats) or closer to the exhaust exit (in my case, before the CNT dual mufflers)?
paulyg95 is offline
Custom Exhaust setup GenesisTR Ontario 48 12-14-2012 04:56 AM
Genesis Coupe's Exhaust Setup... Mr.K 3.8 V6 Discussion 2008-2012 7 06-26-2012 06:38 AM
exhaust question kwhite General Discussion 4 02-02-2012 11:26 AM
CP-E Quad tip Turboback Exhaust FBHYUNDAI Engine 6 08-03-2011 11:14 AM
