DIY Oil Catch Can Install - Hyundai Genesis Forum
 2Likes
post #1 of 600 Old 03-18-2010 Thread Starter
Boost Addict
Projectx7's Avatar
Disclaimer:
As with any DIY you assume full responsibility for what you do to your car and I am in no way liable for any damage that happens. In other wards do this DYI at your own risk.
Car: 2010 Genesis coupe R-Spec Edition
For all of my DIY the car model and trim will be a 2010 Genesis coupe R-Spec Edition most trims will be the same for most aspects but there is the possibility that things can be different on your trim vehicle that may require altering the DIY steps ect.
Materials:
Catch Can
Breather Filter
2-4 Feet of heater Hose [3/8" ID (Inner Diameter)]
Vacuum Cap
Self Tapping Screws
Tools:
Socket Wrench
-7MM
-10MM
Allen Keys (metric)
- Number 5
Pliers
Cutting Utensil
Drill
Philips Head Screw Driver
Notes:
In this DIY I installed a universal ebay catch can that can be found for about $20 shipped.
Oil Catch Can = CC
Install:
Part 1: Setting up your catch can
1) Lay out all the parts for your CC and look for the set of gaskets that they give you. What you first must do is remove the two nipples off the top and apply those gaskets to the bottom of the nipple so that they seal properly against the metal.
2) Now re-install them and make sure the two top nipples are on securely and the drain plug on the bottom is in securely. Find the two brackets they give you for installation and attach the ring clamp over the bracket that goes to the CC and tighten, then use the supplied screws to secure the other L bracket to the mount. It should look like the below picture and this is just temporary until you find how you wish to mount it.
3) Attach the two heater hoses to the nipples of the CC and use the supplied clamps to tighten the hose on.
4) On one of the hoses you must install a reducer which is supplied in the box so what you do is cut a piece of the supplied hose, blue in my case, and attach it to one side of the reducer then on the other side attach it into the heater hose. Use the supplied clamps to tighten up the hoses to the reducer. Now you’re ready for the next step!
Part 2: Mounting your Catch Can
1) This will obviously vary for everyone else but i found the easiest spot to mount the CC was by the driver’s side headlight since there is plenty of room there to install the CC.
2) First see around where you want to mount your catch can try to make it at the highest degree possible so the catch can is as vertical as can be.
3) Now once your satisfied use your drill and the self tapping screws and install the first bracket to the frame of the engine bay.
4) Next secure the other part of the bracket with the supplied screws so that the lip that gets clamped on to the CC is readily exposed so you can easily attach and remove the CC.
5) Now finally rest the catch can on the bracket and tighten the clamp so that the catch can is secured onto the bracket. Now for the final step
Part 3: Running the Lines
1) First, you must remove the line that goes from your valve case to the PCV valve on the intake manifold on the driver’s side of the car.
2) Now that you have removed this line the first line from the catch can without the reducer will be plugged into the PCV valve and tighten with a clamp.
3) The other line will now be hooked up to the valve case this is the one with the reducer and secure it using the factory clamp since i ran out of adjustable clamps.
Now that you have finished steps 3 and 4 the lines should look like this
4) Now the next line you must remove is the line that runs from the valve case to the intake on the passengers side.
5) Now that that line is removed you must attach the breather to the valve case and tighten that down.
6) Next use the vacuum caps and slip it over the tube on the intake.
Finalizing Installation:
Now as always tidy up your installation and make sure everything is secure and tight and start her up and make sure she’s running normally. This is how everything will look with the CC installed.
Well, thats it everyone hopefully this helps you and if you have any questions as always just let me know!
Beyond Redline Tuned
Projectx7 is offline
post #2 of 600 Old 03-18-2010
mmmmmmmmatte black
jules@invision's Avatar
A+
i'll end up with one of these sooner or later too hah
post #3 of 600 Old 03-18-2010
Token Metro Guy
brandon1987's Avatar
I stuck-ted your thread.
--CurrentCar--
(Canadian Spec)
Carbon Filter Removed - 7000K High Beams/DRLs - 20% Tint - M&S Type D Grille - Black Vinyl Roof Overlay - Carbon Wrapped Console - BBM Lip Spoiler
--Previous Cars--
2005 Acura RSX Premium
2000 BMW 323i
1988 Toyota Supra Turbo
brandon1987 is offline
post #4 of 600 Old 03-18-2010
特味! 특미 special flavah!
eclee's Avatar
As i expected~~ ^^ NICE~~~ !! I'm gonna do this tomorrow~~
where can i get these???
2-4 Feet of heater Hose ( size???)( home depot)
Vacuum Cap
Self Tapping Screws( home depot)
Nord Grey 2.0T-> dead...
Waiting for 2012 gencoupe.....
eclee is offline
post #5 of 600 Old 03-18-2010 Thread Starter
Boost Addict
Projectx7's Avatar
Sorry i forgot to add it in it has a 11mm ID (Inner Diameter)
All these parts you can get at your local auto store
post #6 of 600 Old 03-18-2010
cowcow's Avatar
Quoted: 41 Post(s)
Very nice DIY. Will be the first thing i do when i get my car.
cowcow is offline
post #7 of 600 Old 03-19-2010
cosmith's Avatar
Nice, looks almost exactly like the way I did it, except I used a silver can and filter to go with the black car.
