Coolant Flush DIY Video Guide - Hyundai Genesis Forum
post #1 of 4 Old 06-21-2019 Thread Starter
hdebnath's Avatar
Simple drain and fill antifreeze procedure for all gencoupes!
I was able to get about 1 gallon (3.78 L) out from the radiator plus an additional 0.5 L was added to the reservoir so overall 4.3 L was exchanged.
Don't forget to add distilled to the reservoir then remove it after. Also close the purge line when idling with heat/fan on!
Gencoupe Mod and Maintenance YOUTUBE CHANNEL:
https://www.youtube.com/c/gatlinskarX/videos
hdebnath is offline
post #2 of 4 Old 07-26-2019
gen10-38's Avatar
Quoted: 38 Post(s)
Do you know which hose on the 3.8 bk1, on/near intake plenum, you gotta undo to purge air from the coolant system? Can really use a picture with it identified. Pretty sure mine has a air pocket since I flushed it since the heater doesnt get as hot as it used to.
2010 Genesis Coupe GT 3.8 Auto
gen10-38 is offline
post #3 of 4 Old 07-27-2019
As long as there are no leaks and your radiator cap is good the system will self bleed any air out. Takes a few cooling heat cycles and you should check the radiator when it's cold to top off.
post #4 of 4 Old 07-27-2019
In Charge of Snacks
Odelagt's Avatar
Quoted: 239 Post(s)
This reminds me that I need to order new rad hoses and heater lines before I install my new radiator. LOL, SOOOO MANY PARTS!
'11 3.8 R-spec
Odelagt is offline
