Pls Help Me Drop Down To 17's - Hyundai Genesis Forum
post #1 of 14 Old 4 Weeks Ago Thread Starter
Quoted: 98 Post(s)
....So I decided to kill 2 birds with 1 stone. I am changing out my rims very soon. I was going to stay with the stock 18 size diameter...but i also want to gear the rear end to 3.91. I recall seeing on this forum that going from 18's to 17's and keeping the same profile (45's) is the same as dropping the gearing from 354 to 391.
...My coupe is the 2010 base 3.8 6 speed ( NON brembos). If I order a set of 17's with the identical specs as my stock 18's...that's 5x143...67.1 center bore ect..will it be an easy swap? I am also going with lighter rims. I was in touch with an online rim outlet and at first I was told it's an easy change...but then I got the impression i might have problems??
Genesis306 is online now
post #2 of 14 Old 4 Weeks Ago
Quoted: 627 Post(s)
If you go with alloy wheels, it's hit or miss, as the clearances with the rim and the calipers are pretty tight with 17"
If you go with a lower offset, it should clear, but no guarantee.
I have 17" steal rims for my winter wheels and they clear fine. The problem going this route with the same ratio tires, is the car will sit lower, making it harder to get a jack under it.
post #3 of 14 Old 4 Weeks Ago Thread Starter
Quoted: 98 Post(s)
Offset stock is supposed to be 33. The differwnt rims I'm looking at have an offset of 38-45. When you say " lower " is that below 33 or above?
post #4 of 14 Old 4 Weeks Ago
Quoted: 627 Post(s)
Yes. 0 offset would mean the hub face meeting directly in the middle of the rim.
So 33 offset means 33mm in the direction of the first example.
post #5 of 14 Old 4 Weeks Ago Thread Starter
Quoted: 98 Post(s)
I have read that brembo brakes can cause problems with going to a smaller rim. Right now with the 18's I have 1.25" of clearance between the outside of the brake caliper and the rim.
...All I was going to do is pick a 18" rim with say a 40 offset that is guaranteed to fit my coupe...and find the exact same rim in a 17" with also a 40 offset and bolt it up.
post #6 of 14 Old 4 Weeks Ago
Quoted: 627 Post(s)
Did you take into account the clearance with the spokes?
Most people go the other direction for offset. IIRC 25 offset.
If you go too positive with the offset, then you'll have issues with back rim lip rubbing against the strut/spring.
post #7 of 14 Old 4 Weeks Ago Thread Starter
Quoted: 98 Post(s)
Lowest offset I can find in an aftermarket alloy rim is 35. My stock 18's are supposed to be 33. Going to do a lot of searching on the net to see who has done this on 17 alloys...not winter rims and not mustang rims etc.
post #8 of 14 Old 4 Weeks Ago Thread Starter
Quoted: 98 Post(s)
Xxr 527..17x8.25... 25 offset
post #9 of 14 Old 4 Weeks Ago Thread Starter
Quoted: 98 Post(s)
post #10 of 14 Old 4 Weeks Ago
Quoted: 627 Post(s)
Another reason why I went with steel wheels is, they are way lighter than most ally wheels of the same size.
This will do a lot more than going down in wheel size.
If I had to guess, mine are 10~15 pounds each without tires.
post #11 of 14 Old 4 Weeks Ago Thread Starter
Quoted: 98 Post(s)
Interesting about the steel wheels...I found a few alloys that are priced quite well and come in at about 18lbs
post #12 of 14 Old 4 Weeks Ago Thread Starter
Quoted: 98 Post(s)
10-15 lbs?...you got a pic....brand ect. 10 lbs is about 16 lbs lighter than the stock 28" rims
post #13 of 14 Old 4 Weeks Ago
Quoted: 627 Post(s)
Sorry, they're in storage now and I don't have any good photos of them. After 9 years, they are pretty rusty (surface rust, and only used in winter). Probably gonna unmount the tires, have them blasted and repaint them.
IIRC they are just dorman wheels.
Keep in mind, A majority of them are way positive offset. So depending on how wide you go, you are going to have to get spacers just to things don't rub.
I believe my are 8" wide, but it's been 9 years since I checked the size.
If I had to do it again, I would get 18x8 steel wheels (the shop only had 17s at the time)
post #14 of 14 Old 4 Weeks Ago Thread Starter
Quoted: 98 Post(s)
I sent a message to discount tire and got a reply within a few hours. They have a sub listing for my base coupe using 17" rims! There is like 143 rims in 17" that will work.
Coilovers with minimal drop lazn Suspension 2013 and up 11 04-11-2014 12:28 AM
biggest drop lowering springs? usafcase45 Suspension 2008-2012 30 05-15-2012 12:50 PM
2013 Ford Escape To Drop Hybrid, C-Max To Spearhead Hybrid Market AutoGuide.com AutoGuide.Com News 0 12-15-2011 04:50 PM
intercooler psi drop question whatnot 2.0T Discussion 2008-2012 7 12-30-2009 07:37 AM
