A Poor Noobs LS3 T56 Swap - Hyundai Genesis Forum
 61Likes
post #1 of 96 Old 05-14-2017 Thread Starter
Lacbank813's Avatar
Quoted: 27 Post(s)
Quick backstory. I'm an Army Aviation veteran (15P's lead the way lol), who, during the time of LS swapping my GC, was just a college kid. I'm 25 with not much knowledge on working on cars. My terminology, or way of doing things may be wrong, or I may have simply made an extra step when I shouldn't of so bare with me and please, feel free to comment your displeasure, or praise. So with that being said, the purpose of this thread is to walk through all the steps of LS swapping your GC FROM THE PERSPECTIVE OF A POOR MAN WITH A $99 DURALAST TOOL KIT AND A ENGINE HOIST OLDER THAN I AM. I started with an LS1, got it running, then swapped it for a new L99/LS3. Hopefully it encourages those on the fence with little to no experience on building cars to swap, I know it is difficult to ask for some of this information without being belittled in GCO on Facebook. 2011 3.8 Track automatic. I did everything myself, with the exception of a bit of wiring, and all credit will be given later on. Enjoy. I hope this makes an impact. Here we go (PIC HEAVY):
August 2016, where it all began. I purchased a LS1 out of a 2002 fbody Camaro with 67k miles. I picked it up locally for 2600 bucks, it came with all accessories, including harness and PCM.
Shortly after picking up the LS1, I was able to grab a Tick stage 2 T56 locally for 2000 bucks.
At this point I'm all in. I sold the 2011 3.8/ZF for 250 bucks, provided they do the pulling of the engine/trans themselves, which they did. Initially I was going to have a shop build it all (Relentless Designs in Glendale, AZ), but when it came down to it, they started to ignore me after guiding me on what to purchase. It seems the shop didn't really think I would pull the trigger and have them build it! I was stuck with a LS1/T56, so I decided I would finish the project MYSELF. The project sat for a few weeks, as my wife was pregnant and we were starting the process of moving to a bigger house with an actual garage (albeit small).
New house. Tiny garage. The project resumes. Enjuku's kit gave me a couple issues, but I will get into that later on in the thread. For now, my focus was on wiring.
I had a LS1 harness made brand new from a local shop, Tempe Speed & Performance. The common misconception is the genesis ECU is needed - IT IS NOT NEEDED - all my interior items work, except for the gauge cluster (which I will be installing a Holley setup with my next paycheck). I'd imagine traction control and ABS doesn't work, and the genesis ECU will be needed in that case, but I don't care about those features enough to find out that information. I wanted the LS1 PCM mounted under the dash, as well as a second push start button to turn the engine on. The OEM push button still cycled through power like normal, but the second push button fired the motor up. I paid a guy 140 bucks to strip the unnecessary from the Hyundai harness, install the LS1 harness and mount the PCM.
LS1 PCM and fuse box installed under the glove box.
A photo of the engine bay with the Hyundai harness stripped/cleaned up.
As I prep to pair the LS1 and T56 together, a few things had to happen. T56 fbody shifter cup had to be swapped with a GTO shifter cup.
New GM slave cylinder, as well as remote bleeder and clutch line installed.
Power steering. Blue - high pressure, SS line - return line (low pressure).
Everything paired up, now I can moved on to interior/engine bay modifications before dropping the LS1/T56 in.
Going from an automatic to a manual, I decided to just swap in an OEM GC clutch pedal (Hyundai had pre-cut indentions in all the right places that I used a hole saw attached to a drill to punch out), as well as an OEM clutch master cylinder. Not pictured, but I got a shiny cover to the clutch pedal to give it a cleaner look. I also used a 240SX gas pedal and throttle cable.
LS1 and T56 in! ISR longitudes installed, they were a lovely looking set if nothing else lol
ISR LS swap Longtubes
Extra step in going from auto to manual was cutting a hole in the interior. I cut the hole prior to dropping the engine/tranny in, but took a picture after. Additional cutting was needed, but I failed to take more photos.
