Totally disabling the ESC 100% - Page 4 - Hyundai Genesis Forum
post #61 of 76 Old 09-21-2011
I think many people are getting confused here... ESC and TCS are two completely different things....
crashp is offline
post #62 of 76 Old 09-21-2011
Well what does totally disabled mean? If I forget to turn it off at the track usually the first turn reminds me. I turn it off and it doesn't do anything after that?
ABS is different.
post #63 of 76 Old 09-22-2011
WTF is NOS???
XS Speed's Avatar
Disable means that when you turn off your TSC/ESC it is completely off no partial interruption.....
Quickest All Motor Genesis Coupe In North America**
13.15 @ 105.87 09/02/11 On The Motor
12.33 @ 113.15 09/02/11 On The Bottle
12.92 @ 109.75 09/26/09 First Pass In The 12s
**Not Fastest or Most Powerful, Quickest, with an actual Timeslip to back it up...
If you don't like it, go to the track and prove me wrong
Don't forget your slips.....
Want An $800 Paperweight, Contact BTRcc They'll Fix You Up
XS Speed is offline
post #64 of 76 Old 09-22-2011
Out Pissing Off cops!
Mcmonopoly's Avatar
ABS is different.
^^Same for me, and I never had the chance to experience ABS kicking in @ the track. Ever.
2010 2.0T GT Genesis Coupe
|Beyond Redline-Stage 3|
wHP/Tq-TBD-Mustang Dyno
Mcmonopoly is offline
post #65 of 76 Old 09-22-2011
Joe-Shmoe
Ronin's Avatar
I did, at the same track you run probably because I have less sticky tires and was late braking. It was a pretty iffy situation and good thing no one was coming out of the pit at that time. Remember that you are running wider tires and R-Spec bolts.
ABS kicking in basically= no brake for 1-2 seconds...
Karussell White 2.0GT Coupe
  • CP-E Intake
  • TWM short shifter + TiC shifter bushing
Ronin is offline
post #66 of 76 Old 09-22-2011
Mcmonopoly's Avatar
Yeah but I also ran the car bone stock with a tune and OEM everything in the braking department, with the OEM Wheels and tires, on the OEM alignment.
The OEM Brembo pads don't have enough bite to have the ABS engage on dry pavement, even if I was standing on the brake pedal.
The hawk pads have way more bite, but again I ran the car with only upgraded pads and SS lines/fluid, and never engaged the ABS.
And now with the wider tires and front camber, no chance I'll lose braking traction in front....Like you said.
I would like to try out a base brake equipped GC to see the actual difference.
post #67 of 76 Old 09-22-2011
I got the ABS to kick in once at VIR but I was absolutely pushing the pedal through the floor. This was with some Dunlops and EBC Yellostuffs. Could not get that to happen with the OEM track tires.
post #68 of 76 Old 09-22-2011
Joe-Shmoe
Ronin's Avatar
They have enough to lock the 18" all-seasons...
  • CP-E Intake
Ronin is offline
post #69 of 76 Old 09-22-2011
Mcmonopoly's Avatar
Which are essentially crap for performance driving(no offense)...LOL
post #70 of 76 Old 09-22-2011
Yes the brakes are only as good as the tires. And the OEM all seasons are some crappy tires.
post #71 of 76 Old 04-12-2014
first, read how the ESC and stability control, controls traction.
there is NO electronic diff. so it can't vector torque to either wheels to keep stability.
how else would it do it? by applying the BRAKES to individual wheels.
Second thing it does, is lower throttle.
Now ask yourself, does the car lower throttle and/or apply brakes at any point, when ESC is off?
Yes it does apply brakes, supprisingy when i try to get back off at low speed. I hate it.
evlo is offline
post #72 of 76 Old 04-12-2014
What year is you car?
post #73 of 76 Old 04-12-2014
2012 automatic - also it is EU spec., so maybe it is more strict for europe?
evlo is offline
post #74 of 76 Old 11-21-2015
Hey this is a pretty old post but i had the same problem when my GC. but I had to ask a random guy who drove the same car I met at the hyundai lot who has the same car as me (2015 hyundai genesis coupe r-spec). And he told me to press the the traction control button then press and hold it again until it beeps and should notify you that is tranction and stability control is off. I did it and it worked but havnt gone to an open area or track to try to do any burn outs. Hope this helps
Sebastian Sam is offline
post #75 of 76 Old 3 Weeks Ago
2012 Hyundai genesis 2.0t cant turn off esc
tcoffeen29 is offline
post #76 of 76 Old 2 Weeks Ago
I can on my 2010. ABS you cannot turn off.
TCS disabling itself - FML Lauren Electrical & Wiring 2008-2012 11 07-04-2011 06:36 PM
Disabling All Airbags txrxs Electrical & Wiring 2008-2012 11 07-04-2011 05:44 AM
Anyone have issues with ESC/TSC disabling? obelisk General Discussion 31 11-23-2010 07:38 AM
Random disabling when Bluetooth activates? Citadel712 Electrical & Wiring 2008-2012 4 07-17-2009 01:05 AM
