Help!! Car wont start. - Hyundai Genesis Forum
post #1 of 14 Old 06-15-2019 Thread Starter
Question Help!! Car wont start.
Okay so...car is a bk2 auto and has intake, bov, turboback exhaust. After deleting the cats and having to get transmission replaced car runs fine on stock tune. Now car wont start on sfr tune (worked fine before deleting cats) and car is throwing P2564 and p2562 codes. Could it be the wastegate?
Bk2_Dash is offline
post #2 of 14 Old 06-15-2019
Ryno269's Avatar
Quoted: 23 Post(s)
Did you do the keydance routine? The throttle position sensor needs to calibrate itself.
Ryno269 is offline
post #3 of 14 Old 06-15-2019
Ryno269's Avatar
Quoted: 23 Post(s)
I'm.not quite sure if you're saying you just switched out the ECU so I'm going to the most common problem.
Ryno269 is offline
post #4 of 14 Old 06-16-2019 Thread Starter
Yeah did the key dance multiple times and car just wont turn over.
Bk2_Dash is offline
post #5 of 14 Old 06-17-2019
Quoted: 654 Post(s)
Define "won't start"
accessories turn on?
cranks?
or just nothing?
post #6 of 14 Old 06-18-2019 Thread Starter
cranks?
or just nothing?
Yes accessories turn on and car cranks just wont start and I have no idea why
Bk2_Dash is offline
post #7 of 14 Old 4 Weeks Ago
Quoted: 654 Post(s)
disconnect the battery for an hour
post #8 of 14 Old 4 Weeks Ago
Ryno269's Avatar
Quoted: 23 Post(s)
That's my next step on advice too. Disconnect the battery and unplug the ECU. Let it all sit for a bit then hook everything back up and again do the keydance.
Ryno269 is offline
post #9 of 14 Old 4 Weeks Ago Thread Starter
Yeah tries that. Still wont start.
Bk2_Dash is offline
post #10 of 14 Old 4 Weeks Ago Thread Starter
Seems like the throttle position sensor isnt recalibrating when when reading the tuned ecu
Bk2_Dash is offline
post #11 of 14 Old 4 Weeks Ago
Quoted: 654 Post(s)
what cables were disconnected during the install?
Was the battery disconnected while your were removing/installing parts?
post #12 of 14 Old 4 Weeks Ago Thread Starter
Yes disconnected battery, then stock ecu, then connected sfr ecu. Have disconnected and reconnected multiple times
Bk2_Dash is offline
post #13 of 14 Old 4 Weeks Ago
Quoted: 654 Post(s)
was the transmission control module replaced with the transmission.
Does your car have factory keyless start, aka button start?
If it does, then the tcm, bcm, ecu, and immobilizer module have to match.
That's likely why it won't start with either ecu.
The likely issue is the tcm not matching.
post #14 of 14 Old 4 Weeks Ago Thread Starter
Yes keyless entry. Car starts fine with stock ecu.
Bk2_Dash is offline
