Warped rotor? and weird rust spot - Hyundai Genesis Forum
 4Likes
  • 1 Post By -fritz-
  • 1 Post By AKGC
  • 1 Post By Red Raspberry
  • 1 Post By erikv51
post #1 of 19 Old 4 Weeks Ago Thread Starter
erikv51's Avatar
The past few weeks i’ve been hearing a slight scratchy noise coming from the front. I’m assuming it can be a warped rotor. recently it has started to sound very scratchy when braking and sounds very grindy. The type of sound that will make you not want to brake lol. checked out my rotors and this is what i found on the front right. the front left leaves a lot of break dust as i have noticed that rim always gets way dirtier. Any thoughts? i plan on replacing the rotors and the pads very soon.
File Type: jpeg 9CB3E1CB-505E-45E6-AEC3-84A9D301D429_1558518916758.jpeg (930.9 KB, 11 views)
erikv51 is offline
post #2 of 19 Old 4 Weeks Ago
What pads and how many miles and what brakes? I would not worry about that rust spot. And as long as the pads are not gone and you are pressing the metal backing plate against the rotor then no problem there. The rotor looks like it has a bad spot in it but I would say it is only cosmetic.
post #3 of 19 Old 3 Weeks Ago Thread Starter
erikv51's Avatar
i purchased the car at around 74,000 miles. it has brembo brakes but idk if it’s the stock rotor and idk what pads they are. on car fax it says the last time the brakes were changed was at 51,000 miles. The brakes grind the most when the car is about to come to a complete stop and i can feel it on the brake pedal. It’s really an ear sore
erikv51 is offline
post #4 of 19 Old 3 Weeks Ago
2012 Gen. 3.8 Track w/ZF
-fritz-'s Avatar
Quoted: 74 Post(s)
Your rotor looks like a Brembo rotor. It's a vented disc having an open slot between the inner and outer disc. I have 101,500 miles on mine and am on my 3rd set of front pads. I get the ceramic pads from Autozone and my rotors have held up pretty well. The next pad change I will remove the rotors and have them turned. Not sure it's needed though since they are not grooved or warped. The ceramics leave very little dust and stop the car much better than stock pads.
Red Raspberry likes this.
Gencoupe Wings emblems.
Quad exhaust tips.
-fritz- is offline
post #5 of 19 Old 3 Weeks Ago
Reader of many threads
TKJode's Avatar
Quoted: 204 Post(s)
those spots can form if the car has been sitting a long time exposed to rain and there was some contamination on the pads like a small rock or peice of metal. the rotor will get a deep oxidization spot and then subsequent use will sweep away the rust but leave a small crevice.
A warped rotor doesn't make noise, it just wobbles and induces vibration into the steering column and/or the entire car when you hit the brakes.
I think you just have an inclusion on that one pad that's making the noise. No harm in replacing the front pads first, you can try them out and if the noise hasn't gone away, get some new rotors and then bed them in while your pads are still relatively new (don't wait too long if it's still a problem, the best bedding in time for pads/rotors are when they're both new and clean).
2010 Silverstone 380GT
TKJode is offline
post #6 of 19 Old 3 Weeks Ago
Quoted: 638 Post(s)
It just looks like someone didn't use brake clean when changing out rotors or pads.
Basically it looks like a thumb print.
post #7 of 19 Old 3 Weeks Ago
The OE Brembos are great rotors. So many dump them for bling. Maybe not the best for all out track driving though. I've got +95k miles on mine and only half worn. Smooth as can be.
-fritz- likes this.
post #8 of 19 Old 3 Weeks Ago
Quoted: 638 Post(s)
They probably resurfaced them. Thats what I mean by change out.
Anyways, If it's the fronts, then I highly doubt that, because the rotors are what, 2" thick.
The rears are more likely to warp because of it not being vented (assumption, because I'm still running base model brakes)
post #9 of 19 Old 3 Weeks Ago
TKJode's Avatar
Quoted: 204 Post(s)
All 4 corners are vented OEM. The rears are a little thinner and have a bigger hat, so less contact surface. They never get hot enough to warp unless you've got some serious pad dragging happening, I've never been able to get them to smoke at the track and they're super annoying to get properly bedded in.
