Hyundai Genesis Short Shifter Install DIY - Page 2 - Hyundai Genesis Forum
post #21 of 34 Old 08-22-2012
The one the only
obeezy85's Avatar
info on lugs and if they fit on stock 19's and stock lugs thread.
GenSport Carolina's Founding Member
http://thenewgensport.wix.com/gensport#!home/mainPage
JERSEY CITY
MODS way to many to list for here
2010 NORD 2.0T TRACK
Notable cars:
1985 Toyota Corrola GTS Silver RWD Drift
obeezy85 is offline
post #22 of 34 Old 09-16-2012
Thanks for these instructions. I bought a different brand (because honestly I don't care about the vibration damper or spending an extra $100 for it, just personal preference) and ended up using these instructions to do the job. This was my first time under a car (I've never even changed my own oil), so it was an educational experience.
The only thing that was different than the instructions for me was one of the bolts holding the shifter in was the advertised 10mm, but the other was 11mm. I think this might have just been a mistake on my particular car, since that doesn't really make any sense.
Post-install I've driven about 40 miles, and everything seems solid. I pinched my thumb a couple times shifting into reverse, so I guess I ought to stop putting my thumb on the left side
A couple other notes on the install:
-The job would have only taken about 90 minutes, but I got carried away and accidentally unbolted the 12mm bolts holding the shifter assembly in place. Those were really not fun to put back in, so don't do what I did
-I was able to do this in 2 hours: I didn't unhook the exhaust or drive-train, used jack stands,worked in the dark, and used a flashlight. It was kind of a pain to reach the bolts and tighten them properly this way, so I wouldn't recommend doing it this way unless you have some decent arm strength.
-The heat shield has SHARP edges. Holy crap.
-Because I didn't unhook the exhaust one of the 10mm bolts holding the shift lever in place was REALLY hard to reach. Not impossible, just a pain.
-Don't forget to put some anti-seize grease on the heat shield bolts before you put it back on.
-Tools/materials I used: jack stands, regular socket wrench w/ extender, 10mm & 11mm sockets (my shift lever's nut & bolt were 10mm), socket driver + vicegrips to get to one of the bolts that was blocked by the exhaust pipe (don't make fun of me! ).
-Learned the hard way not to use a socket wrench directly above your head It bit me right in the nose.
twodave is offline
post #23 of 34 Old 09-16-2012
Projekt Soju
Flipp's Avatar
lol^ good stuff.
ive done the install on the lift and on the ground with jack stands. really helps is you use a small ratchet with a swivel head and a short extension and flex joint. =]
Exhaust gases go into the turbocharger and spin it, witchcraft happens, and you go faster. -Jeremy Clarkson
https://www.gencoupe.com/media/101301-flipps-whip-projekt-soju.html
Companies/Vendors i vouche for. Best Customer Service and all around good people:
SFR, TurboXS, InvisionAutomotion, PRW, SixSpeedGraphix, MAP, R1 Concepts
Flipp is offline
post #24 of 34 Old 09-17-2012 Thread Starter
Get your TWM Performance Weighted Shift Knobs TODAY!
Shift Knobs - TWM Performance Shift Knob Store
PM ME FOR PRICING!
Renato
Team TWM Performance
TWM Performance is offline
post #25 of 34 Old 09-17-2012
thanks for the DIY, ill be placing an order in November some time. What a great product had their shifter for my previous car. Now time to buy again soon for my gen.
genKoopa is offline
post #26 of 34 Old 09-18-2012 Thread Starter
Great to hear buddy! Come support the cause, GOD SAVE THE MANUALS!
JOIN US on our crusade to SAVE THE MANUALS!
