DIY Bumper Quick Release for Under $20 - Hyundai Genesis Forum
post #1 of 51 Old 05-13-2014 Thread Starter
Zosyn who?
cleangencoupe's Avatar
So first of all, the whole reason I came up with this idea was so that fellow gencoupe owners wouldnt have to spend anywhere over $20 just for some quick releases like those from Quick Latch or from this other company that is selling theirs for $175. So i said screw it and came up with this.
Here's a List of what is needed for this DIY:
(1)Dunlop Dual Design StrapLoks. I believe they only come in silver,gold,brass,and black. If you decide to pick them up in store, mention that they are cheaper on their website and they will price match.
Dunlop Dual-Design Straplok System | GuitarCenter
(1) bag of #6 washers from Home Depot or your local hardware store
(1) #6-32 screws with nuts. (I recommend getting 1 inch screws and a bag of nuts seperate) The ones i used were too long.
(1) pack of 5/16 washers. I think you may be able to buy these seperate. 2 washers will be all you need.
Heres the reciept from Home Depot:
So in TOTAL i spent
$14.49 + $3.64= $18.13
Wayyyyyy cheaper than other places. So anyways on to the instructions.
First, you can either remove you wheel to have more room to work in or do what i did and turn the wheel in the opposite direction in which you are working on.
Next remove the tabs under the bumper that are holding your fender liner.
Remove #1 screw and from here you should be able to pull you bumper out from the tabs or in my case, it was already broken and loose.
Once you pop the bumper out, remove screw #2
I used a big nail to try to mark my drill point on the inside. It is pictured above where the #2 screw should be.
So basically what you do is you hold the nail from the inside and press on the outside of the bumper so that the nail pokes it a bit. Heres a blurry pic.
I used a step drill from the inside to start my hole then drilled from the outside. Make sure u keep measuring with the part. The hole size should be 13/32.
Here's the way the parts will go in order. Anything that is not pictured that came with the locks will not be used.
Start by setting up the outside part of the lock first.
Once the locking pin is in, youre all set with the outside.
Now for the inside.
Start the setup with this:
Make sure its tightened up.
Place it in the hole where #2 screw should be.
Now place a washer and nut on the inside part of the screw and tighten. Double check to make sure its lining up straight.
Push the fender liner back in place and put the tabs back under the bumper.
That should be it. Pretty simple. Here's a video of the test after the installation:
I still need to install the passenger side. Ill try to come up with a template so that you dont have to use the whole NAIL part.
Let me know what you guys think! Thanks!
SOLD
2011 Genesis Coupe Base 2.0T
BROWN Leather Interior w/ Matching Shift Boot
OEM K-White Lip Spoiler
Eibach Front and Rear Sway Bars
System Upgrade/SFR Short Throw Shifter
GlowShift 50mm Boost Gauge
Type B Bezel w/ Magellan 9055LM navi
K&N Typhoon Intake
HKS SSQV4 BOV
CP-E Tow Plate
CURRENT VEHICLE:
2007 Crown Victoria P71 Detective Unit
cleangencoupe is offline
post #2 of 51 Old 05-13-2014
Paps511's Avatar
Quoted: 44 Post(s)
nice
Blue 2015 Mazda 3 iSport
6sp Manual
Black 2011 2.0T R-Spec
GT3071R
392whp @ 21#
Paps511 is offline
post #3 of 51 Old 05-13-2014
unce unce unce
D!RTYLOUD's Avatar
Quoted: 80 Post(s)
[email protected]#K yeah!! 10x better than anything in the market.
https://www.gencoupe.com/2-0t-discuss...-pictures.html
D!RTYLOUD is offline
post #4 of 51 Old 05-13-2014 Thread Starter
Zosyn who?
damn my fingers were dry lol
SOLD
K&N Typhoon Intake
HKS SSQV4 BOV
CP-E Tow Plate
CURRENT VEHICLE:
post #5 of 51 Old 05-13-2014
FS section ravager
dwjp90's Avatar
Video of the quick release in action?
2013 Gran Preimo Grey 2.0T R-spec
Girlfriend named 'her' Jenifer
Guess I'm a mod now.
dwjp90 is offline
post #6 of 51 Old 05-13-2014 Thread Starter
Zosyn who?
its posted up there but heres a link
02A07703-5344-41FC-8FF3-ACDE035C6B16.mp4 Video by twentytwocpb | Photobucket
SOLD
K&N Typhoon Intake
HKS SSQV4 BOV
CP-E Tow Plate
CURRENT VEHICLE:
post #7 of 51 Old 05-13-2014
FS section ravager
dwjp90's Avatar
Omg, i thought you seriously took a selfie pic.... didn't realize it was a video link.
dwjp90 is offline
post #8 of 51 Old 05-13-2014
SUN★WORKS
SteveJohns29's Avatar
Quoted: 153 Post(s)
Looks awesome! I'd probably do this if I didn't already have a hole in my fender..
Sponsored by:
475WHP/363wtq
SteveJohns29 is offline
post #9 of 51 Old 05-13-2014 Thread Starter
Zosyn who?
omg, i thought you seriously took a selfie pic.... Didn't realize it was a video link.
lmfao !
