Hyundai Genesis Coupe HID Conversion Kits! 100% Plug & Play! - Hyundai Genesis Forum
 2Likes
post #1 of 301 Old 11-04-2011 Thread Starter
www.diodedynamics.com
Diode Dynamics's Avatar
Quoted: 70 Post(s)
Arrow Hyundai Genesis Coupe HID Conversion Kits! 100% Plug & Play!
This is it! The tried and tested kit that will fit the Genesis Coupe's H11b fitment with no modification. Over 2000 kits sold to GenCoupe members. This is our new for-sale thread. For feedback, the old thread can be found here.
Diode Dynamics is pleased to announce the new Premium Diode Dynamics HID Conversion Kit. This kit has been carefully designed from the ground up to be the highest-quality HID kit available on the market, without exception.
Ballast: The ballasts are the most important component of an HID kit, as they provide the power. After years of providing midrange and high-quality ballasts for vehicles of all makes and models, Diode Dynamics learned what was important in making a good ballast, and applied it when designing these.
Controller Chip. Most digital (DSP) ballasts on the market still use generic chips, which are cheap, and work pretty well. However, when you need maximum quality, you need a new computer chip designed for one purpose. This is known as an Application-Specific Integrated Circuit (ASIC). These ballasts use brand new DSP ASIC chips for maximum efficiency and brightness, fast warmup time, and extremely stable operation.
CAN-BUS. Some vehicles have systems which sense the power consumption. Since HIDs use less power than factory halogen bulbs, this can cause issues. You can resolve this by adding capacitors, known as warning cancellers, or some ballasts come with them built-in. However, sometimes that's still not enough to trick the vehicle! To fix it, this ballast has not one, but two CAN-BUS modules, which provide capacitance and resistance to the circuit to defeat even the most troublesome modern CANBUS systems. Even if your vehicle does not use a CAN-BUS system, these modules will provide extra power smoothing for reliable operation. Simply put, this ballast will work on any vehicle, the first time you plug it in. With this kit, you don't need to worry about capacitors, warning cancellers, or resistors.
Igniter and Startup. You may have heard of ignition issues with other ballasts, caused by an igniter that is too small to withstand cold temperatures. No reason to worry with these ballasts- the oversized 24kV external igniter means that you will never have an ignition issue, even in the coldest temperatures. Additionally, the ASIC chip in these ballasts means that you only need 4 amps at nominal voltage to start up. These ballasts consume less power than any other on the market, meaning 100% reliable and fast startups, every time.
Shielding. Ever noticed a little black plastic thing clipped onto your laptop charger cord? That's a ferrite bead, which is used to suppress high-frequency signals, which can create radio interference. All ballasts generate these signals, and most just have protection in the ballast. We've also included ferrite beads on the wire, to suppress them.
LED Indicator. Convenience is key, especially during installation. To make things easy, we've added an indicator LED on the input wire, so you know that the ballast is getting power.
Case. These ballasts are the smallest you will find, about the size of a pack of playing cards. The case is fully potted, or filled with epoxy, which makes them fully waterproof and shockproof. Most ballasts on the market are filled to some degree, but these are completely filled to the top, sparing no expense to ensure longevity.
Bulbs:
The bulbs included with Diode Dynamics kits are CNLight bulbs. CNLight is the top manufacturer of aftermarket bulbs in the world, providing the best quality available. You might see other high-quality kits on the market which also use CNLight bulbs. They provide superior life, brightness, and color attenuation when compared to generic HID bulbs, like those found in most cheaper kits on the market. The one-piece base design prevents any issues with separation over time, making the entire bulb extremely reliable.
The CNLight bulb temperatures are rated accurately in Kelvin temperature at 35W, and have an industry-standard 3000 hours of estimated bulb life, which should outlast your vehicle. Please be aware that most HID bulbs are rated inaccurately from other manufacturers. 8000K is not dark blue, and 6000K is not pure white! We provide accurately-measured colors. 3000K is our lowest temperature, and has a pure yellow output, which is great for use in fog lights. 4300K is a pure white output, as seen on many factory HIDs. It will not have any blue tint to its color, and might appear slightly warm. 6000K is our most popular color, which produces an ice white color. It has a very slight hint of blue, and matches best with most LEDs. 8000K is our highest temperature, which produces an ice blue color. This is not a strong blue color though- it is still primarily white, meaning there will be no decrease in light output.
