Flowmaster Vs. Magnaflow - Hyundai Genesis Forum
 4Likes
  • 1 Post By andbudzi
  • 2 Post By superchode
  • 1 Post By mattmc
post #1 of 18 Old 02-13-2017 Thread Starter
Hello. I just created an account. I have a 2013 Genesis Coupe 3.8 track. I don't want to spend too much; I just want my car to be louder because it's so quiet. I was looking at the Flowmaster 80 series and I like the way it sounds from YouTube videos. Question is, is there anything louder than the 80 series? Maybe going to the Magnaflow side? No, I don't wanna straight pipe it. Basically, I want loud but not straight piped loud.
steezymanny is offline
post #2 of 18 Old 02-13-2017
andbudzi's Avatar
Quoted: 433 Post(s)
Remove secondary cats and replace them with strait pipes to make yor xhaust louder.
shorttrack likes this.
andbudzi is offline
post #3 of 18 Old 02-19-2017
I've had the series 80 and straight pipes after pre-cats, cats, and a resonator.
The straight pipes was way too loud and sounded like a Camaro. Huge amount of boomy drone.
If you don't want to spend a lot of money just get the galvanized Flowmaster 80. I think it will be louder than the Magnaflow but not too loud.
I believe the series 80 is an easier install, too. I don't think Magnaflow has the single-in, dual out (one out per end of the muffler) configuration the series 80 FM does.
With the series 80 configuration the installer can leave the pre-muffler clamp right where it is and weld in your muffler. This makes future changes easier.
JMO.
2013 Genesis Coupe 3.8 R-Spec
Cobra2Genesis is offline
post #4 of 18 Old 02-19-2017
superchode's Avatar
Quoted: 309 Post(s)
Hehe i just redid my exhaust. So i have a bolt on cat back with a crossflow muffler (its a knock off of the flowmaster, team allied) with resonator delete freshly painted. Just painted it to prevent corrosion while it sits up in my garage. I would offer someone to take it off my hands or even borrow it if they want to see if they like it. warning.... It is an angy exhaust, but not at all pretty but who cares you cant see it under the car anyway lolz. I loved it and thats why i kept it. All you have to do is unbolt your stock exhaust from the cats back and this will bolt right in hangers and all. Ive got a video or two and pics. I aint shipping it so if you arent near SoCal then no go.... You can pm me if you want and atleast i can share the video and pics to give you an idea of what the setup is like . I had it done for about $600 total
superchode is offline
post #5 of 18 Old 03-02-2017 Thread Starter
Thanks man. I ordered the muffler and 2 dual tips and going to have them welded on this weekend. Really need my car to actually sound like a sports car. Haha
post #6 of 18 Old 03-02-2017
mattmc's Avatar
This is exactly the way I want to go too , flowmaster 80. I was just concerned how much drone it's going to create , other than that .... Love the sound . Really only one way to find out , just get it done .
mattmc is offline
post #7 of 18 Old 03-02-2017
superchode's Avatar
Quoted: 309 Post(s)
So let me help you guys here alittle. While i didnt do the actual flowmaster 80..... I did a very similar setup but with the resonator removed as well. A crossflow muffler. So a little louder than just the muffler swap (atleast at low end). Performance wise no HP gain in fact may have lost alittle up top. Down low had more getup though..... Here is that sound, there are a ton of other 80 series videos out there as well......
https://youtu.be/yJQSwc9Dthw
And outside cruizing
https://youtu.be/ZYPgwlyYLsA
Dont get me wrong i loved it, had a kond of rat rod feel to it hehehe, still in my garage.... But.....
I just redid it to a duel setup with just a center resonated xpipe (magnaflow)..... It sounds way better everywhere and for sure gains all around (no dyno yet, but it does cuz i trust my a$$)..... I did the redo for actually cheaper than the first one. You could mellow the drone and queit it down a bit either with some resonators or rear straight through mufflers....
Both setups retained secondary cats forward btw....
Heres the new dual
https://youtu.be/oMFsjRT2JlE
And outside but in car (heheheh)
https://youtu.be/QCtn-VroE_4
Just wanted to chime in before you commited. And share from experience doing two setups. I personally like the 2nd one WAY better. It hit all three for me... Price, sound and performance, but i dont mind alittle drone either lolz (use headphones if you can it dont sound the same on a phone)
anyway happy modding and share what ya get when its done
GennyFetish and mattmc like this.
post #8 of 18 Old 03-02-2017
mattmc's Avatar
Heres the new dual
Awesome , great videos you put together. Really like that last setup ..... Now I'm really torn 🤔😂
mattmc is offline
post #9 of 18 Old 03-02-2017
mattmc's Avatar
Superchode , This is what I would like to try . I setup like you have now , but with this muffler 524554-Super 50 Muffler ? 2.25 Dual In / 2.25 Dual Out ? Mild Sound
In place of the Magnaflow you have , the Super 50 would be quieter than the 80 series and could run true duals .... However , I compared the actual muffler size , and the flowmaster is an inch wider , taller , and 3 inches longer overall .... I was looking at the picture in your video , and I'm thinking I could get it to work .
