Tros Potent Booster - Hyundai Genesis Forum
 52Likes
post #1 of 194 Old 05-25-2017 Thread Starter
Tros Potent Booster
I got one of these off AliExpress for around $120. It is similar to the other plug and play accelerator modifiers. It's great. It makes the acceleration from low speeds dramatically different. Makes the car much more pleasurable to drive.
Install is straight forward and not hard. Worst thing is getting the OE connector off the pedal. I used a needle nose vise grips adjusted to just apply pressure on the locking tabs but not crush the connector. You need a 10 mm socket to get the bolt out so you can lift the pedal off a hook and turn it around to get to the connector. But once off the furnished module plugs right in. Just make sure the wires are not in the way
It has 6 levels and a bypass setting. Three of the levels are for an automatic and three others for a manual. Each level has multiple settings which increase the effectiveness of the module. One level is ECO mode which I did not use, might be good as a somewhat valet mode though. The second level is a bit subdued and the to top level when tuned to 9 is a beast.
It was raining last night and I set it on the subdued 5 setting.
It does not change deceleration, it does not really change the action when at higher rpms. But taking off from idle or under 2000 rpm it can be quite dramatic as to how much faster the throttle opens.
I would guess this is good for a tenth or so at the 1/4 mile just from the 60 ft times.
titan2782 likes this.
post #2 of 194 Old 05-25-2017
spiralspektrum's Avatar
Quoted: 17 Post(s)
Thanks for the review. I've been following the sprint booster thread and heard about the Tros - been wanting to get more reviews from people on how it is. Do you have a manual or automatic? I plan on purchasing one in a few weeks hopefully.
2014 Genesis Coupe Ultimate - M/T
Genesis rebadge | Raceseng shift knob | Injen SRI | CNT v3 cat back | Depo test pipes | Mishimoto catch can | EBC yellowstuff pads | Megan transmission mount | ATQ SSK w/ bushings | engine leash | DD switchbacks
spiralspektrum is offline
post #3 of 194 Old 05-25-2017
Quoted: 17 Post(s)
Double post - original post didn't show up at first
post #4 of 194 Old 05-25-2017 Thread Starter
I have a manual. And I don't have any experience with the Sprint Booster.
post #5 of 194 Old 05-25-2017
Quoted: 244 Post(s)
Cool, I have the Sprint V3 and love it, no complaints but I would have gone with the Tros just for the substantialy cheaper price as I dont use the lock or valet modes and just keep mine cranked up to race 9 mode all the time. Still I dontregret the purchace, the thing really works.
lvdukerider is offline
post #6 of 194 Old 06-06-2017
I just bought the Tros for my 2013 manual transmission for about $120. It was a breeze to install. The results are pretty impressive but the highest setting is way too aggressive. I am still fine tuning the right level for me but the throttle response is impressive. Definitely worth the upgrade. Time will tell regarding quality. Cheers.
azcats00 is offline
post #7 of 194 Old 06-07-2017 Thread Starter
I have mine set at HH5 or 6.
post #8 of 194 Old 06-09-2017
goodmanale's Avatar
Quoted: 66 Post(s)
Red, did you order the TS-988 model (6-Drive)?
Also, there appears to be a 9-Drive model now, the TP-988.
Are these only sold from AliExpress?
2015 Caspian Black Genesis Coupe R-Spec
SFR 93 Canned Tune
Megan Transmission Mount
Custom Magnaflow CBE
Drop-In K&N Filter (Removed)
3POINT8 Engine Leash
AEM Short Ram Intake
Enkei T6S 18x8.5 (245/40)/18x9.5 (275/40)
goodmanale is offline
post #9 of 194 Old 06-09-2017 Thread Starter
Yes the TS988. I don't know where else to get them.
https://www.aliexpress.com/item/Pote...777979631.html
post #10 of 194 Old 06-09-2017
Quoted: 17 Post(s)
Where have you guys been attaching yours?
post #11 of 194 Old 06-09-2017 Thread Starter
Mine is just laying on the IC in front of the worthless temperature gauge. Not attached.
post #12 of 194 Old 06-09-2017
Quoted: 272 Post(s)
This thread has potential.......
2013 Empire State Gray 2.0t Base 6MT
- HKS SSQV
- K&N Drop-In
- Exceladyne CBE
- SFR S1 Tune
thomas91169 is offline
post #13 of 194 Old 06-09-2017 Thread Starter
This would be the first mod one should do with the Gen Coupe.
post #14 of 194 Old 06-24-2017
Where did you guys end up installing the black module that connects to the pedal? I have mine secured via zip ties to keep it out of the way on the right side of the pedal, but wasn't sure if there is a better way to secure it.
2015 Casablanca White 3.8 Ultimate
dxnguyen2 is offline
post #15 of 194 Old 06-25-2017 Thread Starter
I just stuck mine next to the pedal and trans tunnel no zip ties or anything.
post #16 of 194 Old 06-27-2017 Thread Starter
I tried out the ECO3 level setting as I am about out of gas last night. It severely reduces the throttle input and you cannot even go WOT at that setting.
post #17 of 194 Old 07-05-2017 Thread Starter
It seems what this does is the same as OE sport mode programs but is much more variable. I was on the aggressive tune FH3 and it was too much, even the FH1 was too jerky from a stop. So I went back to the HH levels and ran it all the way to HH9. It seems the change going to the FH 1-9 mode is just a continuation of the HH 1-9, taking up after HH9.
G6 Electronic Throttle Controller
Hard to find any documentation on line but this is the best there is. https://www.aliexpress.com/store/pro...763594136.html
post #18 of 194 Old 07-05-2017
goodmanale's Avatar
Quoted: 66 Post(s)
So it looks like they make a more simple version too. Not as much adjustability, but pretty clean looking.
Our model would be the CT-988.
There are a few other G (I suppose for generation) versions on their site. With different amounts of drive modes.
https://www.aliexpress.com/item/Pote...5-23cb4e9deb69
SFR 93 Canned Tune
post #19 of 194 Old 07-05-2017
Thanks to his thread I purchased a potent booster. installed into my stock 2013 2.0t manual, only mods blow off valve vented and some extra holes drilled into lower part of airbox all done for throttle response not power.
I don't know how this works but for my purposes it works great. I won't use the f settings because it is for lack of a better word turning the throttle into the equivalent of a 1/4 turn throttle on a motorcycle and makes the car much much to touchy for my liking, but using the hh3 or hh4 settings totally helps nullify the dead spot that the throttle has when taking off from a stop and makes it much more consistent. I always found the stock throttle action would change from day to day for no aparent reason, I attributed it to the aligment of the planets. I wish I would have purchased one of these years ago.
Red Raspberry and titan2782 like this.
beevel is offline
post #20 of 194 Old 07-07-2017
Notch__Johnson's Avatar
Quoted: 40 Post(s)
Ordered one myself. It's on its way. Excited to give it a try
2015 Casablanca White 3.8 A/T
| SFR Tune | Diode Dynamics Tail-as-Turn | Art of Speed Wing Rebadge |
| OEM Trunk Spoiler | Diode Dynamics Interior, Exterior LED and 6K HID lighting |
| 20% Tint | Eibach Sportlines | KS-Style Front Lip | AXX Style Rear Diffuser |
|Sequence Spec-1 Style Sideskirts | Muteki Black lugs | ESR SR08 19x9.5/10.5 Candy Teal
Notch__Johnson is offline
McLaren 650S Getting More Potent Version: Report AutoGuide.com AutoGuide.Com News 0 04-01-2014 08:10 AM
