TCS Problems 2015 3.8 - Hyundai Genesis Forum
post #1 of 4 Old 2 Weeks Ago Thread Starter
Hello fellas! I recently got new tires and rims. 245/45/18 in front and 265/45/18 in the rear. 18x9.5 +22. So basically whenever I turn traction and stability off and I try to “drift” it will cut out all power and I’m not able to give it any gas until about 5MPH that’s when it goes back to normal. I hooked up an abs scanner and got C1611. If anyone has had issues with this please let me know! It’s very frustrating. I have the 8speed auto.
Nick Concha is offline
post #2 of 4 Old 2 Weeks Ago
C1611 Vehicle signal (VSS) time out
C1611 CAN Time-out EMS
C1611 Lost Communication with ECM
P1611 Immobilizer-Transponder Malfunction
B1611 FAM Communication Lost and BUS Failure
B1611 CAN Time-out FAM
EMS is Engine Management System. Can't really find out much on it but this. The manual suggest it is a separate module but I cannot find any info on it. May be part of the ECU.
General Description
The body electrical system is comprised of four ECU applied CAN* communication nodes.
※ Control Units : BCM(Body Control Module), PDM(Power Distribution Module), SMK(Smart Key) ECU.
The steering wheel lock/unlock state of ESCL and the required data when EMS(Engine Management System)controls
starting are sent to PDM by the serial communication line.
* CAN (Controller Area Network) : CAN is serial bus communication type which links not only communication system
but also control units each other.
* LIN (Local Interconnect Network) : LIN is serial communication type which is used in electrical control system. (This
is less expensive.)
C1611 is not mentioned
NO DTC code Description
1 P1610 Non-Immobilizer-EMS Connected to an Immobilizer
2 P1674 Immobilizer-Transponder status Error
3 P1675 Immobilizer-Transponder Programming Error
4 P1676 Immobilizer-Smartra Message Error
5 P169A Immobilizer-SMARTRA Authentication Fail
6 P1690 Immobilizer-Smartra No Response
7 P1691 Immobilizer-Antenna Coil Error
8 P1692 Immobilizer Indicator Lamp Error
9 P1693 Immobilizer-Transponder Error
10 P1694 Immobilizer-EMS Message Error
11 P1695 Immobilizer-EMS Memory Error
12 P1696 Immobilizer-Authentication Fail
post #3 of 4 Old 2 Weeks Ago Thread Starter
post #4 of 4 Old 2 Weeks Ago Thread Starter
General Description
is less expensive.)