Without spamming you guys with pics of every step - here are a few in one photo. I installed (yes, by myself. It was nerve-racking being my very first time taking an engine apart - I used LS1HowTo as a guide) 228r cam from TSP with .600"/.600" lift and 112LSA, SLP ported oil pump, TSP hardened pushrods, double behive spring and titanium retainers from PRC, LS2 timing chain set and LS7 lifters. I also cleaned up the pistons and heads. I had to installed the driveshaft so I could place the car in gear to lock the crank from spinning.
Aluminum driveshaft
Enjuku originally stated I could use stock driveshaft bolts to install the driveshaft to the adapter, and into the diff. After a long trip to a farther Hyundai that had them in stock, I quickly realized that was false. I took the whole driveshaft to ACE Hardware and bought some socket head bolts, which needed some grinding and an ACE worker happily did just that. Some red loctite, and it was good to install.
Because I was only working with jack stands, I jacked the car up as high as possible, and without removing the exhaust, I shoved the driveshaft behind the x-pipe, and into the tail of the T56. I had to remove the heat shield, which is pictured above.
Final pic of the driveshaft installed. Heat shield removed.
Installing the fuel lines, fuel pump and fuel pressure regulator.
Bought a fuel pump assembly with the in tank fuel pressure regulator deleted, return line installed and threw in a DW200 fuel pump.
Mishimoto radiator for Bk1 3.8, and Uniq Performance fan shroud with Mishimoto fans.
This was a big moment for me. I could see the finish line. It was fired up a few weeks later, with no issues. It drove perfectly, turned countless heads and was well worth the downtime.... but one day I seen an L99/LS3 for 4000 bucks, best part was it had 11 miles on it vs the LS1 with 67k miles. So I jumped on it!
LS1 pulled in about 45min, again, plenty of room and probably the easiest motor to work on and around.
Sold the motor for a quick 2k, sold as soon as I posted it. The guy I sold it to became a real good friend of mines. He bought it to replace his high mileage, stock LS1.
11 miles on this bad boy!
L99 stripped down and converted to an LS3, including an GMPP ASA cam 226/236 .525"/.525" lift on 110LSA, Melling high volume oil pump, Katech C5-R timing chain, GMPP springs, LS7 lifters, and TSP hardened pushrods, comp cams rocker trunnion upgrade, 3bolt cam sprocket, and LS2 chain damper. I also used an LS7 clutch. Everything, from longtubes, to oil pan, to motor mounts etc transferred over with no issues
LS3 / T56 going in!
Threw in a LS1 pilot bearing, LS7 clutch and dropped her back in. I re-used the LS1 wiring harness and LS1 PCM to cut costs, I didn't want to remove the crank to change the reluctor wheel, so I wired up a Lingenfelter 58x/24x reluctor conversion module, some injector adapters, crank extension wire, MAP extension wire, and also switched to the LS1 accessory configuration. In the picture above I used a corvette spacing, but the alternator touched the fuse box, so I had no choice but to switch to LS1 accessory config using Dirty Dingo brackets. I used spacers to retain the LS3 corvette water pump, as it has been reported it keeps the engine 5-7 degrees cooler vs the LS1 water pump, and also is lighter = less parasitic drag.
LS3 is done. I'm tuning some bugs out with HPTuners, and looking to get a cold air intake fabricated so IATs aren't so bad. I will update this thread with some videos of everything running, and some more 'steps' and photos.
LS1 cammed, untuned, open headers, first drive.
LS3 idling above.
titan2782, kelvo5 and ekuapa like this.
2011 Genesis Coupe GL1
-6.2 liter V8 LS3 + ZL1 supercharger
-Tick Performance Level 2 T56
-3.73LSD
2004 Pontiac GTO
-M12 T56
-3.46LSD
Lacbank813 is offline
post #2 of 96 Old 05-16-2017
I absolutely love your build so far ...I have a bk2 2.0 and iam in the process of getting a LS3 and. T56.....I read on an LS forum that you have to change a handful of things to mat a t56 to a ls3....any feed back on that? Also I hear alot of people say forget were to do it over the wouldn't use the enjuku kit ? Do me a favor stick with posting I'm gonna need all the help and advice I can get for my first ever engine swap...
Lacbank813 likes this.
