Thumb5's unassuming build thread - Hyundai Genesis Forum
 10Likes
post #1 of 148 Old 03-20-2013 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
Well since i'm about to get to the point of full money blowing i figured I would share my build and experiences. I ran a BTR 16G setup last year and loved it, BTR makes amazing tunes!! I made 301whp and 267wtq and ran 13.6 @ 106mph with lots of spin on crap tires. The only thing BTR doesn't offer is a sure fire path to 400whp, although i'm sure those smarties will have something soon for the 10-12 crowd soon.
So the goal this year was 400whp, without having to sweat from running on a stock block. Naturally the best way to get there right now IMO is Beyond Redline's stage 4 kit. Let me first say that dealing with BR has been an absolute pleasure! Tim and Steve understand their customers and make sure they are satisfied, while making sure you understand what you are getting and what the realistic goals are. Instead of upselling stuff and promising power that isn't possible.
SO now to my car's upgrades. First things first, i'm not a rich person by any means. I work hard to blow the money on my car (60 hrs a week 7 days), and prefer to do things cheaply so I don't mortgage my immediate future. That said, I still believe in doing things right the first time. So I pulled my motor this winter and that's where the fun began.
2010 Grey Gen Coupe Track 2.0T w/26,000 miles (summers only)
Engine Build:
-K1 rods
-OEM rod bearings re-used (very good shape, #4 had a few marks on it, cleaned up, not enough oil..)
-OEM pistons and rings re-used
-New OEM Head Bolts, washers
-New OEM headgasket
-EVO X TSB timing chain upgrade
-Gasket matched head and intake manifold
-OEM Hyundai theta water cooled oil cooler (doughnut cooler on filter block)
-re-done engine grounds (stock bolts rust fast)
-relocated right side fuse block under battery tray (thanks msugerman)
-Brad Penn semi-synthetic oil
My engine build was very cheap, all of this was ~$700. No labor involved, work was done by myself and my co-worker who happens to be a Hyundai Gold technician.
Engine bolt-ons:
-Beyond Redline stage 4 complete kit, with EVERYTHING you need to run hassle free.
-Turbonetics T04E, 50 trim, ball bearing with an .82 A/R
-Bosch 750cc injectors
-Deuschworks DW300 Fuel Pump
-2013 Gen coupe fuel sending unit (~70 psi fuel pressure upgrade, best you can do staying returnless)
-BR fuel feed line
-Injen CAI
-Depo catless 02
-DC Sports downpipe
-Tomei Expreme cat back (LOUD)
-TurboXS IC piping and crash bar
-Treadstone tr10 intercooler
-ISIS Radiator w/Mishimoto hoses
-Tial Q BOV on cold side
-DEI heat sheathing for hoses and wiring, reflective gold sheet for hood, and platinum exhaust wrap
-ebay catch cans.. snoopy cans in the future!
Drivetrain:
-Competition Clutch Stage 2 (because 3.5 was no where to be found last year)
-TiC shifter bushings
-Blox weighted shift knob in platinum
-Redline MT90
**future mods, CP-E diff mounts and megan racing trans mount
Suspension:
-STOCK, lol, just Cusco front and rear sways for now, which are awesome BTW
**Eibach sportlines coming soon
-Bridgestone Potenza S-04 Pole Position tires
-20mm hub-centric spacers which may or may not be installed as I don't like ruining wheel bearings.
Brakes:
-Stock and pads are toasted already all the way around
** Hawk HPS pads coming soon
-I prefer sleeper status as I don't like lots of attention on the road. debadged, 2013 Taillights, Sarona grill, black OEM crooked Hs and CF rear bumper block off panel from Tomei
As of now my car is under construction as I wait for my stage 4 kit to arrive. I'm currently running on the stock ecu, turbo and injectors just to break the engine back in, next week it will all come apart again!
As I move forward i'll add pics, 1/4 mile times, dyno sheets and anything else relevant, all legit info, good or bad.
Here's a sneak peek pic, this is the prototype I guess you could say. Stock turbo and temporary covering on new coolant lines for oil cooler.
BrandonM likes this.
2017 VW Golf R "Daily"
Thumb5 is offline
post #2 of 148 Old 03-20-2013
White 2.0T A/T
ozonegc's Avatar
looks good man. did you ever get a picture of your intercoolers core? fin density
2012 Karussell White 2.0T A/T
HP - 183 TQ - 205 on stock tune
Mods: Eibach Sportlines, and some stuff ;D pm me if you wanna know how i got to these numbers.......
ozonegc is offline
post #3 of 148 Old 03-20-2013
2.0 MT - Shanghai
ecarca's Avatar
Nice!
Please let us know how the stage 2 cope with the 400+ whp. I'm interested
Regarding the pads and having tested both, I would probably recommend EBC yellow instead of HPS but your choice.