SOLD
K&N Typhoon Intake
HKS SSQV4 BOV
CP-E Tow Plate
CURRENT VEHICLE:
post #10 of 51 Old 05-13-2014
White 2.0T A/T
ozonegc's Avatar
great diy! nice work man
2012 Karussell White 2.0T A/T
HP - 183 TQ - 205 on stock tune
Mods: Eibach Sportlines, and some stuff ;D pm me if you wanna know how i got to these numbers.......
ozonegc is offline
post #11 of 51 Old 05-13-2014
Chris.himself's Avatar
awesome!
2014 Casablanca 2.0T R-Spec
-Exceladyne Catback Exhaust
-Full Morimoto Headlight Retrofit
-Diode Dynamics License plate LEDs
-Flat black wings F/R
-Wing center caps
-Carbon Fiber Rear Lip
-Lower Grill HoneyComb Mesh
Chris.himself is offline
post #12 of 51 Old 05-13-2014
Insert Klever Title Here
38special's Avatar
Quoted: 34 Post(s)
This is awesome! I like this method a lot better than the ones with the rubber straps and whatnot. This looks much cleaner imo. Kudos man! Subbing for future use
History
1990 EF Hatch - Sold
2002 Civic EX - RIP (Katrina Victim)
2005 Corolla - Sold
2000 Civic Si - Sold
1991 MK3 Supra - Sold
2010 MB Genesis 3.8 GT 6MT - New Daily
1989 MK3 Supra - FOR SALE
**38special's Other Car FOR SALE Thread**
https://www.gencoupe.com/other-vehicle-discussion/130757-38specials-other-car-build-thread.html
"I am always doing that which I can not do, in order that I may learn how to do it." -Pablo Picaso
38special is offline
post #13 of 51 Old 05-13-2014
nomoreammo's Avatar
Quoted: 123 Post(s)
Awesome DIY! Gonna try this in the near future cause my passenger side is totally effed up!
2012 Tsukuba Red 2.0T A/T
Beyond Redline Stage 1 tune
CP-E Intake
CP-E Catback Exhaust
AGP FMIC w/ SSQV BOV.
Turbo XS Downpipe
Forge BOV
nomoreammo is offline
post #14 of 51 Old 05-13-2014
focalgencoupe's Avatar
Quoted: 251 Post(s)
Video does not play for me.
How do you release it, do you push the button?
Also isn't there bottom bolts?
focalgencoupe is offline
post #15 of 51 Old 05-13-2014
240SX turned GC
s3t0_S13's Avatar
Quoted: 16 Post(s)
wondered why a selfie was the last pic lol
any thoughts of painting it? maybe use touch up paint on it? It sorta flows with your wheel color, but despite that asshat charging $175, they were color matched (omg $100 color match)
Competition Clutch
HKS
K
&N
M&S
ABS Dynamic
ARK
AGP
Superlux
Btrcc
PowerAXEL
Magnaflow
s3t0_S13 is offline
post #16 of 51 Old 05-13-2014 Thread Starter
Zosyn who?
seto, this is where i might have nelson do the painting
SOLD
K&N Typhoon Intake
HKS SSQV4 BOV
CP-E Tow Plate
CURRENT VEHICLE:
post #17 of 51 Old 05-13-2014
240SX turned GC
s3t0_S13's Avatar
Quoted: 16 Post(s)
I think color matched would like awesome, or do that neochrome stuff, and save about $159.99 from that other foo lol
Competition Clutch
HKS
K
&N
M&S
ABS Dynamic
ARK
AGP
Superlux
Btrcc
PowerAXEL
Magnaflow
s3t0_S13 is offline
post #18 of 51 Old 05-13-2014 Thread Starter
Zosyn who?
f*ck that fool
SOLD
K&N Typhoon Intake
HKS SSQV4 BOV
CP-E Tow Plate
CURRENT VEHICLE:
post #19 of 51 Old 05-13-2014
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
The strap locks do rust over time as I'm always replacing them on my basses so some extra painting and clearing would be a good precaution. Love the idea very creative and music inspired!! Good work. I'll be doing this once my bumper finally breaks for good
2017 VW Golf R "Daily"
Thumb5 is offline
post #20 of 51 Old 05-13-2014
bgreen's Avatar
This is awesome, the pain in the ass process to get the bumper of is whats stopping me from installing my fogs...and in the future IC piping
1993-Electron Blue Nx2000-SR20DET
2010-M-Blue Genesis Coupe 2.0T
bgreen is offline
Front bumper quick release TurboCoupeGirl General Discussion 22 11-27-2016 02:05 PM
**NEW RELEASE** Polyurethane front bumper [email protected] Exterior 2008-2012 96 12-19-2014 03:44 AM
Quick release oil drains in Canada Bubba_J Engine 0 05-29-2013 08:14 AM
NRG Limited Edition CF steering wheel, Hub, quick release FS fatflyguy Interior 0 11-10-2011 11:41 AM
Personal Steering wheel and Quick release setup Kamkaze Interior 8 03-09-2011 04:13 PM