Nyce0 is offline
post #3 of 96 Old 05-16-2017
FailSauce's Avatar
Quoted: 30 Post(s)
This is heavenly! O_O
SFR | TurboXS | Injen | Mishimoto | Sprint Booster | Enkei | Enthuspec | Parts Shop MAX | Hankook | EBC | Megan Racing | Garageline | Diode Dynamics | OBDLink | Sequence | BBM
FailSauce is offline
post #4 of 96 Old 05-17-2017
Genna108's Avatar
Quoted: 14 Post(s)
Great work. I been following your build from the start on Instagram the ls motor sit so much more comfortably than the 3.8 (IMHO)
Genna108 is offline
post #5 of 96 Old 05-17-2017
br2
Bill
Quoted: 133 Post(s)
dude, holy @#@#...
if you're enjoying yourself more power to you.
i occasionally wonder what mine would look like gutted with a Merlin...
br2 is offline
post #6 of 96 Old 05-17-2017
koreancoupe's Avatar
Quoted: 12 Post(s)
Whole lot of awesomeness in this thread. Keep up the good work.
2015 R-Spec, 6spd
R2C Intake
Lightweight Pulleys
BTR ECU (Secondary Cats Off)
CPE Catback exhaust
koreancoupe is offline
post #7 of 96 Old 05-20-2017 Thread Starter
Lacbank813's Avatar
Quoted: 27 Post(s)
All you need is an LS1 pilot bearing and LS1 slave cylinder, it bolts right up otherwise!
EDIT: This was my first thread that I decided to do at like 3AM, so I missed a couple important steps, like having to grind the enjuku shifter on the bottom because it touched the shifter cup, preventing a full shift into reverse (also reported by multiple others). Feel free to PM, or check here if you need any advice on anything, I'll be updating this thread periodically.
-3.73LSD
2004 Pontiac GTO
-M12 T56
-3.46LSD
post #8 of 96 Old 05-20-2017 Thread Starter
Lacbank813's Avatar
Quoted: 27 Post(s)
Originally Posted by br2 View Post
dude, holy @#@#...
Yup, but were more than a few occasions when I had serious regret in swapping vs buying an LS powered vehicle.
-3.73LSD
2004 Pontiac GTO
-M12 T56
-3.46LSD
post #9 of 96 Old 05-20-2017
shorttrack
Quoted: 375 Post(s)
Nice.
shorttrack is offline
post #10 of 96 Old 05-20-2017
shorttrack
Quoted: 375 Post(s)
Any plans for a rear 4th differential bushing ? 525 hp and gobs of TQ will tax the rear.Many writes ups on 4th diff bushing mods.I used a actual sleeve welded in place first then installed the OEM C-bushing .My diff mod can be seen in the ''Nitrous on a GDI 3.8'' thread on page 16 of the thread.The mod will help in keeping the rear planted .
post #11 of 96 Old 05-22-2017
Quoted: 11 Post(s)
Awesome build so far!! This swap look so clean!
Andron is offline
post #12 of 96 Old 05-22-2017 Thread Starter
Lacbank813's Avatar
Quoted: 27 Post(s)
To my understanding, as long as I stay away from launching with sticky tires, especially a prepped drag strip, it'll hold up for now. I do plan on either going ford 8.8 (thanks to Roland for posting his 8.8 from a cobra in his GC), or adding subframe risers, solid mounts and a fourth bolt. I've been waiting for the diff to fail, or show signs (to motivate me to do the dreadful task of dropping the subframe), but after about a month of some fun driving with the LS1, I've had no issues. My LS3's configuration was mirrored to the 376/525 crate motor (GM's ASA cam), so while I have not dyno'd yet, 525hp crank is what Chevy has advertised. Longtubes (w/ xpipe, glass pack), tune and TB should certainly eek out a bit more power, but I expect to have at least 460+ WHP. Dyno next week! I'll be sure to post the results.
shorttrack likes this.
-3.73LSD
2004 Pontiac GTO
-M12 T56
-3.46LSD
post #13 of 96 Old 05-22-2017 Thread Starter
Lacbank813's Avatar
Quoted: 27 Post(s)
Updated with some more photos/steps and a video of both the LS1 and LS3 idling. I will continue to add some more.
