Direct Injection...Carbon Buildup - Hyundai Genesis Forum
post #1 of 46 Old 06-19-2014 Thread Starter
DavidPaul's Avatar
Quoted: 159 Post(s)
Forgive me if this subject has already been covered. I did a search and didn't find anything about it.
I am quite familiar with the 2.0 Turbo engines from VW that have a serious problem with exhaust valve carbon problems with direct injection engines. This usually occurs after about 40,000 miles and requires an expensive cleaning.
Does anyone know if Hyundai has addressed this problem regarding their new engines and in particular, the 3.8?
Unfortunately, no amount of high speed driving can blow out the carbon with a Direct Injection engine.
2013 Gen Coupe Track 3.8 Red Automatic
2015 VW Tiguan SEL White Gold 2.0T
Album Link;
https://www.gencoupe.com/members/72161-a-albums.html
DavidPaul is offline
post #2 of 46 Old 06-20-2014
inertiamonster's Avatar
Quoted: 670 Post(s)
No, it's probably better than some earlier GDI motors and definitely better than a turbo GDI but the issue is still there. Best bet is to get a catch can installed to catch as much of the junk that would get baked to the valves as possible.
2013 3.8 Track Pearl White
inertiamonster is offline
post #3 of 46 Old 06-20-2014
Quoted: 35 Post(s)
man when i put in my intake manifold spacer. it was horrible. and i only had the car for 8k miles at that point.
But yeah Catch cans will help.
2013 Hyundai Genesis Coupe 3.8L Track
Team: GoGoGear Racing
Series Participating in: NASA Time Trials and United States Touring Car Championships
Sponsored by :
Meng Motorsports, Mishimoto, Track King Racing,SPEC Clutch,Blood Type Racing, QA1,Universal Technical Institute, Megan Racing, ARK Performance, STOPTECH, and BC Racing
Instagram: https://www.instagram.com/apexmuncher/
Currently at 2,860 Miles on Track
Shingo is offline
post #4 of 46 Old 06-20-2014
I'm not familiar with catch cans. Can you help a newbie get educated?
MoebiusStreet is offline
post #5 of 46 Old 06-20-2014
Quoted: 670 Post(s)
Here you go, this is more specific to the 2.0T, but it explains the concept: https://www.gencoupe.com/2-0t-discuss...catch-can.html
There are other threads too that are specific to the 3.8, both the GDI and non-GDI motors, like this one that's a general discussion for the 2013+ V6: https://www.gencoupe.com/3-8-v6-discu...catch-can.html
And here's my DIY install thread for the 3.8: https://www.gencoupe.com/diy-do-yours...n-install.html
post #6 of 46 Old 06-20-2014
Obsessed
JGowen's Avatar
Quoted: 204 Post(s)
I had almost the exact same experience, with 9K miles the buildup was pretty bad.
2011 3.8T Track red
InstalledTurbonetics 6766 3.8T kit! Built engine, fuel return, flex fuel sensor, Haltech ECU, running E85, BTR custom tuned, currently working with Alphaspeed tuning, CNT exhaust, Vertini Racing wheels, Megan mounts, dual CCs, 1400cc injectors. Last dyno tune: 608whp/602wtq
ReceivedGarageline driveshaft couplers, solid diff bushings, PSM Pro coils, JRC rear diff cover, Sedan rear subframe, complete PSM suspension arms and super angle kit, Snow Perf. W/M kit
JGowen is offline
post #7 of 46 Old 06-20-2014 Thread Starter
DavidPaul's Avatar
Quoted: 159 Post(s)
There has been some research suggesting that a water injection system can help alleviate the carbon build up problem but others say that there is a possibility of some rust building on internal parts.
Album Link;
post #8 of 46 Old 06-21-2014
a3l3e9x4's Avatar
did you try seafoam or anything of the kind before?
2013 Monaco White 3.8 Track Auto
a3l3e9x4 is offline
post #9 of 46 Old 06-21-2014
Obsessed
JGowen's Avatar
Quoted: 204 Post(s)
No! I did a manual valve cleaning when I took off my intake to send to GrimmSpeed. I've heard good things about Seafoam, though.
2011 3.8T Track red
JGowen is offline
post #10 of 46 Old 06-21-2014
Quoted: 670 Post(s)
My plan is to Seafoam every 10,000 miles, I change my oil every 5,000 miles so every other oil change, I've done it once so far, due for another this summer.
post #11 of 46 Old 06-21-2014
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
^that's a solid plan. Smell your oil though around 3000 I think the fuel smell will make you want to change that oil sooner.. GDI oil is simply nasty when it gets miles on it.
