DIY Oil Catch Can Install - Page 30 - Hyundai Genesis Forum
 2Likes
post #581 of 600 Old 08-02-2016 Thread Starter
Boost Addict
Projectx7's Avatar
Originally Posted by msmith87 View Post
I wanted to use this write up to install my catch cans but all the pictures are "broken." It seems like all of the older write ups have broken pictures. =( It doesn't matter what browser I use - Chrome or Firefox.
Super late response I know, but check out post 524 for a PDF of the install including all the original photos. Same goes for any of my other DIY's, I've added PDF's after I switched servers.
https://www.gencoupe.com/2305706-post524.html
Beyond Redline Tuned
Projectx7 is offline
post #582 of 600 Old 08-12-2016
I'm interested in this but it says "invalid page specified." Its a broken link for me.
msmith87 is offline
post #583 of 600 Old 08-12-2016
brucelee's Avatar
Quoted: 90 Post(s)
Try this one https://www.gencoupe.com/product-revi...lots-pics.html The video appears to be gone to me but there are still lots of pictures and the cans are really good for both generations of the GC.
2011 Premium Silverstone 2.0T > 2013 Premium Tsukuba Red 2.0T
Webshots http://community.webshots.com/user/bruclee
brucelee is offline
post #584 of 600 Old 08-13-2016
2015 3.8 GDI MT
Carlman's Avatar
Quoted: 53 Post(s)
I have a 3.8. I learned very little from Snoopys dual can install. It was much easier to figure out on my own. All I did was replace 1 little existing pipe with a catch can. I had to find a reducer from 1/2" to 3/8" since that's what the OEM part did. Otherwise, I bought some 3/8" fuel hose and put the inlet pipe to "in" and outlet pipe to "out". I mounted my can to my heat shield for an AEM intake.
The install took 30 minutes. Looks nice, works great.
Taking off the front bumper and all the other disassembly involved in that diy is way out there for me. There is no need in my opinion.
Carlman is offline
post #585 of 600 Old 08-13-2016
brucelee's Avatar
Quoted: 90 Post(s)
Ahh Snoppy's advice was mostly for the 2.0L Turbo since it keeps the crap out of the intake and intercooler more in the cooler weather conditions. I'm not sure what a catch can would do for a V6.
Bruce
brucelee is offline
post #586 of 600 Old 08-14-2016
inertiamonster's Avatar
Quoted: 670 Post(s)
On the V6 it catches a bunch of junk that the PCV line would otherwise send into the intake.
inertiamonster is online now
post #587 of 600 Old 08-14-2016
Cone Killa
Quoted: 148 Post(s)
Do you know where the PCV is located on a BK1 3.8? Also where on the intake is it hooked up to?
Is there any complete "plug and play" catch can solution for the BK1 3.8?
I've searched and haven't really found a conclusive answer.
Thanks.
ApexEight is offline
post #588 of 600 Old 08-14-2016
Quoted: 670 Post(s)
Same as the BK2, see my DIY here: https://www.gencoupe.com/engine-drive...n-install.html
No, there is not a plug and play solution for the 3.8 like the Snoopy cans for the 2.0T but there are a lot of options out there.
post #589 of 600 Old 12-04-2018
Irresponsible Rookie
rthorniley's Avatar
Quoted: 23 Post(s)
Pardon me if someone already answered this in the previous 30 pages...
But has anyone used a 3-port oil catch can and routed the PCV and CCV hoses to one catch can?
Would there be any issues with this?
Obviously I would have to use a "Y" hose joint on the outlet hose, which is not standard. But if its just air that is vented out there shouldn't be much issue, right?
Considering the mishimoto 3-port rather than two separate cans for my BK1 3.8.
2010 3.8 Track,
Konig Hypergram, Nitto NT05, Trans Mount, Engine Leash, Diff Bushings, Intake, Powerstop Track Pads, Braided Brake Lines, Tien Lowering Springs, CAI, Thermal Gaskets, Stripped
rthorniley is offline
post #590 of 600 Old 12-04-2018
You only need one can on NA engines, just the PCV valve side.
post #591 of 600 Old 12-04-2018
rthorniley's Avatar
Quoted: 23 Post(s)
Okay thanks well that makes it easier!
I was reading interiamonster 's write up on the DIY for the 3.8, which is why I thought both sides would be useful for track abuse.
2010 3.8 Track,
post #592 of 600 Old 12-04-2018
Unless you get oil in the pre TB intake track there is no need for it. The oil only gets blown out if the piston rings are bad on a NA engine.
post #593 of 600 Old 12-04-2018
rthorniley's Avatar
Quoted: 23 Post(s)
Gotcha, thanks Red.
