Recommendation for tire pressures at track - Hyundai Genesis Forum
post #1 of 8 Old 06-23-2016 Thread Starter
Been there, but forgot it
kurtfriedrich's Avatar
Quoted: 61 Post(s)
Any recommendations for track tire pressures? Short. 2.25 mile track.
Air temps ~ 70 degrees. Stock Bridgestone Potenza tires. R Spec.
Not a competitive event, point by passing only.
2016 R-Spec Empire State Gray https://sites.google.com/site/kurtoffroad/2016genesiscouper-spec
2015 Yamaha Bolt C-Spec
2014 Yamaha Super Ténéré
kurtfriedrich is offline
post #2 of 8 Old 06-24-2016
Reader of many threads
TKJode's Avatar
Quoted: 206 Post(s)
Bring a pump and a pressure gauge. You will be altering your pressure throughout the day.
Start cold at 35psi
Run them until they're warm
Pit & check pressure while they're still hot.
Bleed hot pressure down to 36-37 psi range. More or less where I like to run.
End of the day, let them cool down, then re-fill back to whatever pressure you like before driving home.
2010 Silverstone 380GT
TKJode is offline
post #3 of 8 Old 06-24-2016
Bring some chalk and mark the sidewall with it. Then you can see how much gets scrubbed off in the turns. If too much then add some air, if too little then bleed some air.
post #4 of 8 Old 06-25-2016 Thread Starter
Quoted: 61 Post(s)
tire pressures
Had a great time at the track last night (Pacific Raceway), other than watching a Vette totaled into and over a Jersey barrier).
I started at 34 as the track was cool, had been some rain. Came in and the fronts had climbed to about 41, dropped all 4 done to 38, came back in, fronts were back up to 40, pretty warm to touch. Rears were still at 38, and barely warm. Chalk marks on fronts indicated either perfect or maybe just a tad too much roll, think I will target 39 for hot running temps on front next time.
thanks for the posts.
(shifter sucks. Hope there is an aftermarket that is much better!)
post #5 of 8 Old 06-26-2016
Jimmy C's Avatar
Quoted: 79 Post(s)
Yes a few short shifters out there . I personally have the ATQ SS , front and rear bushings . ATQ short shifter retains OEM pivot ball dimensions (the only one to do so ). Rifle bolt action , smooth and precise . : advise if you do decide to go with ATQ email them first from their web site to make sure that they have stock
2012 Red premium 2.0t M/t
K&N Typhoon intake
TWN Big R type 600 gram shifter knob
Quaife LSD
SFR stage 1 canned
Synapse BOV
Uniq performance rigid collar kit
Solo Performance HI-flow cat down pipe + cat back
Saikou Michi catch cans
Uniq Performance Strut Bar
BBM Spoiler
ATQ Short shifter + bushings
13+Flywheel , Veleo HD cutch and throw out bearing , APR FW bolts , SS braided hose
Stop tech SS brake lines
Uniq Performance FMIC
Jimmy C is offline
post #6 of 8 Old 06-26-2016 Thread Starter
Quoted: 61 Post(s)
thanks for the post. Not sure how big a deal that is to install. I have since read alot of good things about the Megan Racing Transmission Mount, so I ordered that. Hoping that is enough of an improvement that I can track the car without missing shifts.
post #7 of 8 Old 06-28-2016
I normally end up at about 45 ft and 38 rear (hot) and still normaly demolish the ft outer corner of the tire with 3 deg - camber and 12 kg ft springs.
2013 3.8 R Spec
SFR canned tune
Stance coils, 12 KG ft springs
Stoptec pads with ducting
Secondary cats gutted. single pipe muffler replace.
K&N filter
18x9.5 +15 Ambit rims 275 40 ish rubbers
Kiwi Wayne is offline
post #8 of 8 Old 07-01-2016
2013 3.8 Track
84Supra's Avatar
Quoted: 121 Post(s)
Get a tire temp probe, do readings just after a session, inner, middle, and outer areas of the tire, trying for a pressure that gives consistent readings all the way across.
2013 3.8 Track M/T Shoreline Blue
Too many mods to list
84Supra is offline
Proper Tire pressures Awol Martinez Wheels, Tires and Brakes 2013 and up 4 05-20-2016 12:18 PM
Tire Size Recommendation Flats392 Wheels, Tires and Brakes 2008-2012 14 07-28-2013 11:47 PM
Need a tire recommendation Alertall Wheels, Tires and Brakes 2008-2012 9 06-07-2011 01:19 PM
Tire pressures for Auto-X/Lapping Gamz Wheels, Tires and Brakes 2008-2012 13 05-21-2010 11:56 AM
Tire Air Compressor Recommendation spica Wheels, Tires and Brakes 2008-2012 15 09-01-2009 11:36 AM
