Timing chains replacement 2010 3.8 - Hyundai Genesis Forum
 3Likes
post #1 of 36 Old 2 Weeks Ago Thread Starter
Guys, Just replaced the timing chains in my 3.8 were streched throwing timing codes. Anyway back togeather and now my oil light comes on at idle. The slightest revs and oil light goes out. New oil and filter. Never had this problem before. I am certain oil pump gear and chain is all correct. any ideas. Fram oil filter. 5-20 oil. oil level good. no real noises engine quiet.
hucksterfool is offline
post #2 of 36 Old 2 Weeks Ago
In Charge of Snacks
Odelagt's Avatar
Quoted: 203 Post(s)
No clue as to the issue, but hats off to you for tackling BK1 Lambda chains. I have to do this soon and I'm dreading it.
'11 3.8 R-spec
Odelagt is offline
post #3 of 36 Old 2 Weeks Ago Thread Starter
https://photos.app.goo.gl/2CW3oy391yshWizu9
post #4 of 36 Old 2 Weeks Ago
I guess you need to know what the actual oil pressure is. Beware when trying to use something other than OE on the oil pressure sender threads as they are probably 1/8"-28 BSPT, not NPT 1/8 - 27.
post #5 of 36 Old 2 Weeks Ago Thread Starter
Is there a location I can hook a pressure gauge to thatís not under manafold? Really makes me hot as I never had an issue before. The filter is a non Hyaundai Fran one. I have read that people have had oil filter issues before. Was thinking to try to put old one in and see if corrects.
post #6 of 36 Old 2 Weeks Ago
There are issues with getting the wrong filter for the 3.8L. Some are too short.
post #7 of 36 Old 2 Weeks Ago
2012 Gen. 3.8 Track w/ZF
-fritz-'s Avatar
Quoted: 73 Post(s)
OE Oil filters are almost a must. Fram has a bad reputation.
Gencoupe Wings emblems.
Quad exhaust tips.
-fritz- is offline
post #8 of 36 Old 2 Weeks Ago Thread Starter
Picking up a factory filter at lunch and swapping it tonight.
post #9 of 36 Old 2 Weeks Ago
Quoted: 626 Post(s)
did you prime the oil pump after putting in the chain?
post #10 of 36 Old 2 Weeks Ago Thread Starter
The guide I had didnít mention priming.
post #11 of 36 Old 2 Weeks Ago
Quoted: 626 Post(s)
remove spark plugs, disconnect injectors, crank the motor 10 seconds at a time.
Maybe crank it 3 times with 30 seconds in between cranks to let the starter cool down.
Make sure to prefill the oil filter when you replace it just this time, since you had the oil pan off
post #12 of 36 Old 2 Weeks Ago Thread Starter
I did do that yes. I thought you meant prime with a tool
post #13 of 36 Old 2 Weeks Ago
Quoted: 626 Post(s)
priming with a tool would mean using a high torque drill with a socket attachment on the crank, and removing the spark plugs.
Basically the same principle, but I think you don't want to bother with removing the AC condenser and radiator out of the way to do that.
post #14 of 36 Old 2 Weeks Ago
When i did my 2L and turned the crank by hand after installing to check the cam timing marks this primed the oil pump. But I went around more than two revolutions.
post #15 of 36 Old 2 Weeks Ago Thread Starter
Changed to factory filter. Same issue. Is possible itís just a fluke and sensor went bad. Maybe taking front engine cover frees some gunk that got caught in sensor? Engine quiet at idle. Runs good
post #16 of 36 Old 2 Weeks Ago Thread Starter
Is there any truth to this post I found?
post #17 of 36 Old 2 Weeks Ago
andbudzi's Avatar
Quoted: 441 Post(s)
Not really. They recalled 2.0 in sonatas due to debris.
andbudzi is offline
post #18 of 36 Old 2 Weeks Ago Thread Starter
I tried a little thicker oil. Light off now however getting p0014. Ocv not happy with thicker oil. I give up. I did the timing chains due to a p0018. Couldnít get it to pass emissions
post #19 of 36 Old 2 Weeks Ago
Quoted: 626 Post(s)
I tried a little thicker oil. Light off now however getting p0014. Ocv not happy with thicker oil. I give up. I did the timing chains due to a p0018. Couldn’t get it to pass emissions
Take off the oil control valve and inspect it. Put it back on and test (could be a grounding issue with the valve)
If it's fine, then it could be the ocv filter. Good luck with that. You have to remove the head to get to it.
I don't know why hyun/mitsu/dodge designed the ocv filter like that, when all their other previous engines had it to where you just have to remove a bolt to get to it.
post #20 of 36 Old 2 Weeks Ago
Quoted: 97 Post(s)
I have seen a few videos on YouTube where they show that those fram oil filters are absolute garbage...made with cheap materials. I have also had a problem a few times trying to get the correct oil filter from the dealer for my 2010 3.8. They had to go off of my vin# to make sure it was correct.
Genesis306 is online now
Official Texas Roll Call - *Updated 12/28/2012* WildBill Texas 115 05-04-2018 05:26 AM
