Transmission Fluid and Rear Differential Fluid Change - Page 2 - Hyundai Genesis Forum
post #21 of 25 Old 05-08-2016
twopointfivebar's Avatar
Originally Posted by Deteriorated View Post
I've had my 2014 2.0T for almost 2 years now, and of late the shifting has become a little more sticky in 2nd gear particularly, as well as more notchy upshifting into 2nd and 3rd gears. Hopefully I'll see improvement on this by swapping the fluids to the Redline oils.
Seems like the only piece of information still missing in this guide are the torque values to be used:
Manual Transmission (per the shop manual):
Drain Plug - 43.4 - 57.8 lb-ft
Filler Plug - 43.4 - 57.8 lb-ft
Differential:
Drain Plug - ??
Filler Plug - ??
I would assume that the torques for the differential drain and filler plugs would be the same so long as the bolt sizes are the same. I checked the shop manual for the 2.0T (2014) for even just changing the differential fluid, and this information seems to be completely missing.
According to the service manual, it is the following:
Differential:
Drain Plug - 36.1 to 50.6 lb-ft
Filler Plug - 36.1 to 50.6 lb-ft
Engine: PA X2 91 tune, K&N SRI, 3" Tsudo cat-less resonated downpipe, custom mid-pipe, HKS SSQV III BOV
Handling: Bilstein B8 shocks & struts, Eibach Pro-Kit springs, strut bar, Conti DW
Exterior: 6000K HIDs, 2500K fogs, OE Lip spoiler, 19's Miro Type 111 Hyper Silver wheels, Black wing badges
Interior: CP-E gauge cluster, AEM Wideband, Boost, & Oil Temp gauges
twopointfivebar is offline
post #22 of 25 Old 06-28-2017
Quick Question.
For those of us with R-Spec/Track models with factory LSD: is Redline 75w90 still the recommended oil? Is it fine right out of bottle or need any other additives put in?
boosted1g is offline
post #23 of 25 Old 06-28-2017
Quoted: 31 Post(s)
Originally Posted by boosted1g View Post
Quick Question.
That is what I used on mine, it worked great. not a lick of trouble with it. Ran it on that fluid for 60,000 miles with zero issues.
wmunn is offline
post #24 of 25 Old 01-08-2019
So you used the same oil for the transmission and the rear differential?
MisaBlackBird is offline
post #25 of 25 Old 04-24-2019
KingOfNines's Avatar
Always best to remove the fill plug before draining, as not to cause a vacuum and actually get it stuck inside the case and have to be drilled. Happened once to me when I was working at Valvoline and never again will I crack a drain plug without being 100% sure there isn't a fill plug somewhere
Sent from my ONEPLUS A6013 using Tapatalk
KingOfNines is offline
Transmission Fluid Change??? iammarkus Drivetrain 5 08-09-2018 01:22 PM
Manual Transmission Fluid Change. 22617 Drivetrain 47 03-24-2015 02:20 PM
Transmission Fluid Change Help. NihS07 Drivetrain 11 10-14-2012 10:27 AM
Manual Transmission Fluid change pics? Split Drivetrain 5 07-26-2011 08:53 AM
Car is smoking after the transmission fluid change pjmtwo Drivetrain 10 07-14-2011 11:56 AM
