DIY: transmission fluid drain and fill - Page 7 - Hyundai Genesis Forum
 14Likes
post #121 of 128 Old 03-09-2018
32oz bottles, so I need 2 of those?
jfondell is offline
post #122 of 128 Old 03-09-2018
Yes though you will not get the whole two bottles in. I would consider doing a flush too. So 4 bottles for that.
post #123 of 128 Old 03-09-2018
ok Thanks
jfondell is offline
post #124 of 128 Old 03-16-2018
Quoted: 16 Post(s)
The mineral spirit flush is the best suggestion so far.
The original fluid, that gave the problems, needs to be removed rather than left in to contaminate the new.
There are a bazillion tiny spaces in a tranny that will hold on to the original oil.
Cleanliness is next to godliness.
BBCMHG is offline
post #125 of 128 Old 03-16-2018
When I did my MS flush I filled it to the overflow. Then with it jacked up and level ran it through all the gears at idle several times. Then left the drain open overnight. No way was that ugly green lightweight shockproof coming out otherwise. I had done a fill with Redline MTL and when i went to change that at a couple thousand miles it was as green as the original shockproof.
post #126 of 128 Old 08-10-2018
Transmission Fluid
I need you guy helps, My Genesis Coupe 3.8 Track 2011 recently hit something and my transmission fluid is leaking, and when I put into gear it won't run. Do I change the transmission fluid filter and which type should I buy ? and which transmission fluid would fit my gen ? If you guy could help me please, I really appreciated. Thank You
vboy73 is offline
post #127 of 128 Old 08-10-2018
Quoted: 114 Post(s)
Logic dictates if you hit something and not fluid is leaking, there is physical damage done that needs to be repaired. Changing the fluid and filter to try and remedy that is like saying I broke my leg, should I get some new blood to fix it?
Lethal1ty17 is offline
post #128 of 128 Old 08-10-2018
Quoted: 114 Post(s)
Logic dictates if you hit something and now fluid is leaking, there is physical damage done that needs to be repaired. Changing the fluid and filter to try and remedy that is like saying I broke my leg, should I get some new blood to fix it?
Transmission Fluid GCkid Drivetrain 33 01-05-2019 05:14 AM
Which Redline Transmission Fluid? slade7588 Drivetrain 27 09-25-2011 11:11 AM
has anyone attempted a ZF transmission drain/fill? (track usage) vox Drivetrain 5 06-29-2011 10:06 PM
Transmission Oil Drain Crush Washer HellBilly Drivetrain 11 12-19-2010 10:42 AM
Transmission Fluid? meatsicle Drivetrain 13 02-20-2010 09:37 PM
