DIY Oil Catch Can Install - Page 7 - Hyundai Genesis Forum
 2Likes
post #121 of 600 Old 04-08-2011
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 91 Post(s)
Cause it doesn't like you Will... it just doesn't like anyone anymore...
j/k.
Pic's don't show up for me either, probably the links went bad.
Just so you guys know, I was installing my Injen Cold-side intercooler pipe.. and it was coated with oil and the joints were filled with it.
A catch can is seriously one of the first things you should do. In a few weeks when my mechanic comes back we're going to pull the intercooler and flush it. The throttle plate also has some oil built up on it.
Snoopy0812 is offline
post #122 of 600 Old 04-09-2011
Will's GenCoupe's Avatar
j/k.
hahah funny some one's got jokes, but quick question doe it matter if i get the same CC for bothsides? i already got the one but after reading this topic a little further im defiently going to get another one for the passenger side. The one i have is an ebay one (of couse) with a screw in the bottom of it i guess for ez cleaning or w/e
2011 Mitsubishi Octane Blue Lancer Evolution X
Will's GenCoupe is offline
post #123 of 600 Old 04-09-2011
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 91 Post(s)
I have two ebay cans, one for each side and it doesn't seem to matter at all. Just don't put a catch can between your brake booster hose and the intake. Unless you have an A/T in that case you don't have to worry about it at all.
post #124 of 600 Old 04-09-2011
Well i go the one for right now i was wondering can i go ahead and install that one on the passenger side and just wait for the other one to come in for the driver side or will that f*** something up?
post #125 of 600 Old 04-09-2011
You can install either one. The drivers side is the one needed the most though.
post #126 of 600 Old 04-09-2011
Ok kool i'm going to do the driver side once the other one comes in i will just go ahead and do the passenger side one tomorrow, kinda hard to find this heater hose crap but i'l keep lookin i remember the passegner side i need an 1/2 piece as well as the regular 3/8 pieces.
post #127 of 600 Old 04-09-2011
Actually they are metric, 10mm and 13 mm for the best fit. Be sure to find some way to adapt the 1/2" hose to the can. And get some good hose clamps.
post #128 of 600 Old 04-09-2011
What do you mean? isnt that like a conversion tip or somethig i can use...?
post #129 of 600 Old 04-09-2011
I don't know. Mine did not have anything. The problem is two 1/2" hoses side by side is a tight fit on the eBay ones I got. I used a thin piece of 3/8" clear hose that I then slipped the 1/2" hose over on the nipple. I cut the clear hose just long enough to fit over the entire 3/8" nipple.
post #130 of 600 Old 04-09-2011
so you have the 3/8 feeding the 1/2 hose?
post #131 of 600 Old 04-09-2011
No the 3/8 hose is completely inside the 1/2" hose. Here's a pic.
post #132 of 600 Old 04-09-2011
ok yea i think i got it the only hose that fits that nipple is the 3/8 so by placing the 3/8 on that nipple and sliding it inside the 1/2 its almost as if you have the 1/2 on the nipple instead of the 3/8's right?
post #133 of 600 Old 04-09-2011
You got it.
post #134 of 600 Old 04-11-2011
ok so looking in the bag i don't see a reducer in here i got everything it seems but i do have some blue looking piece one side is open the other side is closed.... I don't think it even came with one, what size do i need and where would i find something like that? Do i even need a reducer?
post #135 of 600 Old 04-11-2011
show us what you gots.....
post #136 of 600 Old 04-11-2011
^not very creative.
Tsukuba Coupe's Avatar
well since the pics didnt show up my friend and I did it our own way...
got the same catch can, however we just use the blue hose it came with instead of buying heater hose. we plugged the hose on the IM and ran the blue hose from the other one to the catch can which we mounted on an existing hole from the stock intake box (gotta have an aftermarket intake that doesn't have a box for this) then just ran the stock hose we took off from the CC down towards the wall so it goes no where. it's not exactly necessary to have the hose go into the cc and back into the IM so we did it this way... I'll take some pics later and post them up too. it will be easier to follow lol.
2010 Tsukuba 2.0T M/T
|ARK Performance|Competition Clutch|Injen|AEM|UTUNE|Prodigy Lip|TURBOSMART|TWM Performance|
www.YouTube.com/user/TsukubaCoupe
Tsukuba Coupe is offline
post #137 of 600 Old 04-11-2011
SoCalturbo's Avatar
are you talking about the turbo side or the intake manifold side?
on the intake manifold you need to use both lines to run it back into the pcv valve.
As for the turbo side, you dont need to run both lines.
SoCalturbo is offline
post #138 of 600 Old 04-11-2011
cowcow's Avatar
Quoted: 41 Post(s)
Is heater hose the right product for the application? I've read online that it can't be used if there's any oil/gas as the rubber will basically be eaten away.
cowcow is offline
post #139 of 600 Old 04-11-2011
^not very creative.
intake manifold side. we just blocked off the one going into the IM. my friend says it's not necessary since it's just putting fumes back into the IM so we just let them out in the atmosphere. it should be even cleaner.
post #140 of 600 Old 04-11-2011
I use fuel line hose.
Why you NEED a catch-can Snoopy0812 2.0T Discussion 2008-2012 646 02-17-2019 06:08 AM
DIY Ultimate Racing 3" High Flow Cat + TXS GEN-RP 3" Downpipe Install *lots of pics* kepone 2.0T Discussion 2008-2012 54 03-03-2017 09:05 AM
More oil stuff...how I got lower temps and what I notice running redline oil (so far) Jesse Crabtree Engine 46 12-03-2016 11:05 AM
Godspeed 750ml Oil Catch Can Install Ryengoth 3.8 V6 Discussion 2013 and up 9 07-14-2014 09:43 PM
Shift Knob Threaded Insert Install DIY TWM Performance Interior 2 04-02-2013 04:41 PM
