Cold air intakes. - Hyundai Genesis Forum
 5Likes
  • 1 Post By hk10_gen
  • 1 Post By RedGen13
  • 3 Post By GenRacer Support
post #1 of 12 Old 05-04-2016 Thread Starter
Cold air intakes.
I'm looking to buy a cold air intake, but i'm not sure where to start. I was looking at the Injen 2.0L Cold air Intake. Worth it or not?
Ramon Soto III is offline
post #2 of 12 Old 05-04-2016
hk10_gen's Avatar
Depends on what you want. There's a lot of threads about comparing performance, but if you just want the looks/sound you can add a cone filter from K&N or someone on your stock piping.
Ramon Soto III likes this.
2011 Mirabeau Blue 2.0T Premium
K&N CAI
30% Tint
Wing Emblems
M&S Type D Grill
Xentec 6000K HIDs
Diode Dynamics 6000K Fog Light LEDs
Nexus 7 Tablet
Power Folding Mirrors
hk10_gen is offline
post #3 of 12 Old 05-05-2016
RedGen13's Avatar
Quoted: 147 Post(s)
You will see zero gains from a cold air intake, it is more for looks and sounds.
I have the Injen intake, but mostly because I liked how it looked and I wanted the turbo spool sound. There was no noticeable performance increase.
So, the question you have to ask yourself is, "Is it worth the $200 for the sound and look of an Injen intake." A cone filter on the stock piping will give you the same sound, you just wont have the flashy pipe and heat shield of an Injen intake.
'13 2.0T R-Spec
  • BTR Stage 3 GTX3076 @ 24psi
  • MXP exhaust manifold
  • 3" Custom turbo back
  • Synapse BOV
  • Injen Intake
  • BK1 Intake Manifold
  • 4.18 final drive w/ LSD
  • Slotted and dimpled rotors
  • Wing Badges
  • CF "functional" hood vents
'99 Eclipse Fully Built
RedGen13 is offline
post #4 of 12 Old 05-05-2016
inertiamonster's Avatar
Quoted: 670 Post(s)
Ooh goody, another cold air intake thread!
2013 3.8 Track Pearl White
inertiamonster is online now
post #5 of 12 Old 05-05-2016
The OG Gencoupe Shop
GenRacer Support's Avatar
Quoted: 68 Post(s)
Zero gains they said
Just for looks and sound they said.
Data doesn't lie.
GENCOUPE MEMBER DISCOUNT
USE COUPON CODE 42-36876 ON GENRACER
Free Shipping for orders over $500, limits apply
YOUR TRUSTED PERFORMANCE SOURCE
CLICK TO READ WHAT PEOPLE HAVE TO SAY ABOUT GENRACER!
[ now accepting WHOLESALE accounts ]
CLICK HERE FOR DETAILS
GenRacer Support is offline
post #6 of 12 Old 05-05-2016
RedGen13's Avatar
Quoted: 147 Post(s)
Data of dyno charts done under unknown conditions?
You're not going to try and tell me that 5hp-10hp is even noticeable under driving conditions, let alone that it is outside the standard deviation of readings between dyno runs.
The filter element is what would cause the gains. Put a $50 cone filter on your stock piping and you will see similar numbers. I'm not trying to stop a sale from you, but it is a bit deceiving to make it sound like OP will even notice a difference in his driving for the $230+ he will be spending.
I'm not an idiot, and you took what I said literally word for word. Obviously there was some hyperbole. A better filter means better air flow, which can lead to more power. The reality is, like I said an aftermarket intake is more for looks and sound than performance. You will see the same ETA reduction from removing your spare and having half a tank of gas.
'13 2.0T R-Spec
  • Synapse BOV
  • Injen Intake
  • Wing Badges
RedGen13 is offline
post #7 of 12 Old 05-05-2016
Automotive idjut
Quoted: 69 Post(s)
There's some gain. Yes, you won't notice it hardly and you'll be doing it for sound until you have more breathing mods and a tune with it, but an intake usually helps with a couple of ponies. There isn't THAT much wrong with the stock airbox to see real gains by replacing it with an intake.
