-   Engine and Drivetrain (https://www.gencoupe.com/engine-drivetrain/)
-   -   OEM Diff Mount for that extra hole ;) (https://www.gencoupe.com/engine-drivetrain/221569-oem-diff-mount-extra-hole.html)
cleangencoupe 02-23-2014 07:45 PM
So. Pretty much self explanatory. Make the damn hole bigger.
Ordered oem parts
http://i11.photobucket.com/albums/a1...07475B2AA9.jpg
Forced this sucker in
http://i11.photobucket.com/albums/a1...8083D391D8.jpg
Duro5341 02-23-2014 07:56 PM
Subed........what's it feel like?, what size is the hole?
I'd always wondered if this was possible, and perhaps in the original design...........but omitted later because of cost/benefit analysis.
Duro
Paps511 02-23-2014 08:00 PM
better or worse?
cleangencoupe 02-23-2014 08:33 PM
Feels a lot better. Just took it out for a drive.
D!RTYLOUD 02-23-2014 11:21 PM
Good work aguacate. I'll have to put this on my list of to dos. What do the parts run me?
Red Raspberry 02-24-2014 04:18 AM
In this parts diagram it shows a bushing on the front side of the sub frame opposite the rear bushing. I've never noticed that before.
Part 62466 part number 554952M000 is the rear bushing, and 62465 part number 554902M000 is the front bushing.
http://www.jimellishyundaiparts.com/...0854-55501.jpg
Paps511 02-24-2014 05:09 AM
So you had to get #55446 and 62466 and the two washers?
How long did it take you to do? 1h?
Kyoshiro 02-24-2014 07:38 AM
Genius! I've always wondered about this.
What was the total cost of parts?
And also, what is complete list of parts required?
cleangencoupe 02-24-2014 08:44 AM
Yup. Those are the part numbers. Took me over an hour to do. Pain in the ass when you don't have the right tools
Paps511 02-24-2014 09:55 AM
And what would the right tools be?
Jack, Jack stands etc but what else
cleangencoupe 02-24-2014 10:26 AM
I think a sheet metal hole saw would work better. I used one of these metal grinders.
http://i11.photobucket.com/albums/a1...121856BF41.jpg
The more and more I drive the car, the better I can feel the difference. If you're one that pays attention to little differences youll definitely notice this.
CoupeDeVille 02-24-2014 10:37 AM
subscribed.
newmedia 02-24-2014 01:14 PM
hope it holds, My throughdown rear differential mount just snapped after 2 years of use. Now I got a broken bolt inside of differential.
http://i641.photobucket.com/albums/u...ia1/010-30.jpg
Fr3nchy524 02-24-2014 01:46 PM
How does the stock on differ then the aftermarket ones? Wouldn't the bolt snap the same way everyone else's aftermarket one has? Or is there more support in the oem mount that would prevent the bolt from snapping? Or possibly the different grade bolts only puts stress on the aftermarket bolt? If you get what I'm trying to say.
cleangencoupe 02-24-2014 01:48 PM
That's what happens with a solid mount
cleangencoupe 02-24-2014 01:52 PM
The OEM one has rubber that allows the diff to still flex. If you go under your car and look at the mount, it's sitting halfway in and half way out in the cross member. The bolt pretty much nests on the rubber bushing which allows room for flex
Red Raspberry 02-24-2014 01:53 PM
Get a left handed thread drill bit 1/3 the diameter of the bolt. Then drill the center of the bolt in reverse. It will probably spin right out after you go in about half way.
Fr3nchy524 02-24-2014 01:55 PM
Ah... That makes sense. Wonder why companies can't make the mounts not solid. Oh well. Sounds like a project I'll be doing to my 13.
newmedia 02-24-2014 02:02 PM
I came to conclusion that this mod is not needed and may cause more damage to the car when the part goes bad. I got lucky that it snapped off clean instead doing more damages that I have seen in other cars. :)
If anyone wants to buy My used throughdown rear differential mount let me know.. I have brand complete new one and used one with missing bolt.
cleangencoupe 02-24-2014 02:07 PM
You were using a SOLID mount. Those will cause damage
