2012 3.8 Rspec / Supercharged :::: PIC HEAVY :::: - Hyundai Genesis Forum
 9Likes
post #1 of 294 Old 10-21-2013 Thread Starter
I wanna go fast!
stewb's Avatar
Whats going on folks! This will be be my Re-build / Build thread for my GC..... Your probably thinking... " Re-build ? what the hell is he talking about " well let me explain.
So, I purchased my first GC in 2012 - 3.8 Track Acqua Minerale BLue 6 spd - Loved the car ever since I layed eyes on it and couldn't wait to start modding/tweeking/perfecting it... My plan was to eventually get into the F/I side of the house, but that wouldn't be until later on down the road.... Flash forward 1 year later. I moved out to Las Vegas for my job (USAF) and I came across a Red 2012 Rspec / Supercharged that was for sale out in San Diego.... got to talking with the Stealership and got a great deal on the car that i couldn't pass up, especially after around $10K had been dumped into the car... So I drove out to San Diego and traded in my GC for the Red GC... Well I was super stoked to own a S/C GC - pretty much my dream of what I had planned for the future for my car. Well we've all bought used cars before right ? The next day the car over heated, so i began trouble shooting and found that my radiator hose had been sitting on the header and it burnt a hole thru it - so I replaced that. Thought that was the issue, nope she still remained to overheat, so I bought a new thermostat thinking maybe that the oem had taken a dump, but w/ only 12k miles I had high doubt that was the issue, but i still replaced it w/ a mishimoto racing thermostat - car still overheated. I was driving to work one morning and my temp gauge redlined within 5 mins of driving, and when I made it to work I opened the hood and I could hear a drip followed by a "hisssss" - it was coolant leaving the block and dripping on the header..... So this is where the RE-BUILD / BUILD part comes into play....
Before I pulled the motor, I removed the exhaust and stock suspension and installed my Ark Grip V2 & HSD Coilovers
This exhaust was SOOOOOOO loud, and it had poor welds, so it was time to go! I ended up giving it to my boy Travis - GenCoupe13 - here on the forum, he had it fixed and re-welded and he threw it on his 13' GC - It sounds amazing now !
Replaced with this beautiful work of art
I had these on my other GC and removed them before I traded it in.
Coils & Exhaust being installed.
Now onto the rebuild:
Car was purchased - June 1, 2013 / June 23, 2013 - I pulled the motor out.
After I tore the motor out & down, I came to find that I had Detonation in cyl 4 which caused my head gasket to literally explode and and also damage the top of the cylinder sleeve and Warp my head.... So my awesome purchase of a car was not so awesome after all....
So as of right now the Motor has been at a machine shop having the following done :
- Block Re-surfaced & Honed
- Heads Decked / Straight Edged / Re-Surfaced
- Crank Polished / Re-Balanced
- All Parts Hot Tanked / Degreased / Cleaned
- New Main Bearings
- New Rod Bearings
- New JE Piston Rings
- New Main Bearing Cap Bolts:
- 21117-3C100 P/N - Cap Bolt (8 bolts)
- 21116-3C100 P/N - Cap Bolt (8 bolts)
- 21126-3C100 P/N - Side Bolt (8 bolts)
- New Front Main Seal
- New Rear Main Seal
- New Valve Cover Gaskets
- New Intake Manifold Gasket(s)
- New Plenum Gasket
- Arp Head Stud Kit (16 Bolts)
The motor already had:
- JE Pistons - Size: STD / Bore: 96.0
- Brian Crower Sportsman Connecting Rods w/ ARP 2000 Bolts
So my plan for this Build Thread is to:
1. Keep you all up to date on the process.
2. Upload as many photo's / videos as possible.
3. Post new Mod's / tweek's to the car and motor.
Let the photos Commence!!!!!!!! Most of these pics were taken with my iphone so excuse my crappy resolution... I will try to get a nice camera to take future pics!
Hood Removed
Motor
Motor
Motor
Motor... yet again lol
Up on Jack Stands / Coolant drained
New Toys - Gotta Love Harbor Freight, all that for $185 !
My boy Mike aka Imdubbs here on the forum - Disconnecting the Exhaust
Everything disconnected from the motor
Cherry Picker all hooked up and ready to pull the motor out :P
Another view of the Cherry Picker
Up...
Uupp...
And away!!! :P
Motor out - Crappy pic sorry :\
Motor Out - Better Pic :P
Back of motor - Spec Clutch stage 3 clutch / Ark Headers
Motor / Supercharger Bracket
Valve covers removed - Didn't have bolts to mount the motor on the engine stand lol so 2 - 2x4's will suffice for the time being :P
Heads & Cams
Heads & Cams
Front Cover removed / Wiring Harness Marked & Taped
Front of Cams
Front of Cams
Started to remove the lower intake manifold and snapped my 6mm Hex Bit, I swear the bolts were torqued to 200 ft lbs friggin ridiculous!!!!!!
Hex Bit decapitated
Which called for a Beer Break! :P
Quick shot of the garage and how everything was sitting - slightly organized :P
The infamous blown headgasket!
yep, blown to SH*T !
