Carbon Fiber CAI help - Hyundai Genesis Forum
post #1 of 21 Old 07-08-2019 Thread Starter
Hi guys. I'm in the process of building a carbon fiber CAI for my 2016 coupe.( I currently have an Injen SRI and I don't like the hot air it pulls it. Not relevant just a backstory.) My main question is what epoxy/ resin should I use? I know I need a high temperature epoxy/ resin but I'm not sure which one to use, because I want a crystal clear finish on my carbon fiber intake, no discolored mixes or brands.... Any help would be appreciated 😃
Ps- I can't find the answer I'm looking for, so if you say "read around, or do a search" can you provide the link to the answer so I can actually read it. Then feel free to troll lol. Thank you
Eric Rosiana is offline
post #2 of 21 Old 07-09-2019
Quoted: 732 Post(s)
You'll not want to use high temp epoxy/resin.
Reason being, is that you will need to use pre-impregnated carbon fiber, and the process involves requiring to use an autoclave.
post #3 of 21 Old 07-09-2019
GennyGuy's Avatar
Why are you set on CF exactly? You can still get great CAI kits that arent CF.
There are a few good youtube videos you can find though discussing proper resins for certain projects
GennyGuy is offline
post #4 of 21 Old 07-09-2019 Thread Starter
why do I need pre-peg? I was planning to layer the resin over top each carbon fiber sleeve, using the poor man's vacuum bagging technique (electrical tape) to get rid of air holes
post #5 of 21 Old 07-09-2019 Thread Starter
to be honest I love the carbon fiber look and want to do as much carbon fiber custom work as I can. I'll spend the extra $$ to learn if I have to, but I want to do everything custom
post #6 of 21 Old 07-09-2019
Quoted: 732 Post(s)
"high temp" carbon fiber pertains to a temp resistance of 350~400*F+
resin need to cure evenly, otherwise you're going to have hot/cool spots while it cures. That and in a constantly varying temp environment is going to crack.
Do you know why in all the instructions for resin, that they say to have 3 containers, 2x A/B containers and a mix container? An even mix of the resin and catalyst is critical, more so that the A:B ratios being correct.
This is 5x more so on thin parts. Thick parts can radiate heat and cure more evenly because there is more mass to allow the heat to transfer, thin parts can't do that effectively.
Just get a aluminum pipe section and wrap some cf vinyl over it, then clear coat it.
post #7 of 21 Old 07-09-2019 Thread Starter
I know people have made carbon fiber intakes without using an enclave, and just let it cure in room temperature. Not sure if they used high temp epoxy/ resin. But I am also not sure of my engine bay temperature. I do not want my epoxy/ resin melting.
I know I can cheap out and do an aluminum pipe wrapped in carbon fiber but that's not the same lol. Cheap. Fast. Reliable. Can only have 2
post #8 of 21 Old 07-09-2019
Quoted: 732 Post(s)
the time you put into it (which you can't get back) just to make a pipe, you're going to find that it wasn't worth it.
and resin doesn't melt, it cracks and shatters.... well the kind used for composites.
post #9 of 21 Old 07-09-2019 Thread Starter
Fair enough, good point lol. It will take awhile, but worth it... In my opinion, hell yea! Me personally. I love working on my car. I don't care how long it takes, I like to do everything myself. And what I don't know I try to outsource, and learn from that way. No wife, no kids, just free time. And when I'm not working on my car I just play PS4, so trust me when I say I have time to kill 😂
And plus I already purchased all the materials except epoxy resin, so I can't really turn back now.
post #10 of 21 Old 07-09-2019 Thread Starter
Ps- not trying to argue with you, just trying to explain my positioning. I appreciate you taking time to respond and help me out
post #11 of 21 Old 07-09-2019 Thread Starter
Helping**
post #12 of 21 Old 07-09-2019
Gaijinn's Avatar
Quoted: 236 Post(s)
Should have asked first
Heres where you should have went to purchase all your materials. They are made with temp proof stuff already. Its quite simple to piece together whatever you need.
https://www.intakehoses.com/carbon-f...ht-tubing.html
Here we go again !
Gaijinn is offline
post #13 of 21 Old 07-10-2019 Thread Starter
Lol I actually started with that idea and on that site. I was so close to getting that and coupling it together. But after some consideration I realized I wanted it flush, I don't like the look of couplings connecting pipes together, looks half assed in my opinion. And finding a ferrule the right size to connect the pipes together from the inside has proven to be a pain in the ass. So my ego kicked in a little more and said f- it, why not build 1 solid piece
post #14 of 21 Old 07-10-2019
shorttrack
Quoted: 379 Post(s)
deleted this response as I just come to realize I wasted 3 minutes of my time .
shorttrack is offline
post #15 of 21 Old 07-10-2019 Thread Starter
Hey guys. I appreciate all the replies, but no one has answered my question lol... What epoxy/ resin combo do I use to build my CAI?
You guys are free to do whatever you please to your cars, but me. I want to build a CF pipe. If someone could just tell me what epoxy to use so the engine heat doesn't **** it up, that would be amazing!
Ps- all the materials except epoxy is purchased. So definitely not interested in taking a different route. Thank you.
post #16 of 21 Old 07-10-2019
shorttrack
Quoted: 379 Post(s)
Lol I don't like the look of couplings connecting pipes together, looks half assed in my opinion. And finding a ferrule -So my ego kicked in a little more and said f- it, why not build 1 solid piece
Hmmmmmmmmmmmmm.Function should be most important .In the age of Smart phones I should have not be surprised .
post #17 of 21 Old 07-10-2019
shorttrack
Quoted: 379 Post(s)
Would be a SMART idea to search the WORLD WIDE WEB and find a carbon fiber company that could answer your question .I would tell you what I used on my carbon fiber inlet but it might be again'st your "EGO" to use it .
post #18 of 21 Old 07-10-2019 Thread Starter
Would be a SMART idea to search the WORLD WIDE WEB and find a carbon fiber company that could answer your question .I would tell you what I used on my carbon fiber inlet but it might be again'st your "EGO" to use it .<img src="https://www.gencoupe.com/images/GenCoupe_2014/smilies/tango_face_devil.png" border="0" alt="" title="Devil" class="inlineimg" />
Lol I messaged 2 carbon fiber companies last week, still waiting on their response. And I contacted epoxy/ resin companies as well, but they don't know the best one to use for this application because we don't know how hot it can get... Thats why I was hoping someone here might have an answer lol. And could I see a picture of it? If it's not discolored my ego shouldn't mind lmao
post #19 of 21 Old 07-10-2019
shorttrack
Quoted: 379 Post(s)
Under hood temps hover around 150 to 160 degrees in the 90-100 degree weather .
post #20 of 21 Old 07-10-2019 Thread Starter
AHH THANK YOU!! So technically I don't need a high temp epoxy. This makes this sooo much easier &#x1f603;
