DIY Oil Catch Can Install - Page 11 - Hyundai Genesis Forum
 2Likes
post #201 of 600 Old 05-20-2011
Moderatar
tarpan's Avatar
I just installed my two catch cans. The purple one on the driver side by the headlight is actually mounted without any drilling. There is a peg there that you can mount the bracket on. For the PCV outlet that is 1/2 inches, I had to run to the hardware store and in the plumbing aisle I found a 1/2 inch to 3/8 inch barb.
Patrolling The Mojave Almost Makes You Wish For A Nuclear Winter
2010 KW Base GC
- HKS SSQV BOV
- PowerAXEL Reflash
- OEM Strut Tower Brace
- Ebay catch cans
Originally Posted by flylow View Post
they keep asking.... "but who makes this car???" and i keep saying... its just a genesis made by genesis lol!
tarpan is offline
post #202 of 600 Old 05-21-2011
Function Over Form
1320drift's Avatar
That CC looks nice. I went budget with a $20 one. After all it is just a catch can.
Parts Shop Max Level Up
SFR tuned
1320drift is offline
post #203 of 600 Old 05-21-2011
Moderatar
tarpan's Avatar
I hear ya. The ones I installed are actually the $20 ebay ones but its just more expensive for us canadians because of the shipping. Works out to about $35 per can after everything.
2010 KW Base GC
- HKS SSQV BOV
- PowerAXEL Reflash
- Ebay catch cans
tarpan is offline
post #204 of 600 Old 05-24-2011
cowcow's Avatar
Quoted: 41 Post(s)
Anyone getting weird noises during startup after installing the CC? It only happens when starting the car cold. The noise sounds like a lot of air moving and it varries from low to higher pitch until the car gets warm.
cowcow is offline
post #205 of 600 Old 05-24-2011
Those are normal noises. I believe it is the throttle open more for the cold start air mix.
FWIW I drained my turbo side can the other day. Got about 30 ml of black thick oil. Very little was in the turbo to IC tube.
post #206 of 600 Old 05-24-2011
GCkid's Avatar
Yeah that has nothing to do with catch cans. Your car always does that. It is more audible if you have an intake and silencer delete. The car revs slightly until it warms up or you put in reverse/drive. It the car lubricating the turbo and such
343 whp 371 ft-lbs
Fastest auto around, I think sooo
CarDomain
http://www.cardomain.com/ride/3855220
YouTube Channel
http://www.youtube.com/user/GCkid100?feature=mhee
GREAT, ETHICAL VENDORS:
Korean Auto Imports <--ONLY vendor for authentic vega bumpers
G&M Performance <--Tom has amazing customer service and is the man
Turbo XS <--Amazing tuner. Quality products
Invision Automotion <--Harry and Craig are killing it over at IA
VENDORS WHO SUCK:
Message me
WWW.FLOWAND.CO
GCkid is offline
post #207 of 600 Old 05-24-2011
cowcow's Avatar
Quoted: 41 Post(s)
It's just that I can clearly hear it more with the CC. I guess it's because there's more metal (which also reflects sound). I don't get the same sounds with an intake the stock rubber elbow. Good to know it's not just me getting the sounds.
Just to be sure though, the sound i get sounds like waves.
cowcow is offline
post #208 of 600 Old 05-24-2011
Moderatar
tarpan's Avatar
Is it possibly due to the new hoses touching the hood/lift and vibrating? I had to adjust mine a bit so that it wouldn't touch when I closed the hood.
2010 KW Base GC
- HKS SSQV BOV
- PowerAXEL Reflash
- Ebay catch cans
tarpan is offline
post #209 of 600 Old 05-24-2011
GCkid's Avatar
That would be more of a rattling sound not air moving
I have that sound happen so many times after installing different things under the hood, so annoying lol
343 whp 371 ft-lbs
CarDomain
YouTube Channel
VENDORS WHO SUCK:
Message me
WWW.FLOWAND.CO
GCkid is offline
post #210 of 600 Old 06-03-2011
jadyer's Avatar
Hey what size hose do you need? The dude said he has9mm or like 16mm I think. I would guess 9? Does anyone know quick? I am about to Finnish my order
Sent from my SGH-T959 using AutoGuide App
jadyer is offline
post #211 of 600 Old 06-03-2011
jadyer's Avatar
Sorry. 9mm or 15mm.anyone?
jadyer is offline
post #212 of 600 Old 06-03-2011
You need two 9 mm for the passenger side. On the drivers side you need one 9mm and one 12 or 13 mm.