2017 VW Golf R "Daily"
Thumb5 is offline
post #12 of 46 Old 06-21-2014
Quoted: 670 Post(s)
I'm using Euro spec full synthetic which is ideal for GDI motors, I feel like I'm already being overly cautious at 5,000 considering it meets BMW, Audi, etc standards for extended life.
post #13 of 46 Old 06-21-2014 Thread Starter
DavidPaul's Avatar
Quoted: 159 Post(s)
That's the same oil spec'd for the VWs as well (VAG) Volkswagen, Audi Group.
My current 2013 VW, CC, 2.0T gets that oil from the dealership during its freebie oil changes and my 09 Eos 2.0T that I traded for my Coupe also got the same oil.
The bottom line is that it does not seem to help the VAG guys as far as carbon on the valves.
I have been driving DI engines since 09 when I got my first CC and my Eos which were both 09s. The first CC was a V6.
No matter what the VAG people did, nothing really kept them from having to do the nasty and expensive valve cleaning routine, at least by 40,000 miles. Some, even sooner. Many used Seafoam regularly without success.
Hopefully it will work on the Hyundai engines.
My Eos only had 17,000 miles on it and my first CC, V6 only had 35,000 miles on it. So, I have no experience with carbon problems.
My current 2013 CC only has 20,000 miles on it and hopefully, I will get rid of it before any carbon problems arise.
Until the government got involved in what the automakers could do and could not do with their engines, everything was going quite well.
Album Link;
post #14 of 46 Old 06-21-2014
Quoted: 670 Post(s)
To be clear I'm not saying the oil will help with carbon build up, just that it can safely go longer between changes.
post #15 of 46 Old 06-21-2014
Obsessed
JGowen's Avatar
Quoted: 204 Post(s)
The only thing that will help prevent carbon buildup is an oil catch can on the PCV side. The reasons and remedies are outlined in the threads inertia linked to above. They are a great read, as soon as possible after purchasing your DI car.
2011 3.8T Track red
JGowen is offline
post #16 of 46 Old 06-22-2014
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
Why does carbon buildup? Complete combustion that is only possible with direct injection engines. This is why no bolt on parts fixes it. That's just the way they are. Now Porsche is about the only line of DI engines that don't suffer this issue.
Thumb5 is offline
post #17 of 46 Old 06-22-2014 Thread Starter
DavidPaul's Avatar
Quoted: 159 Post(s)
Okay, got it.
Album Link;
post #18 of 46 Old 06-22-2014 Thread Starter
DavidPaul's Avatar
Quoted: 159 Post(s)
Assuming that is true, I wonder what is different about Porsche's DI?
Album Link;
post #19 of 46 Old 06-22-2014
Quoted: 670 Post(s)
The biggest reason is fuel is not being sprayed on the valves with DI. I don't think any of us are saying there's a 100% fix for the issue, just that there's ways to greatly reduce the effect. What is Porsche doing differently? Link?
post #20 of 46 Old 06-22-2014
Obsessed
JGowen's Avatar
Quoted: 204 Post(s)
Actually, it is only indirectly related to the combustion, it has to do with how the fuel is delivered to the cylinder (which is also what affects the burn efficiency, hence the indirect relationship). The reason we get such horrible carbon buildup is because the fuel is injected directly into the cylinder, rather than injected in the intake manifold directed at the back of the valve stem, hence the term "direct injection". In non-DI vehicles, the fuel being sprayed on the valve stems washes the buildup off the stems and valves into the cylinder, and it is processed out as the engine runs. In our cars, there is no washing effect as the fuel is sprayed directly into the cylinder and never touches the intake valves, so the exhaust gas and oil from the PCV system sticks to and builds up in the intake system. The reason a few manufacturers that have been working with DI engines for a while have less problem with this is because they re-engineered their PCV system to solve this or have included oil catch cans from the factory between the PCV valve and the intake port. Which is what we do in our cars aftermarket to solve the issue.
And again, all of this information can be found in the threads inertia linked to.
2011 3.8T Track red
JGowen is offline
Do we have direct injection? fred2028 2.0T Discussion 2013 and up 5 11-24-2013 10:53 AM
Should You Buy a Car With Direct Injection? AutoGuide.com AutoGuide.Com News 1 12-07-2012 06:36 AM
Hyundai gets direct injection stateside CFar Media 5 06-19-2009 06:50 PM
direct injection Mozzy General Discussion 11 06-01-2009 12:03 PM