Relay:
Your Premium CAN-BUS HID Kit includes a brand new Heavy-Duty HID Relay, to power your HIDs directly from the battery, instead of the factory wiring. This relay has been designed from scratch, and utilizes a fully-sealed, waterproof relay, with flyback diode, and even has a built-in capacitor for input power smoothing. All wires are sleeved with braided techflex for an attractive appearance and extra protection. The input wires are each a meter long, and the output wires are one meter and two meters, which means the wiring will be long enough for even the biggest vehicles. The single-ground design makes installation easy. This relay was designed with reliability, convenience, and long-life in mind.
Warranty: Our warranty is through Diode Dynamics, LLC, so you can be assured that you will get fast and friendly service should you have any problems. There is a full-replacement 1-year warranty on all HID Kit components, including HID Bulbs, Ballasts and Relay.
Shipment: We carry our own inventory, so no waiting for them to be shipped from overseas, or waiting on big, unreliable suppliers to ship them. They ship right from our own inventory, in St. Louis, Missouri, usually the same day you order.
Kit comes with:
  • One pair HID bulbs in your choice of bulb size and color
  • Two 35w super-slim ballasts
  • Mounting hardware for ballasts
  • Limited Lifetime warranty on electronics (ballasts and wiring)
  • Three-year limited warranty on all components
  • Free Diode Dynamics decal
  • Diode Dynamics 30-day satisfaction guarantee
  • Heavy-duty HID Relay Harness to protect your factory electronics.
Order HERE:
LOW BEAM:2010-2012 | 2013-2015
FOG LIGHT:2010-2012 | 2013-2015
HIGH BEAM:2010-2012 | 2013-2015
Diode Dynamics Low Beam Dust Caps:
INCLUDED FREE OF CHARGE!!!
*HID RELAY HARNESS REQUIRED FOR 2013-2015 GENESIS COUPES*
If you have any questions, please don't hesitate to post, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Customer Submitted Photos:
Customer Reviews:
"Diode Dynamics provide top quality products. Since 2010 and never disappointed. Just install HID fog on my new Genesis Coupe 2013, took 15 minutes each side, very white looks better with my OEM HID low beam." (Posted on April 30, 2013)
"I purchased the kit along with my low beams and the lights as a combo are amazing! i can see everything so much better at night, not to mention they look super nice when u have both sets on at the same time. If you're thinking about it then you NEED to get these bad boys ASAP!" (Posted on August 14, 2012)
"I have bought many HID kits before from local sellers and online sellers and this was by far my best purchase. The service is excellent and the kit fit perfectly. Driving home, i go through a wooded area each night and it is illuminated much better then the kit i have in my other car. I have since ordered a set for two other people and will definitely buy from here again." (Posted on July 31, 2012)
"I have to say that this is the best HID Kit i have ever bought. The lights are nice and bright and a perfect color. The warm up time is super fast and also there is NO buzzing at all from the ballast!! Everything you need comes in this great kit. Would recommend to anyone who wants to do a HID conversion." (Posted on February 14, 2014)
"I recently bought the 6000k kit, and got it in two days, super fast, extremely easy to install, that coming from some one that this the first time installing HIDs on a car, thanks for they video on Diode's YouTube channel, that adapter that comes with the order made it so much simpler to install, it only took me like less than 5mins to do it " (Posted on January 12, 2014)
"Ordered the 6000k kit on a Thursday, got here on Saturday...incredibly fast shipping! I've never done any sort of work like this before and with the help of the install videos DD has on their YouTube page, this install went super easy. Totally changes the look of the car and the amount of light is like night and day compared to the stock halogens. Can't wait to add switchbacks!" (Posted on December 30, 2013)
[/I]
Genesis Coupe - Lighting
We Are The #1 GenCoupe Lighting Experts
(314) 205-3033
Diode Dynamics is offline
post #2 of 301 Old 11-07-2011
Site Sponsor
Nikko@ImportShark's Avatar
do you still have that group buy going on?
www.importshark.com - Premiere Korean Product Supplier
Seibon | M&S Carart | Injen | Sequence | Luxon | Sarona
VIS | AEM | RoadRace | ARK | Road Runs | SuperLUX | Ixion
E-mail: [email protected] / AIM: ImportSharkInfo
post #3 of 301 Old 11-08-2011 Thread Starter
Quoted: 70 Post(s)
We are not currently running any group buy promotions
(314) 205-3033
post #4 of 301 Old 11-17-2011
is 4300k exactly the same type of color (white) as what the luxury manufacturers use? i recently got an hid kit with 4300k but it kinda projects teal at night when driving.
taz883 is offline
post #5 of 301 Old 11-17-2011 Thread Starter
Quoted: 70 Post(s)
A 4300K kit would be pure white, by our rating system. Thanks!
