Oil catch can install 2014 2.0t - Hyundai Genesis Forum
post #1 of 12 Old 2 Weeks Ago Thread Starter
Hi guys I’m new here I’m considering with everything I’ve been reading on catch cans to install one. I was just wondering what’s the best way of doing so I want to do it on the turbo side I know to run the breather tube to the catch can but do I run another tube from intake to the catch can too?
Penguinator29 is offline
post #2 of 12 Old 2 Weeks Ago Thread Starter
post #3 of 12 Old 2 Weeks Ago
The sight tubes are worthless. I take mine out and plug the holes. They just get all dark and you can't see anything through the tubing. This one does have a drain plug. Most you need to take the bottom of the can off to drain. With a drain plug you can add a hose and extend it to a convenient location for easy draining at oil change time. I just have the hose tucked up in front of the tire behind the plastic.
Many want to pay big bucks but they all do the same thing. I use cheap ones form ebay.
post #4 of 12 Old 2 Weeks Ago Thread Starter
Essentially you just take the smaller hose that goes to the intake piping and put it in the catch can and then put a hose on the intake where the hose was before and hook it up to the catch can tooo??? And is it really necessary to have one for now I just plan on a sri and axle back [/QUOTE]
post #5 of 12 Old 2 Weeks Ago
Yes they, if using 2, just go inline of the existing hose. No they are not necessary.
post #6 of 12 Old 2 Weeks Ago Thread Starter
Okay I might get one in the future just didn’t know if it was a must have for it I’m trying my best to keep everything maintained well
post #7 of 12 Old 2 Weeks Ago
Well if you want to maintain it the best then you need one.
post #8 of 12 Old 2 Weeks Ago Thread Starter
Just ordered the one I put in the link on here along with Teflon tape 1/2” and 3/8” hoses
post #9 of 12 Old 2 Weeks Ago
On my cans that use 3/8" barbs...
The 3/8" fits the PCV valve but the Intake barb is 1/2". Metric really. A 3/8" hose should slip inside a 1/2" hose and then all that is needed is a hose clamp. The turbo side, IIRC, the valve cover barb is closer to 7/16".
post #10 of 12 Old 2 Weeks Ago Thread Starter
Should I get a 7/16 hose to be safe or should I be all set?
post #11 of 12 Old 1 Week Ago
Dropping Knowledge
GenCoupeBoricua's Avatar
Quoted: 27 Post(s)
If the catch can is properly baffled then it should be fine. I personally am not a fan of all the generic made ebay ones. As for installation there a few write ups on this very forum on how to install it. Nothing has changed in that aspect.
2011 Hyundai Genesis Coupe
Mods
A shitload
GenCoupeBoricua is offline
post #12 of 12 Old 1 Week Ago
The two biggest factors with a catch can are Low and Cold. Low for gravity drain and cold for hot gaseous condensation.
