All of a sudden, this site is slow - Hyundai Genesis Forum
post #1 of 11 Old 10-21-2013 Thread Starter
The past week or so I'm seeing really long load times for forum threads. Clicking a link to open a thread can take 5 or 6 seconds whereas before it was pretty instantaneous. This happens for me with multiple browsers on multiple systems so I don't think it's me.
The browsers tend to show two sites that continually take a long time to load, static.verticalscope.com and b.scorecardresearch.com.
Here are pings and tracerts to both servers and the numbers seem fine, yet the forum is much slower than these numbers would seem to indicate.
Anyone else noticing this too?
Code:
C:\Windows>ping static.verticalscope.com
Pinging static.verticalscope.com [67.223.104.26] with 32 bytes of data:
Reply from 67.223.104.26: bytes=32 time=80ms TTL=50
Reply from 67.223.104.26: bytes=32 time=81ms TTL=50
Ping statistics for 67.223.104.26:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 80ms, Maximum = 81ms, Average = 80ms
C:\Windows>tracert static.verticalscope.com
Tracing route to static.verticalscope.com [67.223.104.26]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  unknown [192.168.1.1]
  2    46 ms    19 ms    29 ms  69.181.132.1
  3    10 ms    10 ms     9 ms  te-0-1-0-7-ur14.sanjose.ca.sfba.comcast.net [68.87.196.157]
  4    12 ms    11 ms    11 ms  te-1-13-0-11-ar01.oakland.ca.sfba.comcast.net [69.139.198.158]
  5    13 ms    11 ms    15 ms  be-90-ar01.sfsutro.ca.sfba.comcast.net [68.85.155.14]
  6    13 ms    15 ms    15 ms  he-3-8-0-0-cr01.sanjose.ca.ibone.comcast.net [68.86.94.85]
  7    44 ms    13 ms    14 ms  50-242-148-34-static.hfc.comcastbusiness.net [50.242.148.34]
  8    82 ms    82 ms    83 ms  vlan70.csw2.SanJose1.Level3.net [4.69.152.126]
  9    83 ms    83 ms    82 ms  ae-72-72.ebr2.SanJose1.Level3.net [4.69.153.21]
 10    82 ms    92 ms    83 ms  ae-2-2.ebr2.SanJose5.Level3.net [4.69.148.141]
 11    83 ms    82 ms    89 ms  ae-6-6.ebr2.LosAngeles1.Level3.net [4.69.148.201]
 12    82 ms    82 ms    84 ms  ae-3-3.ebr3.Dallas1.Level3.net [4.69.132.78]
 13    83 ms    82 ms    83 ms  ae-93-93.csw4.Dallas1.Level3.net [4.69.151.169]
 14    82 ms    82 ms    83 ms  ae-91-91.ebr1.Dallas1.Level3.net [4.69.151.162]
 15    82 ms    82 ms    81 ms  ae-14-14.ebr2.Chicago2.Level3.net [4.69.151.117]
 16   100 ms    82 ms    81 ms  ae-5-5.ebr2.Chicago1.Level3.net [4.69.140.193]
 17    82 ms   103 ms    83 ms  ae-1-100.ebr1.Chicago1.Level3.net [4.69.151.177]
 18   114 ms    82 ms    81 ms  ae-1-9.bar1.Toronto1.Level3.net [4.69.151.109]
 19    82 ms    83 ms    82 ms  ae-1-13.edge1.Toronto2.Level3.net [4.69.200.234]
 20    80 ms    81 ms    80 ms  WBS-CONNECT.edge1.Toronto2.Level3.net [4.59.180.62]
 21    80 ms    80 ms    81 ms  te-1-1.dist02.tor1.prioritycolo.com [204.11.48.135]
 22    83 ms    83 ms    83 ms  67.223.96.59 [67.223.96.59]
 23    82 ms    79 ms    81 ms  26-104-223-67-static.prioritycolo.com [67.223.104.26]
Trace complete.
Code:
C:\Windows>ping b.scorecardresearch.com
Pinging a1294.w20.akamai.net [96.17.148.41] with 32 bytes of data:
Reply from 96.17.148.41: bytes=32 time=12ms TTL=58
Reply from 96.17.148.41: bytes=32 time=14ms TTL=58
Reply from 96.17.148.41: bytes=32 time=15ms TTL=58
Reply from 96.17.148.41: bytes=32 time=13ms TTL=58
Ping statistics for 96.17.148.41:
    Minimum = 12ms, Maximum = 15ms, Average = 13ms
C:\Windows>tracert b.scorecardresearch.com
Tracing route to a1294.w20.akamai.net [96.17.148.43]
  2    33 ms    21 ms    19 ms  69.181.132.1
  3    10 ms     8 ms     9 ms  te-0-1-0-7-ur14.sanjose.ca.sfba.comcast.net [68.87.196.157]
  4    13 ms    11 ms    15 ms  te-1-13-0-7-ar01.oakland.ca.sfba.comcast.net [69.139.199.126]
  5    14 ms    15 ms    15 ms  be-100-ar01.sfsutro.ca.sfba.comcast.net [68.85.155.18]
  6    17 ms    15 ms    15 ms  he-1-8-0-0-cr01.sanjose.ca.ibone.comcast.net [68.86.91.229]
  7    15 ms    14 ms    16 ms  pos-0-7-0-0-pe01.529bryant.ca.ibone.comcast.net [68.86.88.202]
  8    14 ms    13 ms    14 ms  a96-17-148-43.deploy.akamaitechnologies.com [96.17.148.43]
Trace complete.