4300K is the factory temperature for most manufacturers. It also has the most usable light output.
(314) 205-3033
post #6 of 301 Old 11-18-2011
Heiss's Avatar
6k & 8k are they also pure white? Is there a notisable difference from the 4300k?
Heiss is offline
post #7 of 301 Old 11-18-2011 Thread Starter
Quoted: 70 Post(s)
Please see this guide- 6000K is ice white and 8000K is ice blue. Thanks!
https://www.diodedynamics.com/catalog/hidguide.php
(314) 205-3033
post #8 of 301 Old 12-14-2011
Flipski's Avatar
Order placed! Will post pics after install!
Bump for good service!
Flipski is offline
post #9 of 301 Old 02-01-2012
curtisb's Avatar
got my hids in when i got home there grate , one of the easyest things iv done on the car thatnks guys
curtisb is offline
post #10 of 301 Old 02-03-2012
Quoted: 12 Post(s)
Hey, i know you guys dont supply 5000k but i was wondering if you had any thoughts on it. I know the 4300k are pure white to you guys, but comparing to my friends 5000k, im looking for those.
choboy9242 is offline
post #11 of 301 Old 02-03-2012 Thread Starter
Quoted: 70 Post(s)
We have a "tighter" rating scale than most companies- our 6000K is generally equivalent to the 5000K available from others... white with just an extremely small hint of blue. Thanks!
(314) 205-3033
post #12 of 301 Old 02-03-2012
could somebody post a link to a good DIY walk-through on HID installs?
great if it covered Main headlight and Foglights. (since I ordered both )
R-SpecdCoupe is offline
post #13 of 301 Old 02-04-2012
curtisb's Avatar
you know i was going to do diy but it was so easy and took 5 mins i forgot lol
curtisb is offline
post #14 of 301 Old 02-04-2012
curtisb's Avatar
i can tell you real fast , first you dont have to buy you can take the battery terminal off ,
next get a 10 mm socket n wratchet take the two 10mm bolts out the head lights and push the head lighht out from the back and pull a lil un plug the light plug
then take off the dust cap on the end take the cap and drill a hole in it so you can put the wires and bulb threw it , plug the wires in to the head light black to black red to yellow plug in your plugs to the 35w compas and plug the light back in and push them back into the light holder and turn yoour lights on to see if they work done ,5 mins
curtisb is offline
post #15 of 301 Old 02-04-2012
curtisb's Avatar
what eles do you guys have for the coupe i can get?
curtisb is offline
post #16 of 301 Old 02-04-2012
are these kits still 79.00
is it free shipping o am in ontario canada
plese send price shipped thanks
birel is offline
post #17 of 301 Old 02-06-2012 Thread Starter
Quoted: 70 Post(s)
We are coming out with quite a few new things soon! Keep an eye out
We do not offer free international shipping. It will be around $25 for Priority mail to Canada. The exact price is given at checkout. Thank you!
(314) 205-3033
post #18 of 301 Old 02-06-2012
curtisb's Avatar
got anything els i can get now?
curtisb is offline
post #19 of 301 Old 02-06-2012 Thread Starter
Quoted: 70 Post(s)
Hmmm not sure what all you have, but we have switchback front turn signals, LED reverse lights, full interior LEDs, fog light LEDs or HIDs, and angel eyes. More products coming soon!
(314) 205-3033
post #20 of 301 Old 02-07-2012
curtisb's Avatar
How much for turn light and the reversing
curtisb is offline
The FINAL Official 2013 Genesis Coupe Thread N2OInferno General Discussion 2576 12-17-2018 12:49 PM
The 2011 GC's are here! DSV-UltraGL General Discussion 738 01-07-2011 11:48 AM
GReddy to Debut Performance Parts for Hyundai Genesis Coupe rntibbyboy Engine 23 10-19-2009 04:37 PM
Canadiandriver.com First Drive of Genesis Coupe el_capitan General Discussion 5 04-07-2009 11:21 AM
