NEED HELP I am not that knowledgeable - Hyundai Genesis Forum
post #1 of 6 Old 06-07-2018 Thread Starter
I am looking to replace my catalytic converter, but I cannot use test pipes because I want to pass smog. Are there any alternate parts that are similar? I have a 2016 hyundai genesis coupe 3.8 Automatic
josh42 is offline
post #2 of 6 Old 06-07-2018
Quoted: 16 Post(s)
Check manufacturers like Magnaflow, etc.
Someone has a low restriction cat that will get you past smog and allow the engine to breathe.
Good luck, have fun!
BBCMHG is offline
post #3 of 6 Old 06-09-2018
Daf410's Avatar
You can always get the 02 housing cat deletes. Just make sure that on the sensors that go "after the cat" you put the 02 sensor spacers. Ive done it on my previous cars. Even though they were honda, the 02 sensor spacers work the same way. Just make sure you know if you need the straight or elbow bent ones
Daf410 is offline
post #4 of 6 Old 06-11-2018
Quoted: 272 Post(s)
Do you need to pass sniffer or just visual inspection?
Are you in CA?
2013 Empire State Gray 2.0t Base 6MT
- HKS SSQV
- K&N Drop-In
- Exceladyne CBE
- SFR S1 Tune
thomas91169 is offline
post #5 of 6 Old 06-12-2018
RedGen13's Avatar
Quoted: 146 Post(s)
Changing out a cat is a pretty easy job. You could easily buy test pipes and then just swap your cat back in for smog. I don't live in a state with smog checks, but isn't it normally every 2 years? Spending an hour every 2 years wouldn't be a big deal in my opinion.
'13 2.0T R-Spec
  • BTR Stage 3 GTX3076 @ 24psi
  • MXP exhaust manifold
  • 3" Custom turbo back
  • Synapse BOV
  • Injen Intake
  • BK1 Intake Manifold
  • 4.18 final drive w/ LSD
  • Slotted and dimpled rotors
  • Wing Badges
  • CF "functional" hood vents
'99 Eclipse Fully Built
RedGen13 is offline
post #6 of 6 Old 06-12-2018 Thread Starter
Yea I did not know it was easily replaceable until informed by friend, so that's what I am going to end up doing. I ordered ARK testpipes hopefully theyre good lol
josh42 is offline
NEED HELP I am not that knowledgeable josh42 3.8 V6 Discussion 2013 and up 38 08-02-2018 09:09 PM
NEED HELP I am not that knowledgeable josh42 New Member Section 1 05-31-2018 06:53 PM
