3.8 Engine Forum Lately - Page 5 - Hyundai Genesis Forum
post #81 of 98 Old 10-13-2012
newmedia's Avatar
I think Pavel racing engines on facebook started working on genesis coupe 3.8 rebuild.
newmedia is offline
post #82 of 98 Old 10-13-2012
1stgengen
ByByCavalier's Avatar
I want to see everything!
I need journal bearings and other random engine ****, you gotta help a brother out!
One standardized US gallon of displacement compressed using 6 pistons housed in a 60 degree all aluminum V shaped block to 10.4 atmospheres injected and ejected via 24 valves and 4 camshafts. Mix part 100% organically produced air w/ part refined 91 octane liquid hydrocarbons. Expose to electricity and pressure within the energy extrapolater to produce forward thrust via a fully synchronized helical gear set coupled to a minimal slippage differentiator and rubberized traction disks.
ByByCavalier is offline
post #83 of 98 Old 10-13-2012
newmedia's Avatar
I hope pavel will write a build blog like they did with 2.0 engine on his web site. He knows he has all the time he needs to make custom internal engine parts to public as he see it. I am just trying to do it right first time so the engine has less issues in F/I applications. funny things is I am not asking for not more than 350whp at most for 2010 3.8 A/T using very simple rotrex c38-61 using 90mm pulley supercharger kit made by poweraxel. The system does not have water cooled intake maniford like APG rotrex supercharger kit and optional use of headers. I just want few more whp that is very reliable in long run as DD.
newmedia is offline
post #84 of 98 Old 10-15-2012
newmedia's Avatar
crap...another extra $$$ needed on rebuild , Hyundai korean built engine had installed one of the crankshaft parts backwards. now the crankshaft needs to be sent out , fixed, and coated.
newmedia is offline
post #85 of 98 Old 10-15-2012
1stgengen
What part was installed backwards? I have a spare crank sitting around here if you want it lol!
post #86 of 98 Old 10-15-2012
newmedia's Avatar
I want it if its in good shape with no damage.
Pavel said it was one of the bearings on the crankshaft. Pretty much it needs rebuild...
newmedia is offline
post #87 of 98 Old 10-15-2012
a.k.a. DevilDog
Jorge@UNIQPERFORMANCE's Avatar
Don't forget to put plastidip all over it before you install it
2014 3.8 Track A/T - Casablanca White *SFR Custom Tuned*
post #88 of 98 Old 10-15-2012
I just bought a 2010 genesis coupe track 3.8, 35850 miles on it. I was wondering if someone could actually tell me about the warranty at this point whats covered, whats left. I'm the second owner, i want to just it checked out. Couple of odd things like to get checked out, but i'm tired of spending money thats why I thought I bought a new with warranty, so I wouldn't have to pay for replacement parts or inspection costs for a few years. Manual 6spd I've read that it is normal to have that clutch/transmission clunking sound sometimes. I also have when im stopped and 1st gear getting ready to take off if i have the car turned hard as if backing out of a driveway that there is a what I would describe as a gear grinding sound in the rear. but thats really the only time it does it. I don't know anything about cars fyi lol. Please let me know thanks!
genesiscoupe7 is offline
post #89 of 98 Old 10-15-2012
a.k.a. DevilDog
https://www.hyundaiusa.com/assurance...-warranty.aspx
post #90 of 98 Old 10-15-2012
thanks for the link, to me it looks like I have the 5/60k left on it, I called my closest dealership they said its 125 inspection fee to look at the car? Is that cause I said I just want to have it checked out to make sure nothing is wrong with it? or do I need to say, I hear a sound and want to get it checked out?
post #91 of 98 Old 10-15-2012
a.k.a. DevilDog
Yes, you are bout 25k left.
They are full of crap. Just go get your oil change one time and any Hyundai dealership and they are supposed to check for specific things based on the mileage.
post #92 of 98 Old 10-15-2012
a.k.a. DevilDog
Btw, if JewishThunder flames the crap out of you, don't freak out or take it personally
post #93 of 98 Old 10-15-2012
newmedia's Avatar
LOL, This is what the hyundai factory worker did installing the crankshaft.
This improper install will not cause engine breakdown in near term according to Pavel so do not worry on your 3.8 GC .
newmedia is offline
post #94 of 98 Old 10-15-2012
a.k.a. DevilDog
post #95 of 98 Old 10-15-2012
newmedia's Avatar
double post
newmedia is offline
post #96 of 98 Old 10-15-2012
newmedia's Avatar
He took the engine apart and started to do measurements and found the crankshaft out of spec. I send him photo of part he needs for rebuild and this is from Pavels Racing Engines on his facebook - Email received. "Crank looks good. Once it comes in I will measure all journals and contact you".
here is some info on journals.
AutoEducation.com - Engine crankshaft and how it works
newmedia is offline
post #97 of 98 Old 10-17-2012
newmedia's Avatar
The crankshaft will be sent out for repair and coating to california / about two weeks turnaround time and Pavel racing engines has update on the facebook regarding the engine development.
newmedia is offline
post #98 of 98 Old 10-18-2012
newmedia's Avatar
email from Pavel " Engine disassembled and 0.040 inch crankshaft play measured. Hyundai installed rear thrust bearings backward causing wear on the crankshaft."
newmedia is offline
new to the forum!! Platypus New Member Section 6 12-25-2011 12:14 PM
Chopards Engine Watch Channels Luxury Autos Engine Block AutoGuide.com AutoGuide.Com News 0 06-10-2011 10:40 AM
Our engine compared to R35 3.8L engine? Madhockeyplaya7 3.8 V6 Discussion 2008-2012 51 02-16-2010 08:09 AM
Engine Forum Greg Gencoupe.com Site Issues, Support & Help 0 03-29-2009 06:06 AM
New member/intro forum, other car forum NCH Gencoupe.com Site Issues, Support & Help 1 03-21-2009 10:33 AM
