Engine Leash - Introduction - Page 3 - Hyundai Genesis Forum
 82Likes
post #41 of 213 Old 09-08-2016
superchode's Avatar
Quoted: 315 Post(s)
Dats it haha
superchode is offline
post #42 of 213 Old 09-08-2016
superchode's Avatar
Quoted: 315 Post(s)
I live close to those..... So it's easy to find my kids in the dark
post #43 of 213 Old 09-08-2016
Cone Killa
Quoted: 148 Post(s)
Would love one for my BK1 3.8!
ApexEight is offline
post #44 of 213 Old 09-08-2016
Jesse Crabtree's Avatar
Quoted: 50 Post(s)
(Based off for of what I understand about this mod it should help) but would this benefit an auto as much? Or at all?
Jesse Crabtree is offline
post #45 of 213 Old 09-09-2016 Thread Starter
Addicted to parts
titan2782's Avatar
Quoted: 1059 Post(s)
yes, it would give benefit to A/T as well.
3point8 Performance
Engine Leashes, BK1 & BK2 3.8 intake manifold porting
https://www.facebook.com/3point8GenesisCoupe
2014 3.8 R-Spec 346HP/292TQ
3.91 Gear Swap, Stage 0.5 head PnP, SFR Custom Tune, 80mm TB, PnP manifolds, J2 headers, Custom H pipe, Ark GRiP + test pipes,
NST pulleys, custom true CAI, bunch of other mods,
Engine leash, Megan trans mount, 235/35/19 (F) 255/35/19 (R) Hankook V12, EBC Yellow pads
titan2782 is offline
post #46 of 213 Old 09-09-2016
Quoted: 61 Post(s)
welp... consider my interest piqued! sub'd
SeaWolf is offline
post #47 of 213 Old 09-12-2016
Golfinglenn's Avatar
Quoted: 80 Post(s)
Installed something very similar this weekend. All parts were readily available at local hardware store and took about 10 minutes to put in and tighten up. Cable is 1/8" stainless steel and the part that attaches to the engine brace is just a piece of flat bar with 2 holes that I found in the gate hinge/latch section. Put a double bend in it to clear the bar and also raise the cable away from any cables/wires off the back of the engine.
2016 3.8 Ultimate M/T
CNT catback racing exhaust
Test pipes
Carbon fiber dash kit
ATQ shifter, bushings, collars
Megan transmission mount
Whiteline front swaybar
R2C w/o stupid shield
Hawk HP+ pads and RBF600 fluid
Braided lines (brakes and clutch)
Bore and polish TB
BTR Stage 1
Future mods:
PNP Intake manifiold
Golfinglenn is offline
post #48 of 213 Old 09-12-2016
superchode's Avatar
Quoted: 315 Post(s)
Well???? Howd it do? You get similar results as Titan?
post #49 of 213 Old 09-12-2016
Quoted: 80 Post(s)
Haven't been able to take it out and bang through the gears hard yet. Moderate shifting seemed smoother, but will give it a good test and report back in a couple of days :-). Total parts was about $10 though.
Test pipes
Bore and polish TB
BTR Stage 1
Future mods:
post #50 of 213 Old 09-12-2016 Thread Starter
Addicted to parts
titan2782's Avatar
patent pending, I'm suing you in the morning if i remember!!
nice job, but i wouldn't put the brace under the strut bar, it needs to go on top.
3point8 Performance
post #51 of 213 Old 09-12-2016
superchode's Avatar
Quoted: 315 Post(s)
Nice..... $10.
post #52 of 213 Old 09-12-2016
Quoted: 80 Post(s)
Curious why it needs to go on top? Not an issue, just have to fabricate a triangular piece that would incorporate both strut bolts. Do you think the 1/8" thickness of the flat bar will throw off the strut geometry too much?
And not patent infringement lol, mine has adjustable tension with a turnbuckle, no wrench required :-).
Thanks,
Glenn
Test pipes
Bore and polish TB
BTR Stage 1
Future mods:
post #53 of 213 Old 09-12-2016
superchode's Avatar
Quoted: 315 Post(s)
I am making mine out of chicken wire!!! Ultra light weight, God I am brilliant!..... No but really I like Titans original idea, the concept seems to make sense.
post #54 of 213 Old 09-12-2016
superchode's Avatar
Quoted: 315 Post(s)
Oh ya and titan, whenever you get that "patent" figured out please let me know I know a guy who knows a guy who knows my neighbors daughters boyfriend that wants one
post #55 of 213 Old 09-13-2016
cheers007's Avatar
Quoted: 66 Post(s)
Ya'll think this is a good idea to put extra stress on the intake manifold bolts, which were not intended to help keep the engine still but rather only keep the intake manifold on the block? I think this will cause a failure sooner since you are not letting the engine's movement be stopped by the mounts, rather allowing the first line of defense be the intake manifold held by a cable.
Correct me if I'm misunderstanding this "cable" and why vehicle design engineers have never thought of this in the 100+ years of auto manufacturing.
Current: 2016 3.8 Ultimate Auto Ibiza Blue
Magnaflow 16507 Cat-Back Exhaust
Previous: 2013 2.0T base Auto Shoreline Blue
Check out my instructional videos:
http://www.youtube.com/user/rsm1113
cheers007 is offline
post #56 of 213 Old 09-13-2016
inertiamonster's Avatar
Quoted: 669 Post(s)
They're using the engine hoist bracket on the back of the engine to attach the leash, not the manifold.
2013 3.8 Track Pearl White
inertiamonster is offline
post #57 of 213 Old 09-13-2016
I used a chain on a longitudinal mounted V8. Tied the exhaust manifold to the subframe. Worked great for the life of the car.
post #58 of 213 Old 09-13-2016
cheers007's Avatar
Quoted: 66 Post(s)
Noted. That would make more sense.
post #59 of 213 Old 09-13-2016
Quoted: 23 Post(s)
The point of contact is actually the pass side head, this isn't by any means something an engineer would come up with as its a backyard fix for something that could be cured with stiffer engine mounts and a torque damper. This for years has been done with cars that lack the aftermarket support of hardened engine mounts, or for those who want the engine tied down without the constant vibration.
'15 Coupe 3.8 M/T base white/tan
3" custom catback to camaro transverse muffler
AEM SRI
Megan racing transmission mount
Custom Torque damper
Custom grille air scoop
3.91 LSD
Uniq rigid collars
TS shifter bushings
On the way:
Whiteline sways
Magnaflow catback
Poly filled subframe mounts
Personal goal:
Be in the 12's N/A
Snowwhite is offline
post #60 of 213 Old 09-13-2016 Thread Starter
Addicted to parts
titan2782's Avatar
here's a great example of that
@Red Raspberry
3point8 Performance
Introduction AlexImports New Member Section 7 02-16-2016 08:42 PM
Introduction Mackjar66 New Member Section 2 02-08-2016 01:40 AM
Introduction... Zahmed New Member Section 6 01-31-2016 12:16 PM
Introduction airkash New Member Section 3 01-02-2014 08:17 AM
and here is MY introduction sgenkcoupe New Member Section 5 08-02-2009 05:58 AM