..... grrrrr
Head Removed - gasket literally sprung up when I pulled the head off, and you can see the pistons crown of Cyl 4's is nice and shinny from the coolant being sucked in there, thank god she didnt hydro-lock!
heres a better view... steam cleaning at its finest!
Bottom side of the head.... Exhaust valves were soaked as you can see!
Again, exhaust port soaking wet.....
Close Up
Better Close up.... ridiculous.
Heads off / Top Dead Center
Piston crowns
Stupid finger lol
Cleaned the Heads up a lil :P
Thought this was a cool pic :P
Now onto the good stuff.... Cyl 4 side wall damage from the detonation!
Again...
Better angle / up close pic
Headgasket again.... Aye aye aye!
Pretty sweet pic!
And another...
FINALLY!!! got bolts for the block to put on the engine stand lol Thank you Home Depot :P
Organization at its finest!
And thats all for now folks! Stay tuned for more progress and updates!
Update 2
Update 3
Update 4
Update 5
Update 6
Update 7
update 8
Update 9
Update 10
Update 11
Update 11
Update 12
Update 13
Update 14
Update 15
Update 16
Update 17
stewb is offline
post #2 of 294 Old 10-22-2013
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 91 Post(s)
I was wondering where that SC kit went. Good job on the pics too and looking forward to future developments.
Snoopy0812 is offline
post #3 of 294 Old 10-22-2013
SJ is the man
JewishThunder's Avatar
This seems to be Layzie's car. Bummer that he took a car that had so much bad work done to it, and then sold it to a dealership. I can't believe a dealership would even buy a car like that. Glad you're reviving it, because done properly that should be pretty damn sweet.
Joe's milkshake brings all the boys to the yard...
I AM SPECIAL!
JewishThunder is offline
post #4 of 294 Old 10-22-2013 Thread Starter
I wanna go fast!
stewb's Avatar
@ Snoopy - thanks for opening up the thread brotha! There will be way more pictures and way more future progress in the works!
- Stew
@ JT - Yea it was his.... There was a laundry list of things wrong with the build man, but I got the car at a steal, sometimes things really are too good to be true huh ? However, Im taking all of the necessary steps to revive this monster and have everything done right! no cutting corners like the previous attempt of putting this motor together! stay tuned for progress updates!
- Stew
stewb is offline
post #5 of 294 Old 10-22-2013
SJ is the man
Originally Posted by stewb View Post
@ Snoopy - thanks for oprning up the thread brotha! There will be way more pictures and way more future progress in the works!
- Stew
- Stew
I'm looking forward to keeping up with it! Seriously though, I would triple check anything that you're not personally fixing/replacing. From top to bottom.
I AM SPECIAL!
post #6 of 294 Old 10-22-2013
Sleeper!
GenCoupe13's Avatar
Quoted: 106 Post(s)
About damn time Stew haha. Glad to see you finally got around to it though. Call me when your ready to put that beast back together.
2013 3.8 Shoreline Track M/T Blue
Sponsored By:
Mishimoto / GrimmSpeed / ClutchMasters / GENRACER / ARK Performance
GenCoupe13 is offline
post #7 of 294 Old 10-22-2013
LeesEvoGenX's Avatar
Quoted: 342 Post(s)
I think I remember the thread this guy was selling the car on. Had all kinds of problems.
Good luck on your resurrection build!! As already stated just triple check everything!! lol. This will be superb once completed!!!
2013 Evo X GSR: Built 2.0l with Wiseco pistons, Manly turbo tuff rods, titanium valve springs, Kelford 214-B cams. Stock sleeves. Custom Fuel Rail. Custom Surge Tank.
On Kozmic's Mustang Dyno: 425AWHP 330AWTQ(Break in tune)
Final Tune on E85: 505AWHP 357AWTQ
LeesEvoGenX is offline
post #8 of 294 Old 10-22-2013
GTBoostedGC's Avatar
What type of supercharger did you get? A centrifugal or more of a twin screw?
GTBoostedGC is offline
post #9 of 294 Old 10-22-2013 Thread Starter
I wanna go fast!
stewb's Avatar
HAHA My man! Yea I was bored lastnight and thought " what would travis do? "....... soooo you're welcome lol
stewb is offline
post #10 of 294 Old 10-22-2013 Thread Starter
I wanna go fast!
stewb's Avatar
That would be a Rotrex centrifugal belt fed supercharger sir
stewb is offline
post #11 of 294 Old 10-22-2013 Thread Starter
I wanna go fast!
stewb's Avatar
Trust me brotha... Myself and my machinist have went thru this motor from top to bottom and side to side with a fine tooth comb to make sure she purr's like a lion in heat :P
stewb is offline
post #12 of 294 Old 10-22-2013
Sleeper!
GenCoupe13's Avatar
Quoted: 106 Post(s)
Haha too funny. You already knew "what would travis do?" haha since I mentioned you needed to make one, right massa? (you had me dying with that too btw). Looks good bud. Keep it up!