GTX2867R, K1 rods, Wiseco pistons, Siemens 750cc, BR Swain Tech coat. EM, Tial EWG, Synapse DV, Haltech, WB2, Grimspeed P&P IM, FMIC, cust. K&N intake, AEM MAP, BR EBCS, TurboXS Stealthback + Wilson Perf. cat-back, Bilstein B8, Eibach Pro-Plus kit, LSD, CC flywheel + stage 4, Brembo + SS lines + Ate Super Blue + EBC Yellow front/rear, Yokohama AD08R, 19", CF: hood, trunk, grille, ATQ shifter
Youtube (Nice Gen vids): http://www.youtube.com/user/ecyout
ecarca is offline
post #4 of 148 Old 03-20-2013
SJ is the man
JewishThunder's Avatar
Interesting to use an upgraded sending unit. That's a nice idea.
Joe's milkshake brings all the boys to the yard...
I AM SPECIAL!
JewishThunder is offline
post #5 of 148 Old 03-20-2013 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
Re: Thumb5's unassuming build thread
It wasn't my idea! But it's been successful on a gen before. Not sure what the max power is with this fuel setup, maybe 450. I am worried about my clutch, but it still looks new after a few 1000 miles so it should be OK for the dyno tuning. After that we'll see
Thumb5 is offline
post #6 of 148 Old 03-20-2013 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
There is another thread on the treadstone, it's the same as the tr8. A good balance between size and fin density
Thumb5 is offline
post #7 of 148 Old 03-20-2013
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 91 Post(s)
Snoopy0812 is offline
post #8 of 148 Old 03-28-2013 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
I'm still waiting for my stage 4 kit to get here but here is a few pics from along the way
I had to travel with my engine.. and when I put it back in my garage it was during a blizzard
Bosch/Siemens injectors, dump tube and grimmspeed gaskets
New coolant lines, this is all temporary. Eventually i'll buy a 2013 water pump which has the coolant lines for the doughnut cooler. But this works safely for now.
Thumb5 is offline
post #9 of 148 Old 03-28-2013 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
To Do list:
Springs/Coils
Brakes
Better sway bar bushings
A nice coolant overflow bottle
Install turbo kit!
Thumb5 is offline
post #10 of 148 Old 03-29-2013
Orlando, FL
Do you have any issues with surge due to the Tial Q opening a touch late?
2010 KW 2.0 R-Spec
Garret gt3071, K1 Rods, Wiseco Pistons, + a lot more
Custom tuned by [email protected]
382whp 319wtq @ 22psi on a mustang dyno.
BUY MY CAR! $16.5k!!!
https://www.gencoupe.com/automobiles-sale/209865-sale-2010-kw-2-0-rspec-400-whp-16-5k.html
Thumbs is offline
post #11 of 148 Old 03-29-2013 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
Never , not even once. How i have it hooked up it works great
Thumb5 is offline
post #12 of 148 Old 03-29-2013
Orlando, FL
Where are you running your vac source and what spring do you have in? I am tapping in to the large vacuum hose above the injectors (the one without the check valve) and I am still getting surge, even on the white spring (the plain is what my vac is rated for according to TiAL).
2010 KW 2.0 R-Spec
Thumbs is offline
post #13 of 148 Old 03-29-2013 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
You tapped the brake booster line or the vacuum generator? Niether is a good idea to use. Use my location which is the same as many others; the purge valve line. The 3/8" line where the black and white check valve is. T in front of the check valve. Also i'm running the -10 psi spring (noncolored)
Thumb5 is offline
post #14 of 148 Old 03-29-2013
Orlando, FL
Hmm, ok, thanks. I'll give it a shot. I'm replacing a lot of my hoses this weekend anyway, so that works out.
2010 KW 2.0 R-Spec
Thumbs is offline
post #15 of 148 Old 03-29-2013
cjd82187's Avatar
Subbed!
cjd82187 is offline
post #16 of 148 Old 03-29-2013
TsukubaSteve's Avatar
If u dont mind me asking, why did you choose to reuse the original bearings and rings if you went through all the trouble of putting in rods?
TsukubaSteve is offline
post #17 of 148 Old 03-29-2013 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
Because they were fine. For most people it's a lot of trouble but for me and my cohorts we can do a motor in an afternoon. Our cars are ridiculously easy to work on. Bring the criticism Iol
Thumb5 is offline
post #18 of 148 Old 03-29-2013 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
Also ultimate plan is ls1.. I don't think our motor is worth too much work
Thumb5 is offline
post #19 of 148 Old 04-01-2013 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
Everything I need, just waiting in the dw300 and the fuel pump assy. First fuel pump assy I got from Hyundai was broken of course. I'll show you guys how I'm gonna run my arm cai with this setup later tonight
Thumb5 is offline
post #20 of 148 Old 04-01-2013 Thread Starter
Korean Asswhoopin
Thumb5's Avatar
Quoted: 130 Post(s)
This will be my intake, hacked off AEM cai. Cut right before the badge.
Thumb5 is offline
Pr_gen787 build thread and media thread *(PIC HEAVY)* PR_Gen787 Media 8 06-05-2012 12:49 PM
My Build Thread unkkut 2.0T Discussion 2008-2012 9 04-14-2011 08:45 PM
Slider's Build Thread Slider General Discussion 66 05-03-2010 09:09 AM
ARK PERFORMANCE INC: Offical Build Thread : GENESIS COUPE 3.8 TRACK BUILD ARK Performance Media 21 04-23-2010 09:28 AM
