Oil temp gauge not working - Hyundai Genesis Forum
post #1 of 6 Old 10-03-2019 Thread Starter
Had to replace my motor a few weeks back with a “new to me” motor with 10k claimed. My buddy broke my clock spring so I have a few lights on for that.
Regardless I used my old wiring harness. Never had anything wrong electrical. Since I first got it running I’ve had this issue. Is it possible I missed something on install or should I just look into swapping the sensor?
AlexVoisin is offline
post #2 of 6 Old 10-04-2019
The sensor itself is easy to check with an ohm meter.
What engine do you have?
Test with an ohm meter with connector unhooked.
CVVT Oil Temperature Sensor (OTS)
▷ Type: Thermistor type
▷ Specification
Temperature [°C(°F)] Resistance (kΩ)
40(40) 52.15
20(4) 16.52
0(32) 6.0
20(68) 2.45
40(104) 1.11
60(140) 0.54
80(176) 0.29
post #3 of 6 Old 10-04-2019 Thread Starter
I got a code reader today it’s throwing p0198 high output. Cleared the fault and the gauge works for a few minutes before shutting off again. I have a 13 3.8. Where is the sensor located? I’ve looked through threads and haven’t seen anything
post #4 of 6 Old 10-04-2019
On the 2L it's just below the PCV valve.
post #5 of 6 Old 10-06-2019 Thread Starter
If anyone can verify the oil temp sensor is under the fuel rail on the bk2 3.8?
post #6 of 6 Old 10-07-2019
Appears to be on the right side of the engine at the rear.
