Engine Leash - Introduction - Page 10 - Hyundai Genesis Forum
 82Likes
post #181 of 215 Old 04-17-2017
koreancoupe's Avatar
Quoted: 12 Post(s)
I received mine, and I have to say..."The quality of the construction is outstanding. I still have not driven it yet, but I will give my opinion later. As a note, Titan was easy to get in touch with and shipping was quick. Thank you.
titan2782 likes this.
2015 R-Spec, 6spd
R2C Intake
Lightweight Pulleys
BTR ECU (Secondary Cats Off)
CPE Catback exhaust
koreancoupe is offline
post #182 of 215 Old 04-23-2017
br2
Bill
Quoted: 133 Post(s)
Originally Posted by Hoovie59 View Post
It's stupid how much this thing helps...
it can't be said any better than that.
my cheeks hurt from grinning.
br2 is offline
post #183 of 215 Old 04-23-2017
Quoted: 236 Post(s)
I got mine installed in about 5 minuits, I appears well made and well thought out. I does what its supposed to do, an elegantly simple solution to the too soft motormount problem.
lvdukerider is offline
post #184 of 215 Old 05-24-2017 Thread Starter
Addicted to parts
titan2782's Avatar
Quoted: 1059 Post(s)
Sorry guys, I'm being told that this thread violates the TOS and will be deleted. I appreciate all of the feedback and comments.
Red Raspberry likes this.
3point8 Performance
Engine Leashes, BK1 & BK2 3.8 intake manifold porting
https://www.facebook.com/3point8GenesisCoupe
2014 3.8 R-Spec 346HP/292TQ
3.91 Gear Swap, Stage 0.5 head PnP, SFR Custom Tune, 80mm TB, PnP manifolds, J2 headers, Custom H pipe, Ark GRiP + test pipes,
NST pulleys, custom true CAI, bunch of other mods,
Engine leash, Megan trans mount, 235/35/19 (F) 255/35/19 (R) Hankook V12, EBC Yellow pads
titan2782 is offline
post #185 of 215 Old 05-25-2017
Quoted: 25 Post(s)
We know were to find you
2014 Black 3.8 R-Spec
Stock+ DD 6K low HID and switchbacks | DD XML2 3K fogs | DD tail as turn with rear fog lights mod (using XM80 red led bulbs) | R2C intake | TS Short shifter + bushing kit | TS lightweight pulley kit | 80mm TB with TS spacer | Grimmspeed phenolic spacer | Ark GRiP exhaust | BC Coils
ekuapa is offline
post #186 of 215 Old 05-25-2017
BTW I was gandering at my 4cyl leash set up and had mentioned using two of them, one at each end of the motor. The front has the lifting eye at a good location for a cable to run straight across. The rear lifting eye was removed for a longer piece as it was too short.
post #187 of 215 Old 06-07-2017
BobLoblaw's Avatar
Got this installed today and coupled with my Megan mount my 2010 3.8 shifts perfectly. The mount helped but this engine leash is night and day. Absolutely worth it.
BobLoblaw is offline
post #188 of 215 Old 06-18-2017
spiralspektrum's Avatar
Quoted: 17 Post(s)
Anyone tried painting theirs? If so any specific type of paint used?
2014 Genesis Coupe Ultimate - M/T
Genesis rebadge | Raceseng shift knob | Injen SRI | CNT v3 cat back | Depo test pipes | Mishimoto catch can | EBC yellowstuff pads | Megan transmission mount | ATQ SSK w/ bushings | engine leash | DD switchbacks
spiralspektrum is offline
post #189 of 215 Old 06-18-2017 Thread Starter
Addicted to parts
titan2782's Avatar
It doesn't work out so well. I've tried painting all of the parts, it just comes off and looks bad
Needs to be anodized. I've used some heat shrink tubing around the collars and it looks ok.
Maybe someone else will have better results
post #190 of 215 Old 06-25-2017
Since installing my TROS Potent Booster I can feel the trans/engine rocking up and down on a high rpm shift. I wonder if a leash holding the front of the motor down would work?
post #191 of 215 Old 06-25-2017
Quoted: 236 Post(s)
Im not a major mod guy, but the combination of of the engine leash and sprint booster really transform the personality of the car IMHO.
post #192 of 215 Old 07-03-2017
swagger's Avatar
Quoted: 16 Post(s)
Is there a risk that anchoring the engine only at the back could cause the engine to twist unusually, causing other premature wearout?
swagger is offline
post #193 of 215 Old 07-04-2017
Quoted: 236 Post(s)
I dont see how, it wouldn't twist or move any differently than without the leash installed.
post #194 of 215 Old 07-04-2017
swagger's Avatar
Quoted: 16 Post(s)
Ok, thanks...I heard the engine mounts were weak, so wasn't sure if the leash would fully support the torque at WOT, or if upgrading the engine mounts were a real necessity with this mod. Just looking not to break something else by trying this.
swagger is offline
post #195 of 215 Old 07-06-2017
andbudzi's Avatar
Quoted: 454 Post(s)
Since luxon strut bar is in the way to put original leash i had to come up with my own version.
Oem hood strut bracket is holding up
andbudzi is offline
post #196 of 215 Old 07-06-2017
Quoted: 236 Post(s)
I dont think the leash is supposed to fully support the torque at WOT, the motor mounts still have to do their jobs, if your hard enough on them i suppose you could still dammage the mounts but the engine leash definetly takes away some of the load and IMHO makes traction to the rear wheels, or lack therof, much more predictable. I dont see how the leash could do any harm unless you were to over tighten it.
post #197 of 215 Old 07-07-2017
Actually the leash will fully support the "added" load from torque. You want just enough slack so there is no transmission of noise but not so much there is a lot of travel so excess movement caused by inertia of the engine weight is at a minimum.
post #198 of 215 Old 08-20-2017
tt0ne's Avatar
Quoted: 51 Post(s)
Just ordered one through your facebook store. Looking forward to it!
2013 RSpec
SFR Custom Tune ECU : ATQ Short Shifter : ATQ Rear Shifter Linkage Bushings : ATQ Linkage Bushings
AEM v2 Water/Meth Injection Kit : DC Sports DTS6601 Cat-Back Exhaust : K&N 69 Series Typhoon CAI
Synapse Synchronic BOV/Charge Pipe : Saikou Michi S1-DC3 Dual Oil Catch Can System
Torque Solutions Throttle Body Spacer
tt0ne is offline
post #199 of 215 Old 08-20-2017 Thread Starter
Addicted to parts
titan2782's Avatar
Thanks. They are on back order still; having a problem getting the brackets cut, should be shipping soon.
3point8 Performance
post #200 of 215 Old 01-26-2018
Made one for the front of the 2L. That OE lifting bracket is pretty flimsy though.
Introduction AlexImports New Member Section 7 02-16-2016 08:42 PM
Introduction Mackjar66 New Member Section 2 02-08-2016 01:40 AM
Introduction... Zahmed New Member Section 6 01-31-2016 12:16 PM
Introduction airkash New Member Section 3 01-02-2014 08:17 AM
and here is MY introduction sgenkcoupe New Member Section 5 08-02-2009 05:58 AM