MrDestinE likes this.
mattmc is offline
post #10 of 18 Old 03-02-2017
superchode's Avatar
Quoted: 309 Post(s)
Might not fit in the tunnel.... Magnaflow makes longer ones too. But i think with a dual you are gonna want an xpipe or h pipe at minimum like someone above mentioned or it may sound poopy. The best thing about the xpipe mufflers is its all in one. Simple and less welding cutting. Other guys have done similar stuff with like ferrari center mufflers and xpipes. I was gonna do a used masserati GT center muffler that has the xpipe attached but just went this way cuz our cars will never sound like a ferrari no matter how much we want it to. Dont get me wrong that 456 center setup sounds pretty good, but just a totally different motor....
So you could do one like your looking at but i would say you are gonna want some type of crossover in there to even out the pulses.
post #11 of 18 Old 03-02-2017
mattmc's Avatar
Yeah , I was concerned about it not fitting.... You may be right . Taking into consideration about the x pipe , I need to look into a longer version of what you have . Or the exact muffler you have with resonators at the ends .
mattmc is offline
post #12 of 18 Old 03-02-2017
superchode's Avatar
Quoted: 309 Post(s)
You can find the part number of something then just you tube spam and hear what it sounds like on different stuff. Thats what i did and found this then i was sold. Its not that loud until you open it up. Its actually alot quieter than my first one on the low end. But then you open it up and its the devil hehehehe
https://youtu.be/YUHtl50IB-0
https://youtu.be/K_kMma5ZEi0
post #13 of 18 Old 03-02-2017
superchode's Avatar
Quoted: 309 Post(s)
Heres another pretty sweet g37 (dont like the car) but sounds pretty nice to me
https://youtu.be/RtYYXc3GunA
post #14 of 18 Old 03-03-2017
gen10-38's Avatar
Quoted: 31 Post(s)
I prefer silent and stealthy... dont want the piggies hearing me open it up.
Sounds good though!
gen10-38 is offline
post #15 of 18 Old 03-04-2017
Personally, I've always been a fan of Magnaflow for foreign vehicles. I like the deeper throaty growl from em. I'm doing a Magnaflow next week. Flowmaster is a great product, don't get me wrong. It's all about what sound you like if that's all your using it for.
MuscleJen is offline
post #16 of 18 Old 03-04-2017
superchode's Avatar
Quoted: 309 Post(s)
Also depends on not only the sound you are seeking, but also if you are looking for alittle performace as well. Straight through vs crossflow. I kinda went over the differences i experienced a few posts above. There is a very good youtube vid by the magnaflow engineer. Simple explainatiin about exhaust systems in particular how a crossflow type is much more restrictive and a perforated straight through is actually more free flowing that just a straight pipe. Diameter of piping is also open for debate, IMHO 2-1/4" dual is the way to go on this car, but i am sure others will disagree..... But whatever ya end up doing be sure to show it off
post #17 of 18 Old 1 Week Ago
so I just want to know do I remove my resonator or not when I install this 80 series flowmaster on my 13 3.8 track????
Simms90coupe is offline
post #18 of 18 Old 1 Week Ago
shorttrack
Quoted: 350 Post(s)
Hello. I just created an account. I have a 2013 Genesis Coupe 3.8 track. I don't want to spend too much- Basically, I want loud but not straight piped loud.
The 2 problems most Gen Coupe owners cause the after market to not want to support us .2 damn cheap to truly invest in their cars and want their car to perform and sound like a true sports car on a poor man's budget .
Nightmare On Any Street.2014 3.8 R-spec- Best 1/4 mile 11.70 ET @ 117 MPH on Nitrous and supporting mods (Many).Featured in GCtuner's featured rides section under ''links''.Many changes since then, too many to list.
shorttrack is offline
Flowmaster 80 Series vs Magnaflow Muffler only, comparison question Patrickstern 3.8 V6 Discussion 2013 and up 4 5 Days Ago 03:48 AM
Flowmaster 80 Series DirkD123 General Discussion 5 05-29-2015 11:48 AM
Flowmaster 80 series for a 2.0t caper1 General Discussion 2 04-17-2015 07:36 AM
Anyone have flowmaster mufflers? bluegene 3.8 V6 Discussion 2008-2012 54 06-10-2014 08:05 AM
flowmaster Seraph0503 3.8 V6 Discussion 2008-2012 9 03-21-2011 06:17 AM