2013 3.8 Track Auto
Tsukuba Red
tonydi is offline
post #2 of 11 Old 10-21-2013
Ricer
Roly D Sauce's Avatar
uhhh....
what?
Roly D Sauce is offline
post #3 of 11 Old 10-21-2013
never use only drop once!
BKED's Avatar
I constantly have lag issues with the forum, but only at work, and our network is trash. I'm on IE 7. SERIOUSLY? Never really seem to have issues from home. Are you on the same ISP on all the networks/devices that you're testing on? It could very well be an ISP issue.
As far as dev is concerned, it's one thing to traceroute pings it's another thing to download dynamic content. I'm not sure what kind of framework the forum uses for everything, but it could just be issues with their side. It's mostly just text, but you gotta figure it's pulling an image file for every avatar which needs to load. Most of the menus and divs look like they're simple css and html markup, only the header and the ads look to be image based. Should be a pretty responsive site considering the amount of dynamic content. Nothing too tricky to report just looking at the surface. Do you typically disable javascript or caching/cookies in your browsers? Stuff like the "last visited" and login panel and post count, etc are probably run off of javascript...so if you have that turned off that could do it. Might be slowing thigns down pulling an alternate version of the site. What browser do you use? IE has really poor standards compliance, though a big forum like this with a dedicated support staff should be able to handle all browsers with no issues...but if you're only a really old version it may be falling out of support.
2010 Bathurst Black 3.8 M/T US Spec Grand Touring
Injen CAI | Magnaflow CBE | SFR Tune | Stance GR+ | TS Short Throw & Shifter Bushings | MR Trans Mount | SeoulSport Radiator | 3.77 Torsen LSD | PBM Subframe Risers | PBM Upper & Lower Traction Rods | Competition Stage 3 Clutch & Flywheel | Agency Power SS Braided Clutch Line | Redline Fluid | Gold Ghost Pearl White Dip | Hana Bumper | Custom Lights | Vertini Wheels | Hankook Ventus V12 235/35F 275/35R | 15% Tint
BKED is offline
post #4 of 11 Old 10-21-2013
BKED's Avatar
You're on comcast it looks like? Yeah...just burn your modem as an offering to the computing Gods. Comcast is the biggest bunch of Mooseknuckled Douchecanoes on the planet.
BKED is offline
post #5 of 11 Old 10-25-2013 Thread Starter
And today, it's back to being super fast, like it always was!
I ran gencoupe.com through some online testing sites and someone definitely made a change because the numbers are much better than they were before.
2013 3.8 Track Auto
Tsukuba Red
tonydi is offline
post #6 of 11 Old 10-25-2013
Timbit Biter
Torsen's Avatar
Quoted: 69 Post(s)
When you pay and become a Premium Member, you don't get all the ads any more, and it is much faster.
2016 Ford Mustang GT PP
2011 Hyundai Genesis Sedan 4.6 (daily driver)
2007 BMW M5 *sold*
2011 Ford Taurus SHO (twin turbo) - Livernois Stage 4 Tune *sold*
2013 3.8 Track 8AT *sold*
Torsen is offline
post #7 of 11 Old 10-26-2013
lilthanhxd's Avatar
Jailbreak ur iPhone and it's free if u have an iPhone
lilthanhxd is offline
post #8 of 11 Old 10-26-2013 Thread Starter
Two problems with that idea....one, this wasn't an ad display problem, it was a problem with two of the outside tracking services. And two, I wasn't a Premium Member when it was fast for all 6 months I've been here and I wasn't a Premium Member now that it's back to being fast. So it's never been about the ads.
2013 3.8 Track Auto
Tsukuba Red
tonydi is offline
post #9 of 11 Old 10-26-2013
Timbit Biter
Torsen's Avatar
Quoted: 69 Post(s)
I've definitely noticed a difference in the speed of the site since becoming a Premium Member. The pages load instantly for me. Even on the date you started this thread, I had no issues at all with the site. It's just always fast.
2007 BMW M5 *sold*
Torsen is offline
post #10 of 11 Old 10-28-2013
Administrator
hey Tony,
I am not noticing any issues with site speed on my side. Are you still having an issue with this? Also are there times during the day when it is worse then others?
- dm, community support
Gencoupe ADMINISTRATOR
admin is offline
post #11 of 11 Old 10-28-2013 Thread Starter
Nope, it's been back to great speed since the 25th. It was definitely having issues with the two tracking sites I noted in my original post. Now things load quickly enough that I can barely see those names show up in the browser's status bar at the bottom.
2013 3.8 Track Auto
Tsukuba Red
tonydi is offline
Sudden loss of power driving Alt0id 2.0T Discussion 2008-2012 20 06-13-2015 11:10 PM
This site loads VERY slow for me, if at all. Any way to improve? Suns_PSD Gencoupe.com Site Issues, Support & Help 4 07-22-2011 11:07 PM
When all of a sudden out of no where... Geniousis2010 General Discussion 5 07-15-2011 03:01 PM
sudden thud when accelerating from stop Coop16 General Discussion 15 09-08-2010 04:05 PM