What I did is got all 3/8" (~9mm) and used a piece of thin hose over one of the3/8" barbs so the 1/2" would fit properly. This one goes to the drivers side intake connection.
post #213 of 600 Old 06-03-2011
jadyer's Avatar
OK thanks. So the universal one should work if its 9mm? Can't decide between cusco. Ago or greddy
jadyer is offline
post #214 of 600 Old 06-03-2011
I use the cheap $25 ones from Ebay.
post #215 of 600 Old 06-03-2011
jadyer's Avatar
Ya I would but but I want a nice looking one for the Gen. I may look into eBay for my set can. Are there some decent ones on eBay?
jadyer is offline
post #216 of 600 Old 06-03-2011
Oh I see......
post #217 of 600 Old 06-11-2011
Function Over Form
1320drift's Avatar
I just installed 2 cc and used a bolt on the firewall. It's about middle of the car 6" down from the hood. It has a plastic nut on it. I made a bracket to hold both cc. Perfect fit for the small cc I bought off ebay. I will try and load photos but I'm pretty lazy about things like that so don't count on it.
SFR tuned
post #218 of 600 Old 06-21-2011
Mar uh bow two point oh
Cliffmoney's Avatar
I just ordered two CCs from ebay. All i have to do for the passenger side can with the breather on it is run the hose that went into the intake to the can and cap the intake? does it matter which hose it is?
2011 MB 2.0 base Loving it
2.0/3.8 Frankentake, Glow Shift Boost Gauge, Ebay Catch Cans, Shimmed stock BPV, Deop O2 housing and DP, Bosch 550, and PRW stage1.5 lost to foolishness
2007 TW Si Sold
98 BRP Eclipse RS R.I.P.
Cliffmoney is offline
post #219 of 600 Old 06-21-2011
Moderatar
tarpan's Avatar
I know its hard to see but I am at work so this is the best I can do with MS Paint. Yes you are correct. You will want to replace the hose that originally connects from valve cover to the intake:
2010 KW Base GC
- HKS SSQV BOV
- PowerAXEL Reflash
- Ebay catch cans
tarpan is offline
post #220 of 600 Old 06-21-2011
Headlight God
Happyface44r's Avatar
Here is how me and my girlfriend did our set up. We used 3/8'' fuel line hose and 15/32'' CCV hose.
Dan
The Light Grind
2010 2.0T Premium Silverstone Auto-Gone
2012 3.8 Track Tsukuba Red
Incurve IC-S5 powder-coated in Jungle Grey
Tein S-tek springs
M&S Type-D grill in Tsukuba red
M&S lip in Tsukuba red
Carbon fiber dual projector headlights
Sequence CF diffuser
Ark Grip V1 exhaust with burnt tips
RRM SRI powder-coated red
2013 tail lights
Happyface44r is offline
Why you NEED a catch-can Snoopy0812 2.0T Discussion 2008-2012 646 02-17-2019 06:08 AM
DIY Ultimate Racing 3" High Flow Cat + TXS GEN-RP 3" Downpipe Install *lots of pics* kepone 2.0T Discussion 2008-2012 54 03-03-2017 09:05 AM
More oil stuff...how I got lower temps and what I notice running redline oil (so far) Jesse Crabtree Engine 46 12-03-2016 11:05 AM
Godspeed 750ml Oil Catch Can Install Ryengoth 3.8 V6 Discussion 2013 and up 9 07-14-2014 09:43 PM
Shift Knob Threaded Insert Install DIY TWM Performance Interior 2 04-02-2013 04:41 PM