I'll just run the PCV side for now and check for oil in the TB after a track day.
2010 3.8 Track,
post #594 of 600 Old 12-04-2018
Quoted: 670 Post(s)
I've never collected oil in the vent side can but mine is just a street car. If you track the car I would recommend the second can, another member that tracked his car (I forget his user name now but I think he is long inactive here) installed his cans at the same time as mine (same cans, similar install) and he would routinely pull several ounces of oil from the vent can.
2013 3.8 Track Pearl White
post #595 of 600 Old 12-04-2018
rthorniley's Avatar
Quoted: 23 Post(s)
Awesome thanks inertia
Yeah I saw a video of someone with a 3.8 who installed a can on the CCV side because he was getting oil in the intake, so that's what made me think it was necessary. I don't want to be sucking that stuff up in my intake.
Thinking outside the box here, but would the CCV side even need to be routed back to the intake?
The air pressure wouldn't be the same from the crankcase to the intake anyway.
2010 3.8 Track,
post #596 of 600 Old 12-04-2018
Quoted: 670 Post(s)
You could just put a breather on the vent but then those vapors will vent under the hood. The other option is to install a small oil separator inline with the vent hose, it won't have the capacity of a catch can but on daily driving it won't collect anything anyway and the install would be easier, you'd just have to check it frequently while at the track.
post #597 of 600 Old 12-04-2018
rthorniley's Avatar
Quoted: 23 Post(s)
Oh no that wasn't my plan.
Typically people route the crankcase to the catch can, and catch can to the intake.
I was thinking about routing the CCV to a catch can, and capping the intake connection.
Like follows:
Existing:
Crankcase ---------------------- Intake
Planned:
Crankcase ----- catch can. Intake(now separate)
(Period denotes end of system, dash denotes vent line). Sorry didn't have a picture handy
2010 3.8 Track,
post #598 of 600 Old 12-04-2018
Quoted: 670 Post(s)
Ah, yes you could connect it to a vented catch can and cap the intake.
rthorniley likes this.
post #599 of 600 Old 01-09-2019
rthorniley's Avatar
Quoted: 23 Post(s)
Update:
https://imgur.com/8jEo056
Found oil in my intake manifold. (This was without even running any track days, just spirited driving). So I did as I planned, routed the CCV to the catch can as well. Will upload photos tonight or tomorrow.
2010 3.8 Track,
post #600 of 600 Old 01-10-2019
rthorniley's Avatar
Quoted: 23 Post(s)
Here's my Mishimoto-style 3 port catch can installation.
It was a really simple and cheap idea, all in all under $40.
- The catch can, was just $25ish from eBay. I was actually really surprised with the quality, the aluminum felt sturdy and the baffle system was really similar to the real brand. The lid and o-ring construction gives an air tight seal. And you can rotate the top to point in whichever direction is best for you.
- 3/8 vacuum hose from auto parts store
- various vacuum hose caps
- 5/8 PCV/fuel hose from auto parts store
- various hose clamps
I needed to route the CCV to the catch can, because there was some oil residue in the intake tube (not pictured)
I needed route the PCV to the catch can, because I had oil in the intake manifold:
https://imgur.com/a/ML9G4kv
So I capped the intake line with a vacuum hose cap. And routed the CCV side (far right) to the catch-can inlet. Then routed the PCV side (under throttle body) to the other inlet. Then routed the catch-can outlet to the PCV inlet to the intake manifold (maybe I could have just capped this as well, but I didn't want to risk causing problems due to pressure differences).
https://imgur.com/a/fU7XKvj
Here's a better view of the PCV side. The can is mounted to a 90 degree strong tie, which is bolted to the left of the Pwr Steering reservoir to a stock mounting point. I believe the mounting point was from the stock intake system, which was replaced with a CAI.
https://imgur.com/a/xA1WlSV
2010 3.8 Track,
Why you NEED a catch-can Snoopy0812 2.0T Discussion 2008-2012 646 02-17-2019 06:08 AM
DIY Ultimate Racing 3" High Flow Cat + TXS GEN-RP 3" Downpipe Install *lots of pics* kepone 2.0T Discussion 2008-2012 54 03-03-2017 09:05 AM
More oil stuff...how I got lower temps and what I notice running redline oil (so far) Jesse Crabtree Engine 46 12-03-2016 11:05 AM
Godspeed 750ml Oil Catch Can Install Ryengoth 3.8 V6 Discussion 2013 and up 9 07-14-2014 09:43 PM
Shift Knob Threaded Insert Install DIY TWM Performance Interior 2 04-02-2013 04:41 PM