TKJode is offline
post #10 of 19 Old 3 Weeks Ago Thread Starter
erikv51's Avatar
sometimes when i brake the steering wheel shakes slightly. Additionally, I have had some instances where it pulls to one side when i’m braking. I have been considering getting new pads and new slotted and drilled rotors. I would probably get the pads first though and see if the noise and grinding goes away.
erikv51 is offline
post #11 of 19 Old 3 Weeks Ago
TKJode's Avatar
Quoted: 204 Post(s)
Originally Posted by erikv51 View Post
sometimes when i brake the steering wheel shakes slightly. Additionally, I have had some instances where it pulls to one side when iím braking. I have been considering getting new pads and new slotted and drilled rotors. I would probably get the pads first though and see if the noise and grinding goes away.
Wiggle means new rotors for me. Chuck 'em. You're probably getting the pull because the brake balance is off due to the warping - pads won't fix that. Get some Stoptech (Centric) OE blank brembo rotors, they hold up nice. Or go slotted for some bling factor
TKJode is offline
post #12 of 19 Old 3 Weeks Ago
Quoted: 638 Post(s)
wiggle could be a number of factors.
tire balance
tire out of round
wheel bearings
bad ball joints
etc...
but if it's causing steering wiggle, then it does have to do with something in the front.
post #13 of 19 Old 3 Weeks Ago
New aggressive pads and some hard braking will probably clean off the rotors. Don't have them turned down unless that does not fix them.
post #14 of 19 Old 3 Weeks Ago
dagreekgencoupe's Avatar
Quoted: 65 Post(s)
It looks like that little finished part of the rotor flaked off. Run you finger nail over it, if it feels like a dimple (the rusty part is below the finished part of the rotor), then it flaked off. It's happened before and probably will happen again, rotors are made from iron and when the finished part flakes off, you have the old rusty iron part underneath. The grinding you hear is probably the flaked off part embedded itself into your pad. Also, if you're having a shimmy and pull when braking, it's the rotors. They do look like they have some grooves in them, run your finger nail up and down over the finished part of the rotor, if it's got grooves, it will shimmy and pull. Also, ceramic pads are not the best for performance, they make little to no dust but cook the rotors, because they transfer heat to the rotors instead of absorbing the heat, they do not have as good of a bite and they fade more. Semi-metallic are better performers or better yet get composite pads which are semi-metallic and carbon, but you will be cleaning your rims more. Then again those rims look like they are easy to clean.
2010 2.0T Premium 6 Speed M/T
SFR Stage 1 Tune 93 Octane
SRI
Megan Racing Tranny Mount
Actuator arm baseline adjustment, needed 3 whole turns
Injen Intercoolers Pipes
Turbo Boost Gauge
HID Headlight Conversion Kit
Red LEDs in Dash, Center Display, HVAC Controls, Steering Wheel Controls and Window Switches
Spyder LED Taillights
Rear Lip Spoiler
dagreekgencoupe is offline
post #15 of 19 Old 3 Weeks Ago Thread Starter
erikv51's Avatar
I have determined that the noise and grinding is coming from my front left wheel. it is honestly sounding like metal to metal at this point but the pads look fine to me, then again i haven’t taken the wheel off to get a closer look at everything. It feels almost dangerous to brake so i’m trying to drive as calmly as possible until my brake kit gets here
erikv51 is offline
post #16 of 19 Old 3 Weeks Ago Thread Starter
erikv51's Avatar
here is a video of what it sounds like. It gets very loud when I am about to come to a complete stop and I feel it in the brake pedal and steering wheel.
https://youtu.be/6u-HcNGF8co
erikv51 is offline
post #17 of 19 Old 3 Weeks Ago
Ryno269's Avatar
Quoted: 23 Post(s)
Wheel bearing is what I'd be checking next if it ain't the brakes. Put that side up on a jack and grab the wheel by it's face and see if there is any play by pushing and pulling on the rim. I had this happen before on another car and thought it was my brakes and ended up discovering it was the wheel bearing making all the noise.
Ryno269 is offline
post #18 of 19 Old 3 Weeks Ago Thread Starter
erikv51's Avatar
Thank you for the advice. I’m prettu convinced it’s the brakes, the rotor looks very scratched up. I ordered this brake kit. Installing tomorrow
erikv51 is offline
post #19 of 19 Old 3 Weeks Ago Thread Starter
erikv51's Avatar
https://m.autozone.com/brakes-and-tr..._252162_0?aqs=
TKJode likes this.
erikv51 is offline
