OEM Diff Mount for that extra hole ;) - Page 10 - Hyundai Genesis Forum
 12Likes
post #181 of 238 Old 04-27-2016
SUN★WORKS
SteveJohns29's Avatar
Quoted: 153 Post(s)
All solid mounts. No issues..
Sponsored by:
475WHP/363wtq
SteveJohns29 is offline
post #182 of 238 Old 05-04-2016
Quoted: 13 Post(s)
Originally Posted by cleangencoupe View Post
Originally Posted by jrtz80 View Post
I used the bolt and tapped around it with a hammer at the same time. You can't pull that hard with the bolt because it's rubber mounted... But worked like a charm doing both.
how long did it take?
Took me about 4 hours or so, all together.
jrtz80 is offline
post #183 of 238 Old 06-21-2016
kennyg808's Avatar
Agree
Originally Posted by newmedia View Post
I came to conclusion that this mod is not needed and may cause more damage to the car when the part goes bad. I got lucky that it snapped off clean instead doing more damages that I have seen in other cars.
If anyone wants to buy My used throughdown rear differential mount let me know.. I have brand complete new one and used one with missing bolt.
I believe the diff was made with only3 mounts to allow play and save the drive-train from snapping.
Wish List:
Vega Rear Bumper
Night Shadow LED lights (cracked them)
Powered By Max Pro Coil-Over set.
kennyg808 is offline
post #184 of 238 Old 03-15-2017
hate to bring back a old thread but to any one who has added the fourth oem mount ,how has it held up over time? I know op stated it's still holding up well l, but that was in 2014. any one know if things have changed between then and now?
rcso436 is offline
post #185 of 238 Old 03-15-2017
FWIW here are the OE part numbers
554952M000 - BUSHING-CROSSMEMBER MOUNTING5
554193M000 - BOLT
1351012006K - WASHER-PLAIN
1360212006K - WASHER-SPRING
shorttrack likes this.
post #186 of 238 Old 03-15-2017
Cone Killa
Quoted: 148 Post(s)
Wait so is the bushing one piece or two?
ApexEight is offline
post #187 of 238 Old 03-15-2017
it's just a one piece bushing.
rcso436 is offline
post #188 of 238 Old 03-16-2017
Can any one that have done this confirm if it is safe to do this? Maybe it stiffs the diff much?
elboss is offline
post #189 of 238 Old 03-16-2017
The Original poster did 4 times.
AxeOfGlory likes this.
post #190 of 238 Old 03-16-2017
So I ordered all the stock parts and they will be here tomorrow.
My plan is to clamp a piece of plywood on the back side of the OE hole and use that to guide the pilot drill bit for a 3" hole saw. Then using a 1" solid steel rod and hammer try to flare the opening in a bit.
Looks like the sway bar is in the way so that will have to come off temporarily.
post #191 of 238 Old 03-16-2017
shorttrack
Quoted: 366 Post(s)
elboss Go to the Nitrous on a GDI 3.8 thread and you will see pic's of my nitrous Gen Coupe build .In the pic's you will see the sleeve and OEM C- Bushing installed in the 4th bushing location .Many on this forum know of my build and for some reason do not pass on info to other members that are inquiring about mods that are in fact on my build .Go to post # 306 .I would not use solid bushings on a street driven car , More stiffer than OEM yes but not solid (Diff Bushing),the sub frame I would go with solid sub frame risers bushings only .
shorttrack is offline
post #192 of 238 Old 03-16-2017
Quoted: 31 Post(s)
The 4th bushing setup looks clean.
Did you weld the sleeve in place or did you remove the subframe?
Do you have a part number for the sleeve?
ilikebears is offline
post #193 of 238 Old 03-16-2017
MrDestinE's Avatar
Quoted: 93 Post(s)
Yo, Shorttrack,
Have you ever disclosed the measurements on your sleeve for the absent dif bushings?
or were you going to offer them for sale?
TJ
14 R Spec 3.8 in Casablanca White
Konig Integrams 8.5 10.5 19s w/25 offset
245/35R 285/35R Pilot Sport A3
Diode Dynamics Tail as Turn w/backup mod
Custom Flowmaster 50 cat back Drowned RIP
03 Dodge Ram 5.7 std cab 13.89 stock engine
full stock exhaust. Back on the Road
2000 ZX12R...Faster than i am SOLD
MrDestinE is offline
post #194 of 238 Old 03-16-2017
MrDestinE's Avatar
Quoted: 93 Post(s)
Ah, nm, I finally found the post.......
TJ
post #195 of 238 Old 03-16-2017
shorttrack
Quoted: 366 Post(s)
Loosen the sway bar ,traced O.D of sleeve and grind out when close to sleeve O.D dimension use a metal bur bit ,final fitting of sleeve will be with 120 grit paddle/flapper style wheel or stone bit .No removing of sub frame .I made (machined the sleeve myself .Sleeve dimension is ,1-1/2 inch long,3.1605 '' I.D and a wall thickness of .090 to .100'' +O.D of 3.3405 to 3.3605 inches .Take these to a machinest and he can machine the sleeve out in short time .Mild steel or chrome alloy steel is fine . Tig weld in place .
post #196 of 238 Old 03-16-2017
shorttrack
Quoted: 366 Post(s)
554193M000 - BOLT
Make sure you get the upgraded OEM bolt ,not the BS re-called bolt (Grade 10)
post #197 of 238 Old 03-16-2017
shorttrack
Quoted: 366 Post(s)
I measured the outter part of the mount and it was 3 1/8
Maybe a 3 inch would work and then go from there. Shaving a little at a time till you can press it in. If you go under there and look at both holes and compare, you'll know exactly where to stop.
Ditto.
post #198 of 238 Old 03-16-2017
shorttrack
Quoted: 366 Post(s)
For those who would want a second rear bushing mount . I made a mild steel sleeve with .100'' wall thickness .The I.D. was a average that I got from the factory OEM bushing O.D. The length was the same as the bushing . I traced the bushing O.D. onto the sub-frame and cut the hole to size .Welded the sleeve in place (be careful not to warp the sleeve).Inserted the bushing part 62466/part # 554952m000-the bolt is #55446 ,use off the shelf washer & lock washer .Anyone in the Houston area ,I have 2 extra sleeves made if anyone wants one .Free .
straight forward .
post #199 of 238 Old 03-16-2017
shorttrack
Quoted: 366 Post(s)
The rear sub frame sheet metal holding the diff mounts is a mere .080'' thick , very tough metal but thin .A 2nd sleeve will make the sub frame stronger in this area and spread the shock load of the diff by controlling the instant down travel of the diff's rear under load .1 of the key mods for my Gen to get into the 11's in the 1/4 .
post #200 of 238 Old 03-17-2017
I assume the part I posted is the upgraded one as it was what Hyundai shows for the current bolt.
I just got the parts in from Fourgreen. And it is the metric 10 grade bolt. How is the recall bolt graded?
The OE bushing outside diameter is 3.15" or 80mm
CAI on A/T. What did you do with extra hole in the pipe? Erusion 2.0T Discussion 2008-2012 7 07-17-2012 07:36 AM
diff stabalizer mount CARLYLE Mid-West / Great Lakes 7 08-02-2010 02:42 PM
Kpr diff mount surfmavrik Suspension 2008-2012 15 06-15-2010 02:44 PM
Kpr diff mount surfmavrik 2.0T Discussion 2008-2012 2 05-29-2010 08:47 PM
