Thumb5's unassuming build thread - Page 8 - Hyundai Genesis Forum
 10Likes
post #141 of 148 Old 11-19-2018
lokiinlove's Avatar
Quoted: 106 Post(s)
Originally Posted by Thumb5 View Post
Which side? Exhaust or intake? I did re-do everything recently on the wastegate control side since all my lines started to fall apart from heat cycles
exhaust
I did test routing of vac lines few days ago and i kinda feel i have too much lines, another thing it seems some are way too much exposed to the heat from turbo. I have bottom mount manifold though. ANyway, i'd appreciate pics, maybe i'll get some inspiration
EFR7163 2.0T BK1 A/T build - fast spooling 400whp+ 5speed auto <- let's pray it'll last a while -> https://www.gencoupe.com/gencoupe-build-projects/582313-lokiinlove-s-2-0t-t-build-thread.html
lokiinlove is offline
post #142 of 148 Old 11-19-2018 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
How is your boost controlled? Electric or manual? Manual is a bit simpler but both setups end up about that same. Where do I even upload photos to post here anymore? Photobucket still?
2017 VW Golf R "Daily"
Thumb5 is offline
post #143 of 148 Old 11-21-2018 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
Thumb5 is offline
post #144 of 148 Old 11-23-2018
lokiinlove's Avatar
Quoted: 106 Post(s)
Thanks mate!
that's pretty the same as i routed it, the difference is that i use Pierburg solenoid supplied with EFR + instead of T fitting i use 4-port fitting to feed bypass solenoid. Btw, why did you opt not to use integrated bpv?
Also, is that MV-R wastegate? which spring setup do you use with push\pull wg control and what does you boost curve look like?
Do you have any heat issues with current setup? I see you have PS tube wrapped and i guess something is wrapped above the downpipe, heater hose?
post #145 of 148 Old 11-23-2018 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
I already had piping setup for my tial Q so I didn't really need to change anything. It was cheaper to buy a block off plate then it was another charge pipe and powder coat it. Both are totally fine. I may have fitment issues with the intake pipe if I kept the BPV. The Q only uses manifold vacuum from what used to be purge valve port. So it's really quick using that port as I have tried others. It is an MVS wastegate using the 15lb spring IIRC (it's been so long). The spring it came with was a bit too light. Plenty of heat issues even though the manifold and turbine are coated (but pitting thanks to my new garage). The wastegate actually was black when I first got it.. These cars need vented hoods badly, haven't been racing only daily driving so I haven't really needed to worry about it last couple years. There is nothing wrong with the power steering line but anything else I wrapped was just precautionary, I did put a small piece on the heater hose just because I had extra. I also wrapped the wiring harness. I had to splice and relocate all the wiring that comes to exhaust side from the coil harness. All those wires were cooked from heat, insulation coming off.
I have to dig up an old log to see my boost map, it's boost per gear though so a bit less in 2nd gear but the rest full boost.
Thumb5 is offline
post #146 of 148 Old 11-26-2018
lokiinlove's Avatar
Quoted: 106 Post(s)
I decided to give EFR bpv a try, as sometime i really want gen to be a little quiter, plus i like the idea that released air is recirculated (though i won't really benefit from it being an auto). Capped BOV flange with silicone cap, will see how it goes. Regarding Tial, why did you opt for 15lbs spring? My thought was (based on Perrin Performance boost control write up and Turbosmart manual) that push/pull wg control allows to use lighter spring, like you can triple your spring pressure with dual port connection instead of doubling it with single port connection.
My wiring from coil harness was wasted same way, rewired it last week and guess need to add some more insulation. Seems there is no such thing like too much heat insulation.
post #147 of 148 Old 11-28-2018 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
I got the WG used from a friend and he had originally run it with a manual controller and had issues so he swapped the spring. What those issues were I don't know. All I know is it works great for me
Thumb5 is offline
post #148 of 148 Old 02-18-2019 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
I sold my car over the weekend. It's been fun now time to adult a bit more..
Thumb5 is offline
Pr_gen787 build thread and media thread *(PIC HEAVY)* PR_Gen787 Media 8 06-05-2012 12:49 PM
My Build Thread unkkut 2.0T Discussion 2008-2012 9 04-14-2011 08:45 PM
Slider's Build Thread Slider General Discussion 66 05-03-2010 09:09 AM
ARK PERFORMANCE INC: Offical Build Thread : GENESIS COUPE 3.8 TRACK BUILD ARK Performance Media 21 04-23-2010 09:28 AM