I'm watching that filter. If it starts making a mess I may replace it with another catch can.
Great write up!
--Colin
2010 Genesis Coupe 2.0 Premium A/T w/Navigation Bathurst Black
cosmith is offline
post #8 of 600 Old 03-19-2010
「まんがをえがきます!」
123noob's Avatar
What does this thing do? catching spilled oil?
123noob is offline
post #9 of 600 Old 03-19-2010
cosmith's Avatar
It collects oil and water from the PCV gasses before they are re-circulated. It prevents them from accumulating in the intercooler.
--Colin
cosmith is offline
post #10 of 600 Old 03-19-2010
don1dada's Avatar
is this necessary on cars with sri?
don1dada is offline
post #11 of 600 Old 03-19-2010
Sex Machine
Spool2Go's Avatar
its necessary for any turbocharged car and it will help prolong ur turbo
Genesis Coupe 2.0T GT MIRABEAU BLUE
BR Reflash w/custom tune|DW 550cc Injectors|CP-E Downpipe w/Hi-Flow Cat & 3" Mid-Pipe|Depo Racing FMIC|G&M SRI|HKS BOV w/Block-off plate|NRG Ground Wire Kit|PTP Turbo Blanket|Eibach Sportlines|R1 Drilled/Slotted Rotors|SS Brake/Clutch Lines|Frixa Brake Pads|19" Bronze 5Axis S5:F Rims|Meaty Continental Tires|ACT Clutch w/ Fidanza Flywheel|
Dynoed 262whp & 282wtq @ 17psi on the Mustang Dyno
Spool2Go is offline
post #12 of 600 Old 03-19-2010
FortyOzSpartan's Avatar
Very nice write-up, I'll probably do this at some point using your how-to.
2010 2.0T Genesis Coupe
-U.S. Premium
-32% tint
-cp-e αIntake
FortyOzSpartan is offline
post #13 of 600 Old 03-19-2010
BIG BOOST POP
Cold71's Avatar
very nice write up, i've already ordered my CC. I'll be putting it on with my intake and flash.
2010 Hyundai Genesis Coupe 2.0T
*Installed*
HKS catback exhaust
AEM cold air intake (exceladyne stage 1)
Power Axel tune (exceladyne stage 1)
Recorded 0-60 time: 5.22 seconds
Best 1/4 Mile: 14.26 @ 96mph
Cold71 is offline
post #14 of 600 Old 03-19-2010
don1dada's Avatar
If this is a necessary part for a turbo charged car then why doesn't the manufacture have it built in already?
don1dada is offline
post #15 of 600 Old 03-19-2010
Because the EPA would not allow it.
post #16 of 600 Old 03-20-2010
traction control off =]
cant_stop_spinning's Avatar
nice write up! thanks!!!
for those who dont know, google is your friend. catch cans arent anything new, look it up!!!
"I downshift next to hybrids so they can hear me killing the enviroment "
-Beyond Redline Stage 3
cant_stop_spinning is offline
post #17 of 600 Old 03-20-2010
BIG BOOST POP
Cold71's Avatar
Just got back from the auto store, heads up for anyone in the US. Your not going to find 11mm ID heater hose. I asked and the guy looked at me like I was nuts. Your going to use half inch ID, which is only about 1.7mm larger so you'll be ok.
*Installed*
HKS catback exhaust
Cold71 is offline
post #18 of 600 Old 03-20-2010
eclee's Avatar
LOL I had the same situation at the advanced auto ~ LOL
i asked them for ID 11mm heater hose and he is like ... "we don't sell those...- - ;" we only sell 1/2, 3/8, ..and something..... i was ok.... I'll go check out NAPA. ..- - ;
So i need to get 1/2 heater hose right??? any luck on vaccum cap and self tap screw?
eclee is offline
post #19 of 600 Old 03-20-2010
No you need 3/8" fuel line hose. You measure hose by the inside diameter. The fitting on the actual PCV valve is 8mm and the fitting on the plastic fitting on the intake is ~12 mm. 3/8" hose will work with good clamps but you need a short piece of 1/2" for the intake end to use with one of the included reducers.
I bought one of those cans and put it in today. I am getting another for the other side too instead of the filter.
I mounted mine of the fuse box bracket. Had to notch out some of the plastic.
post #20 of 600 Old 03-20-2010
eclee's Avatar
red raspberry can you put another picture of your intake place? I wanna see how you did it on that area.
eclee is offline
Why you NEED a catch-can Snoopy0812 2.0T Discussion 2008-2012 646 02-17-2019 06:08 AM
DIY Ultimate Racing 3" High Flow Cat + TXS GEN-RP 3" Downpipe Install *lots of pics* kepone 2.0T Discussion 2008-2012 54 03-03-2017 09:05 AM
More oil stuff...how I got lower temps and what I notice running redline oil (so far) Jesse Crabtree Engine 46 12-03-2016 11:05 AM
Godspeed 750ml Oil Catch Can Install Ryengoth 3.8 V6 Discussion 2013 and up 9 07-14-2014 09:43 PM
Shift Knob Threaded Insert Install DIY TWM Performance Interior 2 04-02-2013 04:41 PM
