Trunk emblems - glued? - Hyundai Genesis Forum
post #1 of 12 Old 10-02-2019 Thread Starter
Sweden's Avatar
Quoted: 11 Post(s)
I´ve changed the badge in the middle of the trunk from Hyundai-badge to the black wings instead.
How are the other - "Coupé" and "3.8" - emblems attached? Only glue?
*if it has wheels or boobs, it will cost you*
Sweden is offline
post #2 of 12 Old 10-02-2019
Gaijinn's Avatar
Quoted: 241 Post(s)
I used minute gasket. Great adhesion, but can be pulled cleanly off if necessary.
Here we go again !
Gaijinn is offline
post #3 of 12 Old 10-02-2019 Thread Starter
Sweden's Avatar
Quoted: 11 Post(s)
- Yes, but are the emblems attached by glue from stock? I want to remove them, but must know so there are no screws or other attatchmens to the trunk.
Sweden is offline
post #4 of 12 Old 10-02-2019
On my 2010 the trunk H emblem had some quick push nut on the back. I had to glue it back on as I think the pins broke off.I need to take it off and paint it again.
post #5 of 12 Old 10-02-2019 Thread Starter
Sweden's Avatar
Quoted: 11 Post(s)
- I know about that emblem. Have already replaced that one with the wings.
But the other ones on the trunk, are they only held by glue?
Sweden is offline
post #6 of 12 Old 10-02-2019
Use some dental floss to try and 'saw' it off? If it's just sticky tape it will cut it off but if it's pins it won't.
post #7 of 12 Old 10-02-2019
NOOB
Thraxbert's Avatar
Quoted: 42 Post(s)
The 3.8 and "Coupe" emblems are secured via adhesive. Dental floss, goof off, alcohol, and a hair dryer will help you remove them. They are not glued. But the adhesive is quite resilient.
2013 Grand Touring 3.8: 3p8p True CAI | ISR Single Exit | 3p8p Manifold Riser | TROS Potent Boster 2 | 3p8p Engine Leash | Saikou Michi | Klutch KM20 | Whiteline Sways | Parts Shop MAX Comp Coilovers | Moog & Powergrid Links | Brembo Swap | Android Auto
Thraxbert is offline
post #8 of 12 Old 10-02-2019
Quoted: 746 Post(s)
The oem decals are held on by 3M double sided foam tape.
wrap the ends of some string on something to be used as handles, get the string under the decals and start pulling.
It will either cut the foam, then you clean it up later; or pull the adhesive part away.
Ammonia will break down the adhesive, so you can use something like windex to clean it up or loosed some of the adhesive before pulling.
post #9 of 12 Old 10-02-2019
Gaijinn's Avatar
Quoted: 241 Post(s)
Mine had bolts/screws from the trunk. I removed them prior to my trunk getting painted Chameleon.Mines a 2013. Same for the front. Lost the H badges, put on Genesis wings.
Here we go again !
Gaijinn is offline
post #10 of 12 Old 10-02-2019 Thread Starter
Sweden's Avatar
Quoted: 11 Post(s)
- I have already replaced the "H" from the middle of the trunk as i said in the first post of this thread : ))
"I´ve changed the badge in the middle of the trunk from Hyundai-badge to the black wings instead.
How are the other - "Coupé" and "3.8" - emblems attached? Only glue?"
I´m asking about the other emblems on the back of the trunk.
Sweden is offline
post #11 of 12 Old 10-03-2019
Gaijinn's Avatar
Quoted: 241 Post(s)
I did mine after re-painting.
They are glue only, the emblems are a chromed plastic with body kit adhesive foam padding. You will be able to source and purchase their replacements through any body shop supply. I re mounted the 3.8 added a neo chrome "Turbo" and re-used the Genesis.
Here we go again !
Gaijinn is offline
post #12 of 12 Old 10-04-2019
fydo's Avatar
I parked my car with the trunk facing the sun for an hour. Then just popped them off with my thumb nail. No residue at all.
I'll give up my clutch pedal when they pry it off my cold dead left foot.
fydo is offline
