Harness question - Page 2 - Hyundai Genesis Forum
post #21 of 22 Old 05-16-2016
I use a 4 point I brought from eBay. Lap belts are bolted to existing lap belt points along with stock belts and shoulder straps go to 2 brackets between upper and lower rear seats which I presume are for child seats? Had to use a couple of small shackles. When I'm at the track I just leave the stock belt around behind the seat and plugged in. Or just use both! The harness is definitely helpful but if you don't get it tight it comes loose. Yes a seat would be nice but i'm trying not to mod the car that much. Also if they did have an issue with a harness and stock seat you still have the stock belts.
2013 3.8 R Spec
SFR canned tune
Stance coils, 12 KG ft springs
Stoptec pads with ducting
Secondary cats gutted. single pipe muffler replace.
K&N filter
18x9.5 +15 Ambit rims 275 40 ish rubbers
Kiwi Wayne is offline
post #22 of 22 Old 09-03-2016
Alottabull's Avatar
Watch the angle
Originally Posted by Kiwi Wayne View Post
...shoulder straps go to 2 brackets between upper and lower rear seats which I presume are for child seats?
Wayne, I would be careful about using that as a mounting location for your shoulder belts because of the angle below horizontal. Angles greater than 20 degrees below horizontal generally won't pass safety inspections with racing organizations, because of the risk of spinal compression in a frontal impact.
I personally like to keep the shoulder harness mounting points level with my shoulders. It's just more comfortable on your back when you cinch the harness tight.
2012 Red 2.0T 6M
Forge BOV, Megan Exhaust, Forgestar 18" Wheels
275/40 Rear, 245/40 Front Continental ExtremeContact DWS06
Fidanza Aluminum SMF Flywheel, ACT Clutch
Alottabull is offline
Rear speaker wire harnesses question Cobra Jet Electrical & Wiring 2008-2012 3 05-21-2014 07:39 PM
quad Projector Retrofit Question AxNjXn Electrical & Wiring 2008-2012 1 11-09-2013 12:23 AM
Foglight harness to headlight harness invvoo Electrical & Wiring 2013 and up 0 03-11-2013 08:25 PM
Wiring harness Snoopy0812 Other 0 01-13-2013 08:43 PM
DD Relay Harness for HID KoolStar Exterior 2008-2012 53 09-24-2010 09:29 PM
Tags
harness
