Removing second cat? - Hyundai Genesis Forum
 4Likes
post #1 of 25 Old 09-11-2019 Thread Starter
Sweden's Avatar
Quoted: 11 Post(s)
What would the gain be if the second cat is removed?
And - will the engine recognize the loss of second cat?
*if it has wheels or boobs, it will cost you*
Sweden is offline
post #2 of 25 Old 09-12-2019
Gaijinn's Avatar
Quoted: 241 Post(s)
Slight sound difference.
No performance change.
You might smell gas a bit more.
Here we go again !
Gaijinn is offline
post #3 of 25 Old 09-12-2019 Thread Starter
Sweden's Avatar
Quoted: 11 Post(s)
- Ah okey, not good for anything then. Thankīs.
Sweden is offline
post #4 of 25 Old 09-12-2019
They are not needed and will set no codes if gone. You will loose the weight if nothing else.
post #5 of 25 Old 09-13-2019 Thread Starter
Sweden's Avatar
Quoted: 11 Post(s)
- Ahh, the weight issue, yes : )
I removed the spare wheel from the trunk yesterday and bought a fill spray can instead. That wheel was heavy.
Sweden is offline
post #6 of 25 Old 09-13-2019
Did you have the aluminum spare wheel? My temp spare tire developed a bulge and the tread separated just sitting in the trunk over the years. Went to check the air pressure and could see it was distorted. Never been mounted on the car.
The OE wheels are boat anchors too.
post #7 of 25 Old 09-13-2019
Quoted: 747 Post(s)
The oem spare is a little lighter than a oem wheel/tire.
If you change the wheels because of weight, steel rims are an option. they are lighter than the stock rims.
FYI, the tire repair cans don't to much in freezing temps.
post #8 of 25 Old 09-13-2019
Quoted: 747 Post(s)
dub post
post #9 of 25 Old 09-15-2019
shorttrack
Quoted: 381 Post(s)
Nice old school Kawasaki ZX7R
shorttrack is online now
post #10 of 25 Old 09-15-2019
shorttrack
Quoted: 381 Post(s)
Second cats flow good ,bit heavy.
post #11 of 25 Old 09-15-2019 Thread Starter
Sweden's Avatar
Quoted: 11 Post(s)
- Yes, the alu spare wheel, but it still was heavy like a iron rim. Donīt know it it was extra thick rubber in that tire or what..
Sweden is offline
post #12 of 25 Old 09-15-2019 Thread Starter
Sweden's Avatar
Quoted: 11 Post(s)
- Thankīs, and yes i like those because of the look.
This one will get a ZX9-engine this winter, so hopefully i will roll out a qiute doped "ZX8" from the garage next spring : )
shorttrack likes this.
Sweden is offline
post #13 of 25 Old 09-15-2019 Thread Starter
Sweden's Avatar
Quoted: 11 Post(s)
- How could steel rims be lighter than alu rims??
Sweden is offline
post #14 of 25 Old 09-16-2019
Quoted: 747 Post(s)
because the aluminum alloy wheel is a thick chunk of aluminum. The steel wheel is just 3 stamped out pieces of steel, welded together.
The benefits of aluminum start to negate, when you realize how thick an aluminum piece has to be, to match the strength of steel in a given structural scenario
post #15 of 25 Old 09-16-2019 Thread Starter
Sweden's Avatar
Quoted: 11 Post(s)
- Yes, i didīnt think those Genesis rims were that dense.
Sweden is offline
post #16 of 25 Old 09-16-2019
shorttrack
Quoted: 381 Post(s)
1 of the 1st things I did to my Gen Coupe , got rid of the heavy OEM rims .
post #17 of 25 Old 09-16-2019
shorttrack
Quoted: 381 Post(s)
Lived in the Grudge Motorcycle capital in the height of big money street bike racing for 22 years , North Carolina . Guys shoe horned (with lots of fab work ) built Hayabusa motors into GSXR 1000's . My first true fast bike was 1998 ZX-9R .
Sweden likes this.
post #18 of 25 Old 09-24-2019 Thread Starter
Sweden's Avatar
Quoted: 11 Post(s)
- Still considering this, so...how will it affect the emission values? Here in Sweden we have a control instance "Bilprovningen" that check all cars once a year, and one of the tests is emission pollution.
Also if any "faulty" code is registered due to the lambda-values.
Sweden is offline
post #19 of 25 Old 09-24-2019
Should not make any difference if you primary cats are OK and you have no codes now.
post #20 of 25 Old 09-24-2019 Thread Starter
Sweden's Avatar
Quoted: 11 Post(s)
- Ok, but doesīnt the rear cat also affect the emission mix? Or what is the purpose of that one if not even controlled by the system as the front cat?
Sweden is offline
