2013 rspec no low beams - Hyundai Genesis Forum
post #1 of 9 Old 4 Weeks Ago Thread Starter
My driver side low beam originally went out. Now both of my low beams are out. I have high beams and turn signals on both sides. I can’t find any fuse that controls the headlights. Put in brand new bulbs last night and no luck. PLEASE HELP!
Jarrodbrown is online now
post #2 of 9 Old 3 Weeks Ago Thread Starter
about to lose my mind honestly. every fuse in the car and under the hood is good.
post #3 of 9 Old 3 Weeks Ago
Quoted: 748 Post(s)
did you make sure that the main headlight connector is plugged in all the way... and the wiring loom is not pinched under the headlight housing?
Next option is to check relays.
post #4 of 9 Old 3 Weeks Ago Thread Starter
I've checked the connection on both lights, Can't seem to find any relays related to the lights. People say it could be the multi fuse but I feel like multiple things wouldnt work if it was.
post #5 of 9 Old 3 Weeks Ago
There are solid state relays on the back of the interior fuse box for the headlights.
post #6 of 9 Old 1 Week Ago
Yetisis's Avatar
Quoted: 10 Post(s)
Any luck? Just noticed the exact same problem last night. Also, is it just one relay that controls both low beams or is driver/passenger on separate relays? Both my low beams just stopped working at the same time so it seems far fetched that it’s the bulbs and I wanted to check here before replacing parts that aren’t broken
Yetisis is offline
post #7 of 9 Old 1 Week Ago
Here are the wire diagrams for a '13
post #8 of 9 Old 1 Week Ago
Yetisis's Avatar
Quoted: 10 Post(s)
Thank you! Going to screw around with it tonight and see if I can make any progress. I’ll update if anything useful turns up
Yetisis is offline
post #9 of 9 Old 1 Week Ago
Michael Persons's Avatar
Quoted: 12 Post(s)
Had a similar issue after rebuilding my coupe after a front end collision. It's most likely a grounding issue. Do your low beams blink sporadically?
Wish my car worked
Michael Persons is offline