-3.73LSD
2004 Pontiac GTO
-M12 T56
-3.46LSD
post #14 of 96 Old 05-24-2017
Psytwerk's Avatar
So awesome!!!! Keep going!
Jorge De Silva - Photography & Filmmaking
www.jorgedesilva.com
2013 Hyundai Genesis Coupe | Euro-Spec | 2.0 Turbo | Casablanca White | 8 Speed Auto
Psytwerk is offline
post #15 of 96 Old 05-24-2017
Quoted: 21 Post(s)
This is my dream to do when I get a proper garage. Either a 350Z or my Gencoupe. Such an amazing job. Sounds amazing! Just great
bswanny is offline
post #16 of 96 Old 05-30-2017
Evo
Hey buddy couple questions. Where did you need spacers for the water pump? And what size fuel line did you use? Did you run all new fuel line ? And did you need the reluctant wheel adaptor because you are using a ls1 ecu and harness?
Evo is offline
post #17 of 96 Old 05-30-2017 Thread Starter
Lacbank813's Avatar
Quoted: 27 Post(s)
I had corvette spacing before switching to Fbody spacing (configuration of accessories). The corvettes harmonic balancer sits closer to the block than the Fbody, with the Fbody balancer sticking out 3/4" further. So, to use the LS3 vette water pump with Fbody harmonic balancer/accessories, I needed 3/4" spacers made by ICT Billet, in order for the water pump's pulley to be in line with the rest of the accessories. I used stock fuel line (which is -4 IIRC) up until it reached the engine bay, then I used -6 to the FPR, then to the LS3 fuel rails. The return line I used is -6 as well, all of which is nylon braided fuel hose. And yeah, if I had a LS3 harness made and used the respective computer, I wouldn't need the reluctor wheel conversion module. It was cheaper to reuse the LS1 stuff because I was quoted at 900 bucks for a new harness, and then when I factored in the cost of a new LS3 ECU, DBW throttle body, pedal, TAC, HPTuners credits for new ECU, then it was an easy decision.
-3.73LSD
2004 Pontiac GTO
-M12 T56
-3.46LSD
post #18 of 96 Old 06-13-2017
Addicted to parts
titan2782's Avatar
Quoted: 1063 Post(s)
nice build. I love how you state that you don't know anything, then proceed to dive into a non-trivial engine swap That's how i got started back in the day, just started tearing crap out of the car and learned what it all was as I went. Everyone should do an engine swap at least once!
3point8 Performance
Performance parts for your Genesis Coupe, G35/G37, 350z/370z
@3point8Performance
2014 3.8 R-Spec - Tuned by AlphaSpeed
352HP/312TQ (Dynomite)
336HP/298TQ (Dynojet STD)
330HP/292TQ (Dynojet SAE)
3p8p Stage 3 intake manifolds, 3p8p manifold riser, 3p8p true CAI, J2 Headers, Coolerworx true STS
titan2782 is online now
post #19 of 96 Old 06-13-2017 Thread Starter
Lacbank813's Avatar
Quoted: 27 Post(s)
Haha hell yeah. Definitely a confidence and knowledge boost, so now, unless I'm lazy, I don't think another man will ever touch my car. I've even been doing my own wiring now. But if I could do the swap again with the knowledge I have now, I would probably save about 2k easy.
-3.73LSD
2004 Pontiac GTO
-M12 T56
-3.46LSD
post #20 of 96 Old 07-17-2017
REPTAR's Avatar
Did you happen to retain A/C , Heat , Cruise control , ABS, ETC?
After the LS Swap what functionality did you lose?
2010 Genesis Coupe R-Spec 2.0t M/T tsukuba red
REPTAR is offline
A Noobs Build.... kay609 GenCoupe Build / Projects 48 06-15-2015 07:19 PM
wtb T56 UrbanCrisis Classified Drivetrain 2 02-02-2015 03:52 PM
Tuning Help For Noobs Kahij 3.8 V6 Discussion 2008-2012 10 01-31-2015 06:08 AM
FS: 2005 Corvette T56 and Differential BAMATuner Other 0 07-29-2010 02:22 PM