**PM ME for PRICING!**
Renato
post #27 of 34 Old 04-07-2014
SSPlayer1's Avatar
Nice write up, I just my 14 model 2T premium, and was looking and doing this install, just worried about the stock boot, I don't see any snap point like in your pic, anyone know how to take off the boot on a 13/14 model
2014 Genesis Coupe 2.0T Premium
Ibiza Blue
, Hyundai Performance exhaust
Extreme Dimensions RS-1 Rear Wing, Injen RAI
H&R Sport Springs, 20mm and 25mm wheel spacers
ARK Strut Tower Brace, GCTuner HID Kit
ATQ Short Throw Shifter
SSPlayer1 is offline
post #28 of 34 Old 04-11-2014
Guest
There are some threads about how to take our boots off. The clips holding the boot are on the inside. I've read some people just twist counter clockwise and up, and they snap right off. Others say to take the plastic console piece off first and lift the boot upwards to reach the clips. I haven't taken mine off yet so I couldn't tell you which one worked for me.
Great wright up BTW!
13White2.0T is offline
post #29 of 34 Old 04-24-2014
gendrvr93727's Avatar
I have a 2013 track model... Do I unbolt the cats and back? 3.8 v6... Nvm did it without taking apart the exhaust...
2013 Genesis Coupe 3.8 Track
Platinum Silver
Mods:
Injen Intake
30000k hid bulb replacement in the headlights
12000k hid kit in the fog lights
Blue LED Dome Lights
Blue Footwell LEDS
Winged badges
Tint all the way around
Injen Intake
GarageLine Short Throw shifter
20 MM Garageline spacers front, 25mm in rear
Lowered on eibach sportlines
20x10 rims wrapped in 245 35 R20 Tires
Custom xpipe and true Dual magnaflow exhaust
gendrvr93727 is offline
post #30 of 34 Old 06-12-2014
Genesis Coupe RSpec 2013
GenRSpec13's Avatar
I wasn't able to get that rubber boot underneath back on... man I tried and tried, knuckles all scrapped to ishh.... finally just gave up and left it there. Checked when I was installing my exhaust and it didn't have water or anything in it, which was my fear.
GenRSpec13 is offline
post #31 of 34 Old 10-16-2015
Dark_Coupe's Avatar
Thanks for the write up. Installed a short throw today and it probably halved the amount of time it would have taken me. And GenRSpec13 that boot was the worst part of the installation. Luckily I have skinny fingers and finally got it back on but what a PITA!
Dark_Coupe is offline
post #32 of 34 Old 10-16-2016
Dreamcar's Avatar
Quoted: 15 Post(s)
Thanks for the DIY. I don't know what the deal was, maybe they changed some design slightly for 2015 but I could not get that pin out that held the shifter to the linkage. I tugged and pulled and hammered and eventually gave up after half the day slipped by. With that being said, I have the stock shifter installed and will be selling my ATQ SS with rear bushings as I can't be hassled to attempt that installation again. Jeesh...
15 3.8 Ultimate
BC Racing BR Series Coilovers
ISR Street Catback Exhaust
Ark Performance Test Pipes
Megan Racing Transmission Mount
Injen Short Ram Intake
De-badged Rear
Winged Badges
18% Tint
YouTube Channel
www.youtube.com/channel/UC2aBf6moBKl06_i1H3uDgJg[/SIZE]
Dreamcar is offline
post #33 of 34 Old 08-24-2018
I had the same problem with the shifter pin on my 2014 2.0T. I tried prying it out, pushing it out, and using pliers but the pin would not budge.
normanchen5 is offline
post #34 of 34 Old 08-26-2018
Joe-Shmoe
Ronin's Avatar
wow... that seller is banned?
Karussell White 2.0GT Coupe
  • CP-E Intake
  • TWM short shifter + TiC shifter bushing
Ronin is offline
The FINAL Official 2013 Genesis Coupe Thread N2OInferno General Discussion 2576 12-17-2018 01:49 PM
ISIS Stainless Shorty Clutch Line DIY Installation - Hyundai Genesis Coupe 09+ FrankenRob Engine and Drivetrain 5 05-05-2014 07:25 PM
TWM Short Throw Shifter Kit Review KrazyKen Product reviews 12 01-26-2014 03:00 AM