2013 2.0T 8AT
Kia recently installed itself on the front end. Must-have mod for those wanting an easy +100ish horses under the hood. Such an epic mod I don't even need the rest of the parts. FS thread incoming.
R2C SRI W/ Black Hex filter
Treadstone IC w/ piping
Synapse DV
DC Sports CBE
Depo DP/HFC
TurboXS O2 Housing
BTR Stage-AT Tune w/ NGK plugs
ADD W1 CC x2
SSR GTV03 18x8.5 +22F, 18x9.5+22R
Michelin Pilot Sport A/S 3 245/40F 275/40R
Oryan is offline
post #8 of 12 Old 05-05-2016
yammyboy's Avatar
Quoted: 49 Post(s)
When I had my 2014 Veloster turbo R Spec , I went to a dyno tune day with a bunch of Velosters from my forum. All I had was a dropin K&N filter in my stock air box. I dynoed 189 HP. Then Tork pulled my ECU and 20 minutes later I dynoed 221 HP. Then for shits and giggles he pulled the stock rubber air hose from the stock box only. I then dynoed another 8.3 HP. He just wanted to show me what I was missing by useing the stock set up and not a CAI. I eventually installed a CAI and was very happy with the results. I understand all engines are different. It just work's on that little 1.6 GDI turbo. I miss that little bugger.
2015 - Empire State Gray GC Ultimate 3.8 auto, K&N dropin air box mod ,grimspeed spacer, wrapped intake,,Megan cat back exh,,rigid collers, BK1 Track sway bars,olive burl dash , Wing badges,KS front lip, V3 tail lamps, ESR SR08 silver rims,19X9.5+22 fronts,19X10.5 +22 rears. Hankook Ventus V12 EVO120, 245-40 ft, 275-35 Rears.so far.
2017 - White Veloster value edition, N/A,stock so far.
2017 -Yamaha FZ10, gray with lime green rims, Reflashed, many boltons,.dyno tuned.
yammyboy is offline
post #9 of 12 Old 05-05-2016
yammyboy's Avatar
Quoted: 49 Post(s)
yammyboy is offline
post #10 of 12 Old 06-01-2016
Aftermarket intakes are pretty much the same when it comes to functionality, so just get the one that fits your budget. K&n, R2C, AEM and Injen are the popular brands.
ronemer is offline
post #11 of 12 Old 06-01-2016
chadbrochills's Avatar
Quoted: 116 Post(s)
Data doesn't lie.
Let's see some dynos from independent companies, not the ones selling the product. Sure, there may be a small hp/tq gain, but not enough that you will really notice it nor is it enough to justify spending the $ they charge on said products, IMO.
'10 Silverstone 2.0T Track
-DW 550cc injectors
-BK2 Tails w/ Audi mod
-BK2 Valeo HD clutch setup
chadbrochills is offline
post #12 of 12 Old 06-01-2016
SUN★WORKS
SteveJohns29's Avatar
Quoted: 153 Post(s)
Start here:
https://www.gencoupe.com/new-member-s...must-read.html
Then go here:
https://www.gencoupe.com/new-member-s...ml#post2287593
Then read these threads for lulz:
https://www.gencoupe.com/2-0t-discuss...my-engine.html
https://www.gencoupe.com/engine/10632...ked-motor.html
https://www.gencoupe.com/3-8-v6-discu...en-intake.html
Then remove your spare tire (who needs that) for the gainz and buy a SRI from @GenRacer Grant
Closing...
Sponsored by:
475WHP/363wtq
SteveJohns29 is offline
Closed Thread
Injen Cold Air Intakes - INCREDIBLE PRICING & FREE SHIPPING! [email protected] Engine 448 09-06-2014 08:14 AM
Cold Air vs. Short Ram Air Intakes Jeckyll 3.8 V6 Discussion 2008-2012 40 11-10-2011 07:41 AM
FS: AEM Cold Air Intakes for 2.0T like new ff183 Ontario 15 09-20-2011 06:29 PM
Aem cold air intakes special pricing!!!! Free s&h pm for price hyundaiparts4 Engine 263 04-05-2011 12:53 PM
People with Injen Cold Air Intakes Please Read synnyster 3.8 V6 Discussion 2008-2012 10 05-18-2010 05:14 PM
