Car hesitates when going into boost - Hyundai Genesis Forum
post #1 of 7 Old 08-29-2018 Thread Starter
NimbusUli's Avatar
Hey guys, Iím new at this forum thing, but I have a serious problem that I canít figure out. So I have a 2013 GC 2.0t, I have an Injen cold air intake, ISR catback exhaust and aftermarket Hps radiator and heater hoses installed. That is all the Mods I have installed on it and my oil is only 300 miles used, as well as the radiator coolant. Plus I have a new Autocraft Gold battery. The car was driving great literally 5 days ago, but out of the blue when accelerating from around 30 and up mph, while going into boost, as my boost gauge indicates, the car starts to stutter and hesitate to the point where the car sort of gets stuck in that stutter unless I depress the gas pedal to go out of boost to stop the stuttering. I find it mind blowing that LITERALLY 5 days ago when driving, when I started to hear the cold air intake, while going into boost my car just took off beautifully, as any turbo charged GC should. So my question to you fellow GC owners is, why is this happening, any ideas as to what may be going on? Only answers I can think of is
1) NEED A TUNE (has never been tunned)
2) Replace spark plugs (maybe the ones I have on probably donít produce enough spark to support my mods?)
Thanks in advance, any answers would be appreciated.
NimbusUli is offline
post #2 of 7 Old 08-30-2018
Did you disconnect the battery to reset the learned fuel trims?
post #3 of 7 Old 08-30-2018
RedGen13's Avatar
Quoted: 147 Post(s)
Tried turning your traction control off?
'13 2.0T R-Spec
  • BTR Stage 3 GTX3076 @ 24psi
  • MXP exhaust manifold
  • 3" Custom turbo back
  • Synapse BOV
  • Injen Intake
  • BK1 Intake Manifold
  • 4.18 final drive w/ LSD
  • Slotted and dimpled rotors
  • Wing Badges
  • CF "functional" hood vents
'99 Eclipse Fully Built
RedGen13 is offline
post #4 of 7 Old 08-30-2018
mikeb1031's Avatar
get a good BOV, your still on the stock one right? thats probably it. also check your wastegate actuator arm. you can try to replace your spark plugs. and the tune would most likely not be the issue
2013 Gen Coupe 2.0T 6-spd
Injen SRI intake
3in Cat-back
SFR 1.5
Forge BOV
QTP cutout
BOV solenoid bypass
TB spacer + TB coolant bypass
mikeb1031 is offline
post #5 of 7 Old 08-30-2018 Thread Starter
NimbusUli's Avatar
Yes itís still stock. And what should I be checking for on the wastegate actuator arm exactly?
post #6 of 7 Old 08-31-2018 Thread Starter
NimbusUli's Avatar
I tried turning the traction control off, but it still happened 😫
post #7 of 7 Old 09-01-2018
genesisgenius's Avatar
Quoted: 40 Post(s)
scan engine codes bro. might not have check engine light but still can have a code that will throw a check engine light on later on. sounds like a misfire to me. if you didn't do anything most likely a spark plug went out.
GenesisGenius
Youtube Channel. http://youtube.com/c/genesisgenius
genesisgenius is offline
Porsche Camp4 Canada: Its Not About Going Fast, Its About Going Sideways AutoGuide.com AutoGuide.Com News 0 02-21-2013 08:30 AM
2012 2.0T RPM hesitates in 4th-6th gear around 3000RPM hdemel 2.0T Discussion 2008-2012 28 01-09-2013 07:31 PM
Car hesitates offaxis7 2.0T Discussion 2008-2012 14 04-14-2011 12:00 PM