Sponsored By:
post #13 of 294 Old 10-22-2013
Quoted: 342 Post(s)
Oh yeah I don't doubt you for a second man. I honor thee for taking on such a giant task. It will so rewarding though when it starts on the first crank when you're done
Either way I am subbed in now for some supercharged goodness!!
Congrats again my man, keep taking lots of pics through the steps, cuz you know we love to see em
post #14 of 294 Old 10-22-2013
R-spec13's Avatar
Sub a dub dub
R-spec13 is offline
post #15 of 294 Old 10-22-2013 Thread Starter
I wanna go fast!
stewb's Avatar
Thank you good sir!
stewb is offline
post #16 of 294 Old 10-22-2013 Thread Starter
I wanna go fast!
stewb's Avatar
:::: UPDATE ::::
Just got back from the machine shop today. I had to go drop off my Main Bearing Cap bolts, my machinist spun a bolt and you'll see why you never re-use Oem Hyundai bolts - damn near every bolt on the 3.8 is Torque to Yield - AKA - ONE TIME USE ONLY FOLKS!!!! Anywho, he told me I should have the motor back tomorrow... but im not holding my breath...
Here are some pics of the progress, the motor looks absolutely amazing, these guy did some phenomenal machine work to the Block & Heads:
Beautifully re-surfaced block!
Brings a tear to my eye... :P Fantastic craftsmanship.... Block was knifed .003"
As you can see on the main cap's the furthest one to the right is missing a bolt, because it was spun being put back in! But all is well, it didnt snap - only twisted :P FEWF!
And this is exactly why you never re-use TY bolts folks!
16 New Main Cap Bolts & 8 Side Bolts
Heads w/ Cams... Every piece of this motor was Hot Tanked, Degreased and Cleaned!
Heads w/ Cams
JE Pistons & Brian Crower Connecting Rods.... All have been Hot Tanked, Degreased and Cleaned
Pistons look brand new again :P All new JE Rings installed
Awesomeness :P
Heads were Decked, Straight Edged, Planed, and Re-Surfaced... Again, they look fantastic!
I tried taking a picture of the Cylinder Walls - not the best sorry guys - anyways, they have been honed and lubed.... they look great, extremely smooth!
EDIT:: Also in the last picture, the center cylinder is Cyl 4 where the detonation occured and damaged the top of the cylinder wall.... all fixed - looks like nothing happened! looking great :P
Thats all for now guys... I hope you enjoy seeing the progress as much as I enjoy going thru it :P
- Stew
stewb is offline
post #17 of 294 Old 10-22-2013
In Charge of Snacks
Odelagt's Avatar
Quoted: 239 Post(s)
I'm almost crying from happiness! Thanks for saving the honor of the SC gen coupe. lol
'11 3.8 R-spec
Odelagt is offline
post #18 of 294 Old 10-22-2013 Thread Starter
I wanna go fast!
stewb's Avatar
Hahahaha you sir are very welcome! I cant wait till i get the motor back and get the car running, shes gonna be bullet proof and one bad SOB :P stay tuned my friend!
stewb is offline
post #19 of 294 Old 10-22-2013
슈퍼 쿠페 ^_^
Snoopy0812's Avatar
Quoted: 91 Post(s)
Who told you it would be ok to reuse the factory bolts?
They did an excellent job on that block btw, looks mint. Did you happen to get them to port the exhaust on the heads?
post #20 of 294 Old 10-22-2013 Thread Starter
I wanna go fast!
stewb's Avatar
Thanks snoopy! they've done a hell of a job re-surfacing the block and the heads... I was blown away today when I seen everything! Trust me I wasn't going to re-use the original bolts... My machinist was re-using them to test fit the new main bearings to check for clearance & fitment just to make sure everything seated well... Half way thru tightening the last bolt it spun on him and luckily enough didnt snap - thank god! and he was able to remove it... I had already purchased the new bolts before hand :P and i'm using ARP head studs for the top end of the motor
Also, the reason why it spun in the first place was because the 1st time the motor was torn down by the previous owner's friend who was a "mechanic" he re-used them and torqued them down - big NO-NO. Then the previous owner had the motor torn down a 2nd time at a proper machine shop (due to issues that occured from the 1st tear down/rebuild) that machine shop then re-used and torqued those same bolts again including my head blots.... which blew my mind... because damn near every bolt on the 3.8 including the 2.0 and Torque to yield.
stewb is offline
2012 Barrie and Beyond - Round 2 *pic heavy* ReGenEr8 Media 15 11-01-2012 10:20 PM
Partout - 2010 2.0T RSpec(Pic Heavy) GCShadow Engine 11 10-16-2012 08:59 AM
2012 Barrie and Beyond Fall Cruise *pic heavy* ReGenEr8 Media 15 10-09-2012 03:45 AM
2012 Street Impressions Canada Day Car Show - PIC HEAVY SomeGuyDave Media 10 07-03-2012 07:28 PM
Finally got my 2013 3.8 Rspec... pic heavy mast240 Media 5 05-01-2012 01:42 PM
